No Memory Available
Здраствуйте! Загрузил в Инстанс вторую базу, также начал делать статистику и реорганизацию. В последствии "не работали табличные пространства"Обращение к табличному пространству не разрешено SQLSTATE=55039"". Посмотрев в db2diag.log увидел ошибки: 2013-07-30-16.38.36.781000+180 I132476F735 LEVEL: Error PID : 23164 TID : 24244 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : BICA APPHDL : 0-15 APPID: ::1.59834.130730133836 AUTHID : USR1CV82 EDUID : 24244 EDUNAME: db2agent (BICA) FUNCTION: DB2 UDB, SQO Memory Management, sqlogmshr, probe:149 MESSAGE : ZRC=0x850F0005=-2062614523=SQLO_NOSEG "No Storage Available for allocation" DIA8305C Memory allocation failure occurred. DATA #1 : String, 8 bytes BICA DATA #2 : String, 56 bytes Insufficient INSTANCE_MEMORY to allocate new memory set. DATA #3 : numChunks, PD_TYPE_NUM_CHUNKS, 4 bytes 37304 2013-07-30-16.38.36.782000+180 E133213F958 LEVEL: Warning PID : 23164 TID : 24244 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : BICA APPHDL : 0-15 APPID: ::1.59834.130730133836 AUTHID : USR1CV82 EDUID : 24244 EDUNAME: db2agent (BICA) FUNCTION: DB2 UDB, base sys utilities, sqeLocalDatabase::FirstConnect, probe:100 MESSAGE : ZRC=0x850F0005=-2062614523=SQLO_NOSEG "No Storage Available for allocation" DIA8305C Memory allocation failure occurred. DATA #1 : String, 303 bytes Failed to allocate the desired database shared memory set. The configured DATABASE_MEMORY plus desired overflow may have exceeded INSTANCE_MEMORY or the maximum shared memory on the system. Attempting to start up with a smaller overflow allowance. Desired database shared memory set size is (bytes): DATA #2 : unsigned integer, 8 bytes 2444754944 2013-07-30-16.38.36.784000+180 I134173F963 LEVEL: Warning PID : 23164 TID : 24244 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : BICA APPHDL : 0-15 APPID: ::1.59834.130730133836 AUTHID : USR1CV82 EDUID : 24244 EDUNAME: db2agent (BICA) FUNCTION: DB2 UDB, SQO Memory Management, SqloMemController::requestMemory, probe:50 MESSAGE : ZRC=0x8B0F0000=-1961951232=SQLO_NOMEM "No Memory Available" DIA8300C A memory heap error has occurred. DATA #1 : String, 28 bytes Attempt to get memory failed DATA #2 : unsigned integer, 8 bytes 2139160576 DATA #3 : unsigned integer, 8 bytes 0 DATA #4 : String, 11 bytes DB-BICA DATA #5 : unsigned integer, 8 bytes 0 DATA #6 : unsigned integer, 8 bytes 0 DATA #7 : unsigned integer, 8 bytes 247660544 DATA #8 : unsigned integer, 8 bytes 2147483648 DATA #9 : unsigned integer, 8 bytes 175964160 Я так понял что изза падений буферпулов(нехватки памяти) неработали и табличные пространства. По искав по форуму решения как запустить ТП - запустил ТП.