Very slow INSERTs
Доброе утро. Имеет место быть subj. создаю таблицу при вставке 70к записей время вставки занимает более 4 часов. почему так происходит. -- а также следующее: select count(*) from SET.TXN 1 ----------- 70241 1 record(s) selected. db2 => INSERT INTO "SET"."TXN" ("ACG_TXN_TP_ID", "BRK_COST_AMT", "BRK_COST_CCY_ID", "CR_AU_CST_ID", "CR_AU_ID", "CR_IFRS_ACG_STC_ITM_ID", "CR_NET_CASH_FLOW_AMT", "CR_RAS_ACG_STC_ITM_ID", "DB_AU_CST_ID", "DB_AU_ID", "DB_IFRS_ACG_STC_ITM_ID", "DB_NET_CASH_FLOW_AMT", "DB_RAS_ACG_STC_ITM_ID", "DPRCN_IND", "DVC_ID", "EXCP_CAUS_ID", "EXCP_IMP_ID", "EXG_RATE", "MSR_PRD_ID", "NET_CASH_FLOW_AMT", "NET_CASH_FLOW_AMT_DMST", "OPRN_TP", "OU_ID", "PCS_TASK_ID", "PPN_DT", "PPN_TM", "PRIM_AR_ID", "PRIM_CST_ID", "PYMT_DOC_ID", "PYMT_DOC_TP_CODE", "REFR_NBR", "RQS_CMM_ID", "RQS_CNL_ID", "SETL_CNL_ID", "SRC_STM_ID", "SSPCS_EV_GRP_ID", "TM_OF_DAY_TBND_ID", "TXN_BOOK_DT", "TXN_CCY_ID", "TXN_CRT_DT", "TXN_DSC", "TXN_DT", "TXN_ID", "TXN_LCS_TP_ID", "TXN_TM", "TXN_TP_ID", "TXN_VAL_DT", "TXN_VAL_TM") VALUES (17, 5.4647, 26, 29, 70, 66, 9.9844, 83, 43, 83, 42, 10.3590, 9, 'W', 'XIYTLEIAPO', 33, 33, 18.6819, 90, 50.4871, 8.1723, 'P', 92, 46, '2010-05-26', '07:10:08', 20, 83, 89, 'RREWT', 'AGXNEXCRKB', 72, 89, 28, 25, 12, 13, '2004-01-17', 0, '2010-12-30', 'UBZI', '2002-10-20', 68, 98, '13:19:17', 25, '2015-06-25', '19:55:49') получаю следующее: DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL0327N The row cannot be inserted into table "SET.TXN" because it is outside the bounds of the defined data partition ranges. SQLSTATE=22525 CREATE TABLE SET.TXN ( TXN_ID BIGINT NOT NULL, TXN_TP_ID INTEGER, ACG_TXN_TP_ID INTEGER, MSR_PRD_ID SMALLINT, TM_OF_DAY_TBND_ID INTEGER, RQS_CNL_ID INTEGER, SETL_CNL_ID INTEGER, EXCP_CAUS_ID INTEGER, EXCP_IMP_ID INTEGER, RQS_CMM_ID INTEGER, SSPCS_EV_GRP_ID INTEGER, TXN_LCS_TP_ID INTEGER, DB_AU_ID INTEGER, CR_AU_ID INTEGER, DB_AU_CST_ID INTEGER, CR_AU_CST_ID INTEGER, DB_RAS_ACG_STC_ITM_ID INTEGER, CR_RAS_ACG_STC_ITM_ID INTEGER, DB_IFRS_ACG_STC_ITM_ID INTEGER, CR_IFRS_ACG_STC_ITM_ID INTEGER, OU_ID INTEGER, PRIM_CST_ID INTEGER, PRIM_AR_ID INTEGER, PYMT_DOC_ID INTEGER, PYMT_DOC_TP_CODE VARCHAR(10), TXN_CCY_ID INTEGER NOT NULL, DB_NET_CASH_FLOW_AMT DECIMAL(22, 4), CR_NET_CASH_FLOW_AMT DECIMAL(22, 4), NET_CASH_FLOW_AMT