LEVEL: Error
Добрый день. подскажите что это и как с ним бороться? 2015-08-20-15.26.41.412742+180 I433786A864 LEVEL: Error PID : 16580720 TID : 1 PROC : db2fm INSTANCE: db2inst1 NODE : 000 HOSTNAME: hostname EDUID : 1 FUNCTION: DB2 Common, Fault Monitor Facility, db2fm, probe:170 MESSAGE : ECF=0x90000349=-1879047351=ECF_FM_FAIL_TO_STOP_GCF_FM Failed to stop the GCF fm module CALLED : DB2 Common, Generic Control Facility, GcfCaller::stop DATA #1 : signed integer, 8 bytes 1 DATA #2 : unsigned integer, 8 bytes 0 CALLSTCK: (Static functions may not be resolved correctly, as they are resolved to the nearest symbol) [0] 0x0900000003730150 pdOSSeLoggingCallback + 0xC0 [1] 0x09000000055F6224 oss_log__FP9OSSLogFacUiN32UlN26iPPc + 0x1C4 [2] 0x09000000055F65DC ossLogRC + 0x9C [3] 0x0000000100003A90 main + 0x2590 [4] 0x00000001000002B0 __start + 0x70 2015-08-20-15.26.52.989652+180 I434651A837 LEVEL: Error PID : 23003180 TID : 1 PROC : db2fm INSTANCE: db2inst1 NODE : 000 HOSTNAME: hostname EDUID : 1 FUNCTION: DB2 Common, Generic Control Facility, gcf_stop, probe:60 MESSAGE : ECF=0x90000390=-1879047280=ECF_FM_INVALID_PROCESS_ID Invalid process id CALLSTCK: (Static functions may not be resolved correctly, as they are resolved to the nearest symbol) [0] 0x0900000003730150 pdOSSeLoggingCallback + 0xC0 [1] 0x09000000055F6224 oss_log__FP9OSSLogFacUiN32UlN26iPPc + 0x1C4 [2] 0x09000000055F5FE4 ossLog + 0x84 [3] 0x09000000016A0580 gcf_stop + 0x740 [4] 0x0900000001690130 stop__9GcfCallerFP12GCF_PartInfoUlP11GCF_RetInfo + 0x1D0 [5] 0x0000000100003A10 main + 0x2510 [6] 0x00000001000002B0 __start + 0x70 2015-08-20-15.26.52.990868+180 I435489A864 LEVEL: Error PID : 23003180 TID : 1 PROC : db2fm INSTANCE: db2inst1 NODE : 000 HOSTNAME: hostname EDUID : 1 FUNCTION: DB2 Common, Fault Monitor Facility, db2fm, probe:170 MESSAGE : ECF=0x90000349=-1879047351=ECF_FM_FAIL_TO_STOP_GCF_FM Failed to stop the GCF fm module CALLED : DB2 Common, Generic Control Facility, GcfCaller::stop DATA #1 : signed integer, 8 bytes 1 DATA #2 : unsigned integer, 8 bytes 0 CALLSTCK: (Static functions may not be resolved correctly, as they are resolved to the nearest symbol) [0] 0x0900000003730150 pdOSSeLoggingCallback + 0xC0 [1] 0x09000000055F6224 oss_log__FP9OSSLogFacUiN32UlN26iPPc + 0x1C4 [2] 0x09000000055F65DC ossLogRC + 0x9C [3] 0x0000000100003A90 main + 0x2590 [4] 0x00000001000002B0 __start + 0x70 Спасибо. ... |
| 20.08.2015, 15:39:48 |
start [/forum/topic.php?desktop=1&fid=43&tid=1600746]: |
65ms |
35ms |
| others: | 195ms |
| total: | 332ms |