Смог подключиться к базе и даже сней работать. Но ДБ2 не выделяла памяти(больше 120Мб). Почитав по форуму нашел решение создать другой инстанс и загрузить базу. Но может есть другой способ менее кардинальный? ДБ2,Виндовс 7, РАМ 8ГБ: ============================================================ О среде инструментов управления DB2 ============================================================ Уровень инструментов управления DB2: Идентификатор продукта SQL09071 Идентификатор уровня 08020107 Уровень DB2 v9.7.100.177 Уровень компиляции s091114 PTF IP23029 ============================================================ Комплект разработки Java (JDK): Уровень IBM Corporation 1.6.0 ============================================================ ... |
| 30.07.2013, 18:11 |
No Memory Available
ОлександрСтепанович, ------------------------------ Введенные команды ------------------------------ get db cfg; ------------------------------------------------------------------------------ get db cfg Конфигурация базы данных Выпуск конфигурации базы данных = 0x0d00 Выпуск базы данных = 0x0d00 Территория базы данных = UA Кодовая страница базы данных = 1208 Кодовый набор базы данных = UTF-8 Код страны/региона базы данных = 380 Последовательность упорядочивания базы данных = UCA500R1_LROOT_AN_CX_EX_FX_HX_NX_S2 Альтернативная последовательность слияния (ALT_COLLATE) = Совместимость чисел = OFF Совместимость с Varchar2 = OFF Совместимость данных = OFF Размер страницы базы данных = 32768 Управление динамическими запросами SQL (DYN_QUERY_MGMT) = DISABLE Концентратор операторов (STMT_CONC) = OFF Поддержка поиска для базы данных (DISCOVER_DB) = ENABLE Ограниченный доступ = NO Класс оптимизации запросов по умолчанию (DFT_QUERYOPT) = 5 Уровень параллелизма (DFT_DEGREE) = 1 Продолжение при арифметических ошибках(DFT_SQLMATHWARN) = NO Интервал обновления по умолчанию (DFT_REFRESH_AGE) = 0 Типы обсл. таблиц по умолчанию для опт.(DFT_MTTB_TYPES) = SYSTEM Число хранящихся частых значений (NUM_FREQVALUES) = 10 Число хранимых квантилей (NUM_QUANTILES) = 20 Режим округления для десятичных с плавающей точкой (DECFLT_ROUNDING) = ROUND_HALF_EVEN Отложено резервных копирований = NO Все принятые транзакции записаны на диск = YES Повторов отложено = NO Восстановлений отложено = NO Многостраничное размещение файлов разрешено = YES Состояние сохранения в журнале для восстановления = NO Состояние обработчика пользователя для регистрации = NO Самонастраивающаяся память (SELF_TUNING_MEM) = ON Размер совм.памяти базы данных(4 Кбайт)(DATABASE_MEMORY)= AUTOMATIC(131808) Порог памяти базы данных (DB_MEM_THRESH) = 10 Макс. память списка блокировок (4 Кбайт) (LOCKLIST) = AUTOMATIC(4096) Процент списков блокировки на программу (MAXLOCKS) = AUTOMATIC(60) Размер кэша пакета (4 Кбайт) (PCKCACHESZ) = AUTOMATIC(6478) Порог куч совмест. сортировок (4 Кбайт)(SHEAPTHRES_SHR) = AUTOMATIC(512) Размер кучи списка сортировки (4 Кбайт) (SORTHEAP) = AUTOMATIC(103) Размер кучи базы данных (4 Кбайт) (DBHEAP) = 9446 Размер кэша каталога (4 Кбайта) (CATALOGCACHE_SZ) = 906 Размер буфера журнала (4 Кбайт) (LOGBUFSZ) = 4907 Размер кучи утилит (4 Кбайт) (UTIL_HEAP_SZ) = 54506 Размер пула буферов (страниц) (BUFFPAGE) = 10000 Размер кучи оператора SQL (4 Кбайт) (STMTHEAP) = 4096 Размер кучи программы по