Как послать тестовый алерт на почту?
Мы настроили алерты в Db2 по этой инструкции: http://www-01.ibm.com/support/docview.wss?uid=swg21432523 В ящике самое первое письмо: > Subject: Test message from the DB2 Admin Server on GENERATE > > This message is being sent to you as a test of the DB2 Tools notification system. > It indicates that your E-mail address has been entered as a candidate for notification of various events managed by the DB2 Tools. > > Thank you. Я настроил sendmail и поменял хост в настройках: db2 update admin cfg using SMTP_SERVER localhost Как теперь послать тестовое письмо заново? ... |
| 05.02.2015, 21:04:43 |
start [/forum/topic.php?desktop=1&fid=43&tid=1600893]: |
236ms |
25ms |
| others: | 224ms |
| total: | 525ms |
