Информативность логов db2
Добрый вечер. подскажите какую информацию несет данное сообщение появляющееся в db2diag.log: 2015-06-25-16.17.16.003398+180 I123629160A2405 LEVEL: Warning PID : 20250846 TID : 15938 PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : DATABASE APPHDL : 0-49453 APPID: 192.51.21.11.41166.150625131612 AUTHID : db2dash HOSTNAME: hostname2 EDUID : 15938 EDUNAME: db2agent (DEVDWH) 0 FUNCTION: DB2 UDB, base sys utilities, sqeAgent::AgentBreathingPoint, probe:16 CALLSTCK: (Static functions may not be resolved correctly, as they are resolved to the nearest symbol) [0] 0x090000000878A9A8 AgentBreathingPoint__8sqeAgentFi + 0x1CC [1] 0x0900000008C22B88 sqleCheckTimeThreshold__FP11sqkfChannelPv + 0x5C [2] 0x0900000008C22FCC WaitRecvReady__11sqkfChannelFiT1 + 0x354 [3] 0x090000000943688C ReceiveAnyBuffer__11sqkfChannelFPP10sqkfBufferiPi + 0x654 [4] 0x0900000007A9A8A4 sqlkqrcv__FP8SQLKQ_CBP8sqeAgentPiPP10sqkfBufferT3 + 0x4A0 [5] 0x0900000007A9A094 sqlktrcv__FP9sqlri_taoPi + 0xAC [6] 0x0900000007A986D0 sqlkt_unpack_tuple__FP9sqlri_taoPiPbP5sqlcaPUiPUlP8sqeAgent + 0x64C [7] 0x0900000007A9E53C sqlktftc__FP8sqeAgentP9sqlri_taoP5sqlcaPUiPUl + 0x6DC [8] 0x0900000007A958DC sqlritqa__FP8sqlrr_cb + 0x23C [9] 0x09000000086D31C8 sqlriSectInvoke__FP8sqlrr_cbP12sqlri_opparm + 0x34 [10] 0x09000000085F88EC sqlrr_process_fetch_request__FP14db2UCinterface + 0xF08 [11] 0x09000000085F68C4 sqlrr_open__FP14db2UCinterfaceP15db2UCCursorInfo + 0x12E8 [12] 0x09000000085F46EC sqljs_ddm_opnqry__FP14db2UCinterfaceP13sqljDDMObject + 0x1D70 [13] 0x09000000086378B8 sqljsParseRdbAccessed__FP13sqljsDrdaAsCbP13sqljDDMObjectP14db2UCinterface + 0x1AC [14] 0x0900000008637534 .sqljsParse.fdpr.clone.230__FP13sqljsDrdaAsCbP14db2UCinterfaceP8sqeAgentb + 0x56C [15] 0x090000000863268C @73@sqljsSqlam__FP14db2UCinterfaceP8sqeAgentb + 0x27C [16] 0x0900000008024924 @73@sqljsDriveRequests__FP8sqeAgentP14db2UCconHandle + 0xB4 [17] 0x090000000802537C @73@sqljsDrdaAsInnerDriver__FP18SQLCC_INITSTRUCT_Tb + 0x558 [18] 0x09000000080245F0 sqljsDrdaAsDriver__FP18SQLCC_INITSTRUCT_T + 0x21C [19] 0x090000000834E0FC RunEDU__8sqeAgentFv + 0x584 [20] 0x090000000834A454 EDUDriver__9sqzEDUObjFv + 0x13C [21] 0x090000000834A2DC sqlzRunEDU__FPcUi + 0x10 [22] 0x0900000008357248 sqloEDUEntry + 0x264 [23] 0x09000000011E3E10 _pthread_body + 0xF0 [24] 0xFFFFFFFFFFFFFFFC ?unknown + 0xFFFFFFFF Спасибо. ... |
| 25.06.2015, 16:25:22 |
Amiri, Добрый вечер. Для вас - практически никакую. Это трейс показывающий, где именно обнаружен неожиданный разрыв соединения со стороны клиента. ... |
| 25.06.2015, 17:38:15 |
start [/forum/topic.php?desktop=1&fid=43&tid=1600780]: |
189ms |
38ms |
| others: | 206ms |
| total: | 470ms |