умолчанию (4 Кбайт)(APPLHEAPSZ)= 4096 Размер памяти прикладных программ (4 Кбайта) (APPL_MEMORY) = AUTOMATIC(40016) Размер кучи статистики (4 Кбайт) (STAT_HEAP_SZ) = AUTOMATIC(4384) Интервал проверки тупиковых ситуаций (мс) (DLCHKTIME) = 10000 Время ожидание блокировки (сек) (LOCKTIMEOUT) = 20 Предельная доля измененных страниц (CHNGPGS_THRESH) = 80 Число асинхронных чистильщиков страниц (NUM_IOCLEANERS) = AUTOMATIC(1) Число серверов ввода-вывода (NUM_IOSERVERS) = AUTOMATIC(3) Флаг сортировки индекса (INDEXSORT) = YES Флаг обнаружения последовательного чтения (SEQDETECT) = YES Предварит.выборка по умолч. (страниц) (DFT_PREFETCH_SZ) = AUTOMATIC Отслеживать измененные страницы (TRACKMOD) = OFF Число контейнеров по умолчанию = 1 Экстент табл.простр.по умолч. (страниц) (DFT_EXTENT_SZ) = 32 Максимальное число активных программ (MAXAPPLS) = AUTOMATIC(40) Среднее число активных программ (AVG_APPLS) = AUTOMATIC(1) Максим.число открытых файлов БД на программу (MAXFILOP) = 65535 Размер файла журнала (4 Кбайт) (LOGFILSIZ) = 1024 Число первичных файлов журнала (LOGPRIMARY) = 23 Число вторичных файлов журнала (LOGSECOND) = 6 Измененных путей к файлам журналов (NEWLOGPATH) = Путь к файлам журнала = D:\DB2\NODE0000\SQL00001\SQLOGDIR\ Путь журналов переполнения (OVERFLOWLOGPATH) = Путь журналов зеркальной копии (MIRRORLOGPATH) = Первый активный файл журнала = Блокировать журнал при переполн.диска (BLK_LOG_DSK_FUL) = NO Блокировать операции, не занесенные в журнал (BLOCKNONLOGGED) = NO Процент макс.перв.простр.журнала у транзакции(MAX_LOG) = 0 Число акт.файлов журнала на актив.ед.раб. (NUM_LOG_SPAN)= 0 Счетчик принятий для группы (MINCOMMIT) = 1 Процент исправ.файла журнала до мягк.контр.тчк (SOFTMAX)= 920 Сохранение в журнале для восстанов.включено (LOGRETAIN) = OFF Обработчик пользов. для регистрации включен (USEREXIT) = OFF Роль базы данных HADR = STANDARD Имя локального хоста HADR (HADR_LOCAL_HOST) = Имя локальной службы HADR (HADR_LOCAL_SVC) = Имя удаленного хоста HADR (HADR_REMOTE_HOST) = Имя удаленной службы HADR (HADR_REMOTE_SVC) = Имя экземпляра HADR на удал. сервере (HADR_REMOTE_INST) = Срок ожидания HADR (HADR_TIMEOUT) = 120 Режим синхронизации записи в журнал HADR (HADR_SYNCMODE) = NEARSYNC Длительность окна для равноправного HADR (с) (HADR_PEER_WINDOW) = 0 Первый метод архивирования журнала (LOGARCHMETH1) = OFF Опции для logarchmeth1 (LOGARCHOPT1) = Второй метод архивирования журнала (LOGARCHMETH2) = OFF Опции для logarchmeth2 (LOGARCHOPT2) = Путь архива журналов при отказе (FAILARCHPATH) = Число попыток архив.перед решен.об ошибке(NUMARCHRETRY) = 5 Задержка попыток архивирования журнала (с)(ARCHRETRYDELAY) = 20 Опции поставщика (VENDOROPT) = Автоматический перезапуск разрешен (AUTORESTART) = ON Время воссоздания и построение пересоздания индекса (INDEXREC) = SYSTEM (RESTART) Страниц журнала при построении индекса (LOGINDEXBUILD) = OFF Число сеансов loadrec по умолчанию (DFT_LOADREC_SES) = 1 Число резервных копий баз данных (NUM_DB_BACKUPS) = 12 Хранение хронологии для восстанов.