Помогите с 68
Что за бесовая таблица такая S9.ACT ничего ее не берет! хотел обнулить а тут такое ( Lock timeout (sec) (LOCKTIMEOUT) = 30 Max storage for lock list (4KB) (LOCKLIST) = 16384 Percent. of lock lists per application (MAXLOCKS) = 10 db2 => TRUNCATE TABLE S9.ACT IGNORE DELETE TRIGGERS DROP STORAGE IMMEDIATE DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL0911N The current transaction has been rolled back because of a deadlock or timeout. Reason code "68". SQLSTATE=40001 db2 => ALTER TABLE S9.ACT ACTIVATE NOT LOGGED INITIALLY WITH EMPTY TABLE DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL1477N For table "S9.ACT" an object "831" in table space "1" cannot be accessed. SQLSTATE=55019 db2 => TRUNCATE TABLE S9.ACT IGNORE DELETE TRIGGERS DROP STORAGE IMMEDIATE DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL0911N The current transaction has been rolled back because of a deadlock or timeout. Reason code "68". SQLSTATE=40001 db2 => ALTER TABLE S9.ACT ACTIVATE NOT LOGGED INITIALLY DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL1477N For table "S9.ACT" an object "831" in table space "1" cannot be accessed. SQLSTATE=55019 db2 => delete from S9.ACT DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL1477N For table "S9.ACT" an object "831" in table space "1" cannot be accessed. SQLSTATE=55019 db2 => drop table S9.ACT DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL0911N The current transaction has been rolled back because of a deadlock or timeout. Reason code "68". SQLSTATE=40001 db2 => select count(*) from S9.ACT 1 ----------- SQL1477N For table "S9.ACT" an object "831" in table space "1" cannot be accessed. SQLSTATE=55019 db2 => reorg table S9.ACT SQL2216N SQL error "-911" occurred while reorganizing a database table or its indexes. db2 => SET INTEGRITY FOR S9.ACT IMMEDIATE CHECKED DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL0911N The current transaction has been rolled back because of a deadlock or timeout. Reason code "68". SQLSTATE=40001 db2 => ALTER TABLE S9.ACT ACTIVATE NOT LOGGED INITIALLY DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL1477N For table "S9.ACT" an object "831" in table space "1" cannot be accessed. SQLSTATE=55019 Спасибо. ... |
| 10.04.2015, 17:05:47 |
Помогите с 68
db2 => import from /dev/null of del replace into S9.ACT SQL3015N An SQL error "-911" occurred during processing. SQL0911N The current transaction has been rolled back because of a deadlock or timeout. Reason code "68". SQLSTATE=40001 ... |
| 10.04.2015, 17:08:31 |
Помогите с 68
я сделал так иначе не вижу способа.. просто как с этим бороться? db2 => quiesce database immediate force connections DB20000I The QUIESCE DATABASE command completed successfully. db2 => drop table S9.ACT DB20000I The SQL command completed successfully. db2 => unquiesce db DB20000I The UNQUIESCE DATABASE command completed successfully. ... |
| 10.04.2015, 17:11:29 |
Помогите с 68
неуж кто сделал? db2 "LOCK TABLE S9.ACT IN EXCLUSIVE MODE" ... |
| 10.04.2015, 17:15:08 |
Помогите с 68
Amiri, Почитайте вывод команды: Код: plaintext Блокировки на таблицу можно посмотреть так: Код: sql 1. 2. ... |
| 10.04.2015, 18:56:29 |
start [/forum/topic.php?desktop=1&fid=43&tid=1600832]: |
59ms |
42ms |
| others: | 232ms |
| total: | 374ms |
