Задача: в ddl файле set terminator на ;
В чем здесь ошибка? #more test.dll connect to KTC3 --#set terminator";" select * from KONTO; select * from MANDANT #Result: Database Connection Information Database server = DB2/LINUXZ64 9.7.9 SQL authorization ID = DB2INST1 Local database alias = KTC3 SQL0104N An unexpected token ";" was found following "select * from KONTO". Expected tokens may include: "END-OF-STATEMENT". SQLSTATE=42601 MANDANT NAME_1 NAME_2 BLZ BIC BUCHUNGSTAG STATUS STATUSINFORMATION CREATETIME UPDATETIME BENUTZERKENNUNG ------- ---------------------------------------- ---------------------------------------- -------- ----------- ----------- ------------ -------- ------------------------------------------------------------------------------------------------------------------------------ ------------------------ --------------------- --------------------- --------------- 0 record(s) selected. ... |
| 31.07.2015, 12:52:22 |
ddl конечно ... |
| 31.07.2015, 12:53:08 |
-_Михаил_-, Код: plaintext 1. 2. 3. ... |
| 31.07.2015, 13:06:35 |
start [/forum/topic.php?desktop=1&fid=43&tid=1600758]: |
39ms |
40ms |
| others: | 210ms |
| total: | 322ms |