(дни)(REC_HIS_RETENTN)= 366 Автоудаление объектов восстановления (AUTO_DEL_REC_OBJ) = OFF Класс управления TSM (TSM_MGMTCLASS) = Имя узла TSM (TSM_NODENAME) = Владелец TSM (TSM_OWNER) = Пароль TSM (TSM_PASSWORD) = Автоматическое обслуживание (AUTO_MAINT) = ON Автоматическое резервное копирование базы данных (AUTO_DB_BACKUP) = OFF Автоматическое обслуживание таблиц (AUTO_TBL_MAINT) = ON Автоматический запуск runstats (AUTO_RUNSTATS) = ON Автоматическая статистика оператора (AUTO_STATS_PROF) = OFF Автоматическое профилирование статистики (AUTO_STATS_PROF) = OFF Автоматическое изменение профиля (AUTO_PROF_UPD) = OFF Автоматическая реорганизация (AUTO_REORG) = ON Автоматическая повторная проверка (AUTO_REVAL) = DISABLED Текущее принятие (CUR_COMMIT) = DISABLED Вывод CHAR при вводе DECIMAL (DEC_TO_CHAR_FMT) = V95 Символьные операции XML включены (ENABLE_XMLCHAR) = YES Интервал сбора WLM (минут) (WLM_COLLECT_INT) = 0 Параметры сбора монитора Показатели требования (MON_REQ_METRICS) = NONE Показатели активности (MON_ACT_METRICS) = NONE Показатели объектов (MON_OBJ_METRICS) = NONE События единиц работы (MON_UOW_DATA) = NONE События истечения сроков блокировок (MON_LOCKTIMEOUT) = NONE События тупиковых ситуаций (MON_DEADLOCK) = WITHOUT_HIST События ожидания блокировок (MON_LOCKWAIT) = NONE Порог событий ожидания блокировок (MON_LW_THRESH) = 4294967295 Число записей в списке пакетов (MON_PKGLIST_SZ) = 32 Уровень предупреждений о блокировках (MON_LCK_MSG_LVL) = 1 SMTP-сервер (SMTP_SERVER) = Флаги условной компиляции SQL (SQL_CCFLAGS) = Актуальные параметры сеанса (SECTION_ACTUALS) = NONE ... |
| 30.07.2013, 18:13 |
No Memory Available
ОлександрСтепанович, Посмотрите DBM CFG и INSTANCE_MEMORY. ... |
| 30.07.2013, 18:51 |
No Memory Available
CawaSPb, Насколько я понял из логов не стартанул "STMM Daemon could not be started". Отключил Самонастраивающаяся память (SELF_TUNING_MEM) и установил вручную Размер совм.памяти базы данных(4 Кбайт)(DATABASE_MEMORY)= 326816, но нечего ето недало! По логу "Failed to allocate the desired database shared memory set. The configured DATABASE_MEMORY plus desired overflow may have exceeded INSTANCE_MEMORY or the maximum shared memory on the system. Attempting to start up with a smaller overflow allowance. Desired database shared memory set size is (bytes): DATA #2 : unsigned integer, 8 bytes 2101133312" Пишет что DATABASE_MEMORY + "переполнение" перевесили INSTANCE_MEMORY. (DATABASE_MEMORY)= 326816 (INSTANCE_MEMORY) = AUTOMATIC(524288) Что ето за переполнение? get db cfg Конфигурация базы данных Выпуск конфигурации базы данных = 0x0d00 Выпуск базы данных = 0x0d00 Территория базы данных = UA Кодовая страница базы данных = 1208 Кодовый набор базы данных = UTF-8 Код страны/региона базы данных = 380 Последовательность упорядочивания базы данных = UCA500R1_LROOT_AN_CX_EX_FX_HX_NX_S2 Альтернативная последовательность слияния (ALT_COLLATE) = Совместимость чисел = OFF