Непонятки с мониторингом потоков на Message Broker 7.
Блин что-то я не пойму. Есть команда mqsireportflowmonitoring, с ее помощью я создал XML профайл событий для мониторинга. После чего командой mqsichangeflowmonitoring я этот профайл загружаю, причем ничего в нем не меняя, на тот же поток, в логах вижу следующее собщение. Jan 12 17:51:42 server user:warn|warning WebSphere Broker v7007[16384118]: (BROKER.grp)[15679]BIP3918W: Message flow 'myflow' failed to load event sources from configurable service monitoring profile '/home/user/profile.xml'. All event sources for the message flow have been deleted. Monitoring events will not be produced for the message flow. : BROKER.e52f6fdf-4401-0000-0080-eebd4b8f879e: /build/S700_P/src/DataFlowEngine/Monitoring/ImbMonitoringManager.cpp: 1460: ImbMonitoringManager::populateMonitoringProfile: : И в итоге все события имеют статус disabled. Причем, при попытке с помощью команды mqsichangeflowmonitoring разрешить конкретное событие получаю следующее сообщение. BIP2051E: Broker BROKER (UUID a74849c2-3eaf-11e2-9108-000000000000) could not process an internal configuration message to completion, the problem was caused by 'Report : AllFolders : NULL'. The configuration message could not be processed and was rejected. Use the inserts within this message to determine the cause of the problem. Correct the broker's configuration and redeploy using the Message Broker Toolkit, mqsideploy command or a CMP application. Contact your IBM support center if you are unable to resolve the problem. BIP2087E: Broker BROKER was unable to process the internal configuration message. The entire internal configuration message failed to be processed successfully. Use the messages following this message to determine the reasons for the failure. If the problem cannot be resolved after reviewing these messages, contact your IBM Support center. Enabling service trace may help determine the cause of the failure. BIP8036E: Negative response received. This command sends an internal configuration message to the broker, the response received indicated that the internal configuration message was unsuccessful. Check that the WebSphere MQ transport is available. Check the system log for further information. ... |
| 13.01.2015, 10:53:51 |
В общем попытки удалить асоциацию с профайлом не увенчались успехом, пришлось удалить поток и задеплоить его снова. Тогда все снова заработало. ... |
| 14.01.2015, 19:53:42 |
AndrykV, Могла бы Вас заинтересовать наша вакансия? Разработчик Требования к кандидату: • Понимание принципов сервисно-ориентированнной архитектуры (SOА). • Опыт проектирования интерфейсов повторно используемых компонентов (сервисов) • Опыт проектирования/разработки, внедрения интеграционных решений с использованием продуктов IBM WebSphere (в первую очередь IBM WebSphere Message Broker/Integration Bus, IBM WebSphere MQ). • Опыт работы с XML, XSD, разработки модели данных, использование специализированных инструментов для работы с XML-технологиями. • Знание английского на уровне чтения литературы по специальности. • Высшее образование (техническое, математическое). • Приветствуется: o Знание предметной области - банки/финансовые организации; o Опыт работы с одной из промышленных реляционных СУБД, предпочтительно Oracle. Обязанности: • Разработка интеграционных решений в области обмена расчетными документами (SWIFT) • Разработка технических проектов на разработку интеграционных решений. • Разработка технических спецификаций сервисов в соответствии с интеграционными стандартами Банка, включая: - проектирование интерфейса сервисов (WSDL, XSD). Мы предлагаем: • Официальное оформление по ТК РФ • Белая заработная плата (оклад + премии) • Социальный пакет (ДМС, английский язык) • Возможность обучения и сертификации за счет компании • Дисконт-программа от компаний партнеров • Крупные и уникальные проекты в развивающейся компании Пишите на почту: ashabalina@luxoft.com ... |
| 18.03.2015, 15:32:59 |
start [/forum/search_topic.php?author=testz&author_mode=last_topics&do_search=1]: |
60ms |
32ms |
| others: | 618ms |
| total: | 769ms |
