HELP SQL0313N
db2 => insert into test.SES ("DATE_END", "DATE_START", "HOST_NAME", "REMOTE_USER", "HTTP_SESSION_ID") values (?, ?, ?, ?, ?) DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL0313N The number of variables in the EXECUTE statement, the number of variables in the OPEN statement, or the number of arguments in an OPEN statement for a parameterized cursor is not equal to the number of values required. SQLSTATE=07004 как исправить не инсертит я думаю, это лечится установкой значения текущего значения нумератора первичного ключа но как не пойму. ... |
| 12.12.2013, 10:30 |
HELP SQL0313N
[12/12/13 13:06:56:157 MSK] 00000052 SystemErr R insert into ЕУЫЕ.SES ("DATE_END", "DATE_START", "HOST_NAME", "REMOTE_USER", "HTTP_SESSION_ID") values (?, ?, ?, ?, ?) [12/12/13 13:06:56:157 MSK] 00000052 SystemErr R 1970-01-01;2013-12-12 13:06:56.155;10.96.10.13;qweqweqweqweqwe;PWaq9I; [12/12/13 13:31:04:521 MSK] 00000082 SystemErr R com.ibm.websphere.ce.cm.DuplicateKeyException: One or more values in the INSERT statement, UPDATE statement, or foreign key update caused by a DELETE statement are not valid because the primary key, unique constraint or unique index identified by "1" constrains table "TEST1.STAT" from having duplicate values for the index key.. SQLCODE=-803, SQLSTATE=23505, DRIVER=4.11.69 а это ошибка в логе при попытке инсерта ... |
| 12.12.2013, 10:40 |
start [/forum/topic.php?desktop=1&fid=43&tid=1601218]: |
38ms |
23ms |
| others: | 235ms |
| total: | 326ms |