Совместимость с Varchar2 = OFF Совместимость данных = OFF Размер страницы базы данных = 32768 Управление динамическими запросами SQL (DYN_QUERY_MGMT) = DISABLE Концентратор операторов (STMT_CONC) = OFF Поддержка поиска для базы данных (DISCOVER_DB) = ENABLE Ограниченный доступ = NO Класс оптимизации запросов по умолчанию (DFT_QUERYOPT) = 5 Уровень параллелизма (DFT_DEGREE) = 1 Продолжение при арифметических ошибках(DFT_SQLMATHWARN) = NO Интервал обновления по умолчанию (DFT_REFRESH_AGE) = 0 Типы обсл. таблиц по умолчанию для опт.(DFT_MTTB_TYPES) = SYSTEM Число хранящихся частых значений (NUM_FREQVALUES) = 10 Число хранимых квантилей (NUM_QUANTILES) = 20 Режим округления для десятичных с плавающей точкой (DECFLT_ROUNDING) = ROUND_HALF_EVEN Отложено резервных копирований = NO Все принятые транзакции записаны на диск = YES Повторов отложено = NO Восстановлений отложено = NO Многостраничное размещение файлов разрешено = YES Состояние сохранения в журнале для восстановления = NO Состояние обработчика пользователя для регистрации = NO Самонастраивающаяся память (SELF_TUNING_MEM) = OFF Размер совм.памяти базы данных(4 Кбайт)(DATABASE_MEMORY)= 326816 Порог памяти базы данных (DB_MEM_THRESH) = 10 Макс. память списка блокировок (4 Кбайт) (LOCKLIST) = AUTOMATIC(4096) Процент списков блокировки на программу (MAXLOCKS) = AUTOMATIC(60) Размер кэша пакета (4 Кбайт) (PCKCACHESZ) = AUTOMATIC(2319) Порог куч совмест. сортировок (4 Кбайт)(SHEAPTHRES_SHR) = AUTOMATIC(512) Размер кучи списка сортировки (4 Кбайт) (SORTHEAP) = AUTOMATIC(103) Размер кучи базы данных (4 Кбайт) (DBHEAP) = 9446 Размер кэша каталога (4 Кбайта) (CATALOGCACHE_SZ) = 906 Размер буфера журнала (4 Кбайт) (LOGBUFSZ) = 4907 Размер кучи утилит (4 Кбайт) (UTIL_HEAP_SZ) = 54506 Размер пула буферов (страниц) (BUFFPAGE) = 10000 Размер кучи оператора SQL (4 Кбайт) (STMTHEAP) = 4096 Размер кучи программы по умолчанию (4 Кбайт)(APPLHEAPSZ)= 4096 Размер памяти прикладных программ (4 Кбайта) (APPL_MEMORY) = AUTOMATIC(40016) Размер кучи статистики (4 Кбайт) (STAT_HEAP_SZ) = AUTOMATIC(4384) Интервал проверки тупиковых ситуаций (мс) (DLCHKTIME) = 10000 Время ожидание блокировки (сек) (LOCKTIMEOUT) = 20 Предельная доля измененных страниц (CHNGPGS_THRESH) = 80 Число асинхронных чистильщиков страниц (NUM_IOCLEANERS) = AUTOMATIC(1) Число серверов ввода-вывода (NUM_IOSERVERS) = AUTOMATIC(3) Флаг сортировки индекса (INDEXSORT) = YES Флаг обнаружения последовательного чтения (SEQDETECT) = YES Предварит.выборка по умолч. (страниц) (DFT_PREFETCH_SZ) = AUTOMATIC Отслеживать измененные страницы (TRACKMOD) = OFF Число контейнеров по умолчанию = 1 Экстент табл.простр.по умолч. (страниц) (DFT_EXTENT_SZ) = 32 Максимальное число активных программ (MAXAPPLS) = AUTOMATIC(40) Среднее число активных программ (AVG_APPLS) = AUTOMATIC(1) Максим.