SQL1092N
народ хелп срочно db2inst1@dm2x:~> id uid=1002(db2inst1) gid=102(db2iadm1) groups=102(db2iadm1),101(dasadm1) db2inst1@dm2x:~> db2start SQL1092N The requested command or operation failed because the user ID does not have the authority to perform the requested command or operation. User ID: "DB2INST1". что случилось я не могу запустить базу прав не хватает это такое в первые... Linux x64 Спасибо. ... |
| 09.06.2014, 13:41 |
SQL1092N
Amiri, что выдает: Код: plaintext ... |
| 09.06.2014, 14:04 |
SQL1092N
db2inst1@dm2x:~> db2set DB2_GRP_LOOKUP=local SQL1092N The requested command or operation failed because the user ID does not have the authority to perform the requested command or operation. User ID: "DB2INST1". db2inst1@dm2x:~> ... |
| 09.06.2014, 14:09 |
SQL1092N
db2inst1@dm2x:~> db2 get dbm cfg | grep -i -E "_group|plugin" SYSADM group name (SYSADM_GROUP) = DB2ADMNS SYSCTRL group name (SYSCTRL_GROUP) = DB2ADMNS SYSMAINT group name (SYSMAINT_GROUP) = SYSDB2 SYSMON group name (SYSMON_GROUP) = SYSDB2 Client Userid-Password Plugin (CLNT_PW_PLUGIN) = Client Kerberos Plugin (CLNT_KRB_PLUGIN) = Group Plugin (GROUP_PLUGIN) = GSS Plugin for Local Authorization (LOCAL_GSSPLUGIN) = Server Plugin Mode (SRV_PLUGIN_MODE) = UNFENCED Server List of GSS Plugins (SRVCON_GSSPLUGIN_LIST) = Server Userid-Password Plugin (SRVCON_PW_PLUGIN) = db2inst1@dm2x:~> ... |
| 09.06.2014, 14:09 |
SQL1092N
нистого упала база и теперь беда со стартом ... |
| 09.06.2014, 14:23 |
SQL1092N
db2inst1@dm2x:~> db2set -all [i] DB2_ATS_ENABLE=YES [i] DB2_DMU_DEFAULT=IMPLICITLYHIDDENINCLUDE [i] DB2COMM=TCPIP [i] DB2CODEPAGE=1251 [i] DB2AUTOSTART=YES [g] DB2_COMPATIBILITY_VECTOR=MYS [g] DB2SYSTEM=dm2x [g] DB2INSTDEF=db2inst1 [g] DB2ADMINSERVER=dasusr1 db2inst1@dm2x:~> db2set DB2_GRP_LOOKUP=LOCAL SQL1092N The requested command or operation failed because the user ID does not have the authority to perform the requested command or operation. User ID: "DB2INST1". ... |
| 09.06.2014, 14:40 |
SQL1092N
Amiri Код: plaintext 1. 2. Надо либо (предпочтительнее): Код: plaintext Потом: Код: plaintext ... |
| 09.06.2014, 14:45 |
start [/forum/topic.php?desktop=1&fid=43&tid=1601061]: |
46ms |
50ms |
| others: | 233ms |
| total: | 373ms |