число открытых файлов БД на программу (MAXFILOP) = 65535 Размер файла журнала (4 Кбайт) (LOGFILSIZ) = 1024 Число первичных файлов журнала (LOGPRIMARY) = 23 Число вторичных файлов журнала (LOGSECOND) = 6 Измененных путей к файлам журналов (NEWLOGPATH) = Путь к файлам журнала = D:\DB2\NODE0000\SQL00001\SQLOGDIR\ Путь журналов переполнения (OVERFLOWLOGPATH) = Путь журналов зеркальной копии (MIRRORLOGPATH) = Первый активный файл журнала = Блокировать журнал при переполн.диска (BLK_LOG_DSK_FUL) = NO Блокировать операции, не занесенные в журнал (BLOCKNONLOGGED) = NO Процент макс.перв.простр.журнала у транзакции(MAX_LOG) = 0 Число акт.файлов журнала на актив.ед.раб. (NUM_LOG_SPAN)= 0 Счетчик принятий для группы (MINCOMMIT) = 1 Процент исправ.файла журнала до мягк.контр.тчк (SOFTMAX)= 920 Сохранение в журнале для восстанов.включено (LOGRETAIN) = OFF Обработчик пользов. для регистрации включен (USEREXIT) = OFF Роль базы данных HADR = STANDARD Имя локального хоста HADR (HADR_LOCAL_HOST) = Имя локальной службы HADR (HADR_LOCAL_SVC) = Имя удаленного хоста HADR (HADR_REMOTE_HOST) = Имя удаленной службы HADR (HADR_REMOTE_SVC) = Имя экземпляра HADR на удал. сервере (HADR_REMOTE_INST) = Срок ожидания HADR (HADR_TIMEOUT) = 120 Режим синхронизации записи в журнал HADR (HADR_SYNCMODE) = NEARSYNC Длительность окна для равноправного HADR (с) (HADR_PEER_WINDOW) = 0 Первый метод архивирования журнала (LOGARCHMETH1) = OFF Опции для logarchmeth1 (LOGARCHOPT1) = Второй метод архивирования журнала (LOGARCHMETH2) = OFF Опции для logarchmeth2 (LOGARCHOPT2) = Путь архива журналов при отказе (FAILARCHPATH) = Число попыток архив.перед решен.об ошибке(NUMARCHRETRY) = 5 Задержка попыток архивирования журнала (с)(ARCHRETRYDELAY) = 20 Опции поставщика (VENDOROPT) = Автоматический перезапуск разрешен (AUTORESTART) = ON Время воссоздания и построение пересоздания индекса (INDEXREC) = SYSTEM (RESTART) Страниц журнала при построении индекса (LOGINDEXBUILD) = OFF Число сеансов loadrec по умолчанию (DFT_LOADREC_SES) = 1 Число резервных копий баз данных (NUM_DB_BACKUPS) = 12 Хранение хронологии для восстанов.(дни)(REC_HIS_RETENTN)= 366 Автоудаление объектов восстановления (AUTO_DEL_REC_OBJ) = OFF Класс управления TSM (TSM_MGMTCLASS) = Имя узла TSM (TSM_NODENAME) = Владелец TSM (TSM_OWNER) = Пароль TSM (TSM_PASSWORD) = Автоматическое обслуживание (AUTO_MAINT) = ON Автоматическое резервное копирование базы данных (AUTO_DB_BACKUP) = OFF Автоматическое обслуживание таблиц (AUTO_TBL_MAINT) = ON Автоматический запуск runstats (AUTO_RUNSTATS) = ON Автоматическая статистика оператора (AUTO_STATS_PROF) = OFF Автоматическое профилирование статистики (AUTO_STATS_PROF) = OFF Автоматическое изменение профиля (AUTO_PROF_UPD) = OFF Автоматическая реорганизация (AUTO_REORG) = ON Автоматическая повторная проверка (AUTO_REVAL) = DISABLED Текущее принятие (CUR_COMMIT) = DISABLED Вывод CHAR при вводе DECIMAL (DEC_TO_CHAR_FMT) = V95 Символьные операции XML включены (ENABLE_XMLCHAR) = YES Интервал сбора WLM (минут) (WLM_COLLECT_INT) = 0 Параметры сбора монитора Показатели требования (MON_REQ_METRICS) = NONE Показатели активности (MON_ACT_METRICS) = NONE Показатели объектов (MON_OBJ_METRICS) = NONE События единиц работы (MON_UOW_DATA) = NONE События истечения сроков блокировок (MON_LOCKTIMEOUT) = NONE События тупиковых ситуаций (MON_DEADLOCK) = WITHOUT_HIST События ожидания блокировок (MON_LOCKWAIT) = NONE Порог событий ожидания блокировок (MON_LW_THRESH) = 4294967295 Число записей в списке пакетов (MON_PKGLIST_SZ) = 32 Уровень предупреждений о блокировках (MON_LCK_MSG_LVL) = 1 SMTP-сервер (SMTP_SERVER) = Флаги условной компиляции SQL (SQL_CCFLAGS) = Актуальные параметры сеанса (SECTION_ACTUALS) = NONE get dbm cfg Конфигурация менеджера баз данных Тип узла = Сервер баз данных с локальными и удаленными клиентами Выпуск конфигурации менеджера баз данных = 0x0d00 Максимальное число открытых файлов (MAXTOTFILOP) = 16000 Скорость процессора (миллисекунд/команда) (CPUSPEED) = 1,338309e-007 Макс. число одновременно активных баз данных (NUMDB) = 8 Поддержка системы объединения баз данных (FEDERATED) = NO Имя монитора процессора транзакций (TP_MON_NAME) = Счет оплаты за счет вызываемого по ум.(DFT_ACCOUNT_STR) = Путь установки Java Development Kit (JDK_PATH) = Уровень захвата диагностических сообщений (DIAGLEVEL) = 3 Уровень оповещения (NOTIFYLEVEL) = 3 Каталог данных диагностики (DIAGPATH) = Размер переходящих журналов db2diag и уведомлений (Мбайт) (DIAGSIZE) = 0 Переключатели монитора базы данных по умолчанию Пул буферов (DFT_MON_BUFPOOL) = ON Блокировка (DFT_MON_LOCK) = ON Сортировка (DFT_MON_SORT) = OFF Оператор (DFT_MON_STMT) = OFF Таблица (DFT_MON_TABLE) = OFF Отметка времени (DFT_MON_TIMESTAMP) = ON Единица работы (DFT_MON_UOW) = OFF Наблюдение за работоспособностью экз. и БД (HEALTH_MON) = ON Имя группы SYSADM (SYSADM_GROUP) = DB2ADMNS Имя группы SYSCTRL (SYSCTRL_GROUP) = Имя группы SYSMAINT (SYSMAINT_GROUP) = Имя группы SYSMON (SYSMON_GROUP) = Подключаемый модуль ID пользователя-пароля клиента (CLNT_PW_PLUGIN) = Подключаемый модуль Kerberos клиента (CLNT_KRB_PLUGIN) = IBMkrb5 Подключаемый модуль группы (GROUP_PLUGIN) = Подключаемый модуль GSS для локальной авторизации (LOCAL_GSSPLUGIN) = Режим подключаемых модулей сервера (SRV_PLUGIN_MODE) = UNFENCED Список серверов подключаемых модулей GSS (SRVCON_GSSPLUGIN_LIST) = Подключаемый модуль ID пользователя-пароля сервера (SRVCON_PW_PLUGIN) = Аутентификация соединений сервера (SRVCON_AUTH) = NOT_SPECIFIED Менеджер кластеров (CLUSTER_MGR) = Аутентификация менеджера баз данных (AUTHENTICATION) = SERVER Альтернативная аутентификация (ALTERNATE_AUTH_ENC) = NOT_SPECIFIED Разрешение каталогизации без полномочий(CATALOG_NOAUTH) = NO Доверять всем клиентам (TRUST_ALLCLNTS) = YES Аутентификация доверенного клиента (TRUST_CLNTAUTH) = CLIENT Пропустить аутентификацию на системе объед. (FED_NOAUTH) = NO Путь баз данных по умолчанию (DFTDBPATH) = D: Размер кучи монитора баз данных (4 Кбайт) (MON_HEAP_SZ) = 156 Размер кучи вирт.машины Java (4 Кбайт) (JAVA_HEAP_SZ) = 2048 Размер буфера аудита (4 Кбайт) (AUDIT_BUF_SZ) = 0 Размер совм.памяти экземпляра(4Кбайт) (INSTANCE_MEMORY) = AUTOMATIC(524288) Размер буфера резерв.копир. по ум. (4Кбайт) (BACKBUFSZ) = 1024 Размер буфера восстановлен.по умолч.(4 Кбайт)(RESTBUFSZ)= 1024 Размер стека агента (AGENT_STACK_SZ) = 64 Мин.размер принятой собст.памяти (4 Кбайт)(MIN_PRIV_MEM)= 32 Порог собственной памяти (4 Кбайт) (PRIV_MEM_THRESH) = 20000 Порог кучи сортировки (4 Кбайта) (SHEAPTHRES) = 0 Поддержка кэша каталогов (DIR_CACHE) = YES Размер кучи слоя поддержки программы (4Кбайт)(ASLHEAPSZ)= 15 Макс.разм.блока ввода-вывода реквестера(байт)(RQRIOBLK) = 32767 Размер кучи запроса (4 Кбайт) (QUERY_HEAP_SZ) = 1000 Влияние рабочей нагрузки на утилиты (UTIL_IMPACT_LIM) = 10 Приоритет агентов (AGENTPRI) = SYSTEM Размер пула агентов (NUM_POOLAGENTS) = AUTOMATIC(100) Начальное число агентов в пуле (NUM_INITAGENTS) = 0 Макс. число взаимодействующих агентов (MAX_COORDAGENTS) = AUTOMATIC(200) Макс. число соединений с клиентами (MAX_CONNECTIONS) = AUTOMATIC(MAX_COORDAGENTS) Поддержание изолированных процессов (KEEPFENCED) = YES Число помещенных в пул изолир. процессов (FENCED_POOL) = AUTOMATIC(MAX_COORDAGENTS) Начальное число изолированных процессов(NUM_INITFENCED) = 0 Время воссоздания и построение пересоздания индекса (INDEXREC) = RESTART Имя базы данных менеджера транзакций (TM_DATABASE) = 1ST_CONN Интервал ресинхронизации транзакций(сек)(RESYNC_INTERVAL)= 180 Имя SPM (SPM_NAME) = ADMINIST Размер журнала SPM (SPM_LOG_FILE_SZ) = 256 Предельное число агентов ресинхрониз.SPM(SPM_MAX_RESYNC)= 20 Путь журнала SPM (SPM_LOG_PATH) = Имя рабочей станции NetBIOS (NNAME) = Имя службы TCP/IP (SVCENAME) = db2c_DB2 Режим поиска (DISCOVER) = SEARCH Экземпляр сервера поиска (DISCOVER_INST) = ENABLE Файл базы данных ключей сервера SSL (SSL_SVR_KEYDB) = Файл хранения ключей сервера SSL (SSL_SVR_STASH) = Метка сертификата сервера SSL (SSL_SVR_LABEL) = Имя службы SSL (SSL_SVCENAME) = Спецификации шифра SSL (SSL_CIPHERSPECS) = Версии SSL (SSL_VERSIONS) = Файл базы данных ключей клиента SSL (SSL_CLNT_KEYDB) = Файл хранения ключей клиента SSL (SSL_CLNT_STASH) = Макс. уровень параллелизма запроса (MAX_QUERYDEGREE) = 3 Разрешить внутрираздельный параллелизм (INTRA_PARALLEL) = NO Число внутр.буферов связи (4 Кбайт) (FCM_NUM_BUFFERS) = AUTOMATIC(1024) Число внутренних каналов связи (FCM_NUM_CHANNELS) = AUTOMATIC(512) Срок ожидания db2start/db2stop (мин) (START_STOP_TIME) = 10 ... |
| 31.07.2013, 11:13 |
No Memory Available
ОлександрСтепанович, Здравствуйте. Похоже, что сумма размеров буферных пулов ваших баз превысила предел Express-C редакции. Верните SELF_TUNING_MEM обратно в ON/ Выставьте руками буферы базы BICA в какие-нибудь значения (в страницах) NNN AUTOMATIC так, чтоб они в сумме (и плюс память для другой базы, если вы одновременно 2 базы будете активными держать) не превышали 2GB. Ну и чтоб запас был, т.к. так ещё есть потребители памяти... ... |
| 31.07.2013, 23:27 |
start [/forum/topic.php?desktop=1&fid=43&tid=1601376]: |
49ms |
58ms |
| others: | 247ms |
| total: | 405ms |