DECIMAL(22, 4), NET_CASH_FLOW_AMT_DMST DECIMAL(22, 4), TXN_CRT_DT DATE, TXN_BOOK_DT DATE, TXN_DT DATE, TXN_TM TIME, TXN_VAL_DT DATE, TXN_VAL_TM TIME, DVC_ID VARCHAR(18), TXN_DSC VARCHAR(2000), REFR_NBR VARCHAR(64), EXG_RATE REAL, BRK_COST_AMT DECIMAL(22, 4), BRK_COST_CCY_ID INTEGER, DPRCN_IND CHARACTER(1), PPN_DT DATE NOT NULL, PPN_TM TIME NOT NULL, SRC_STM_ID SMALLINT NOT NULL, PCS_TASK_ID INTEGER NOT NULL, OPRN_TP CHARACTER(1) NOT NULL ) INDEX IN INDEX_L0 PARTITION BY RANGE ( MSR_PRD_ID NULLS LAST, SRC_STM_ID NULLS LAST ) ( PARTITION PART876704 STARTING (8767,4) INCLUSIVE ENDING (8767,4) INCLUSIVE IN DATA_L0 INDEX IN INDEX_L0, PARTITION PART876707 STARTING (8767,7) INCLUSIVE ENDING (8767,7) INCLUSIVE IN DATA_L0 INDEX IN INDEX_L0, PARTITION PART876708 STARTING (8767,8) INCLUSIVE ENDING (8767,8) INCLUSIVE IN DATA_L0 INDEX IN INDEX_L0, PARTITION PART876709 STARTING (8767,9) INCLUSIVE ENDING (8767,9) INCLUSIVE IN DATA_L0 INDEX IN INDEX_L0, PARTITION PART876710 STARTING (8767,10) INCLUSIVE ENDING (8767,10) INCLUSIVE IN DATA_L0 INDEX IN INDEX_L0, PARTITION PART876724 STARTING (8767,24) INCLUSIVE ENDING (8767,24) INCLUSIVE IN DATA_L0 INDEX IN INDEX_L0, PARTITION PART1073909 STARTING (10739,9) INCLUSIVE ENDING (10739,9) INCLUSIVE IN DATA_L0 INDEX IN INDEX_L0 ) DISTRIBUTE BY HASH (TXN_ID) ; ALTER TABLE SET.TXN DATA CAPTURE NONE PCTFREE 0 LOCKSIZE ROW APPEND OFF NOT VOLATILE; ALTER TABLE SET.TXN ADD CONSTRAINT TXN_PK PRIMARY KEY (TXN_ID); ... |
| 03.09.2015, 10:37:27 |
Very slow INSERTs
AmiriДоброе утро. Имеет место быть subj. создаю таблицу при вставке 70к записей время вставки занимает более 4 часов. почему так происходит. -- а также следующее: select count(*) from SET.TXN 1 ----------- 70241 1 record(s) selected. db2 => INSERT INTO "SET"."TXN" ("ACG_TXN_TP_ID", "BRK_COST_AMT", "BRK_COST_CCY_ID", "CR_AU_CST_ID", "CR_AU_ID", "CR_IFRS_ACG_STC_ITM_ID", "CR_NET_CASH_FLOW_AMT", "CR_RAS_ACG_STC_ITM_ID", "DB_AU_CST_ID", "DB_AU_ID", "DB_IFRS_ACG_STC_ITM_ID", "DB_NET_CASH_FLOW_AMT", "DB_RAS_ACG_STC_ITM_ID", "DPRCN_IND", "DVC_ID", "EXCP_CAUS_ID", "EXCP_IMP_ID", "EXG_RATE", "MSR_PRD_ID", "NET_CASH_FLOW_AMT", "NET_CASH_FLOW_AMT_DMST", "OPRN_TP", "OU_ID", "PCS_TASK_ID", "PPN_DT", "PPN_TM", "PRIM_AR_ID", "PRIM_CST_ID", "PYMT_DOC_ID", "PYMT_DOC_TP_CODE", "REFR_NBR", "RQS_CMM_ID", "RQS_CNL_ID", "SETL_CNL_ID", "SRC_STM_ID", "SSPCS_EV_GRP_ID", "TM_OF_DAY_TBND_ID", "TXN_BOOK_DT", "TXN_CCY_ID", "TXN_CRT_DT", "TXN_DSC", "TXN_DT", "TXN_ID", "TXN_LCS_TP_ID", "TXN_TM", "TXN_TP_ID", "TXN_VAL_DT", "TXN_VAL_TM") VALUES (17, 5.4647, 26, 29, 70, 66, 9.9844, 83, 43, 83, 42, 10.3590, 9, 'W', 'XIYTLEIAPO', 33, 33, 18.6819, 90, 50.4871, 8.1723, 'P', 92, 46, '2010-05-26', '07:10:08', 20, 83, 89, 'RREWT', 'AGXNEXCRKB', 72, 89, 28, 25, 12, 13, '2004-01-17', 0, '2010-12-30', 'UBZI', '2002-10-20', 68, 98, '13:19:17', 25, '2015-06-25', '19:55:49') получаю следующее: DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL0327N The row cannot be inserted into table "SET.TXN" because it is outside the bounds of the defined data partition ranges. SQLSTATE=22525 тут понятно за диапазон!!! (не актуально) второй вопрос открыт остается! Спасибо. ... |
| 03.09.2015, 12:34:45 |
Very slow INSERTs
Amiri, Добрый день. MQT, триггеры есть на таблице? План запроса вставки покажите. ... |
| 03.09.2015, 12:43:45 |
Very slow INSERTs
Mark Barinstein, Нет тригеров нет никаких. cut << INSERT INTO SETG.TXN(TXN_CCY_ID,PPN_DT,PPN_TM,PCS_TASK_ID,OPRN_TP,TXN_ID,TXN_TP_ID,ACG_TXN_TP_ID,MSR_PRD_ID,TM_OF_DAY_TBND_ID,RQS_CNL_ID,SETL_CNL_ID,EXCP_CAUS_ID,EXCP_IMP_ID,RQS_CMM_ID,SSPCS_EV_GRP_ID,TXN_LCS_TP_ID,DB_AU_ID,CR_AU_ID,DB_RAS_ACG_STC_ITM_ID,CR_RAS_ACG_STC_ITM_ID,DB_IFRS_ACG_STC_ITM_ID,CR_IFRS_ACG_STC_ITM_ID,OU_ID,PRIM_CST_ID,PRIM_AR_ID,PYMT_DOC_ID,PYMT_DOC_TP_CODE,CR_NET_CASH_FLOW_AMT,DB_NET_CASH_FLOW_AMT,NET_CASH_FLOW_AMT_DMST,TXN_CRT_DT,TXN_BOOK_DT,TXN_DT,TXN_TM,TXN_VAL_DT,TXN_VAL_TM,DVC_ID,TXN_DSC,REFR_NBR,EXG_RATE,BRK_COST_AMT,BRK_COST_CCY_ID,DPRCN_IND,SRC_STM_ID,DB_AU_CST_ID,CR_AU_CST_ID) VALUES(ORCHESTRATE.TXN_CCY_ID,ORCHESTRATE.PPN_DT,ORCHESTRATE.PPN_TM,ORCHESTRATE.PCS_TASK_ID,ORCHESTRATE.OPRN_TP,ORCHESTRATE.TXN_ID,ORCHESTRATE.TXN_TP_ID,ORCHESTRATE.ACG_TXN_TP_ID,ORCHESTRATE.MSR_PRD_ID,ORCHESTRATE.TM_OF_DAY_TBND_ID,ORCHESTRATE.RQS_CNL_ID,ORCHESTRATE.SETL_CNL_ID,ORCHESTRATE.EXCP_CAUS_ID,ORCHESTRATE.EXCP_IMP_ID,ORCHESTRATE.RQS_CMM_ID,ORCHESTRATE.SSPCS_EV_GRP_ID,ORCHESTRATE.TXN_LCS_TP_ID,ORCHESTRATE.DB_AU_ID,ORCHESTRATE.CR_AU_ID,ORCHESTRATE.DB_RAS_ACG_STC_ITM_ID,ORCHESTRATE.CR_RAS_ACG_STC_ITM_ID,ORCHESTRATE.DB_IFRS_ACG_STC_ITM_ID,ORCHESTRATE.CR_IFRS_ACG_STC_ITM_ID,ORCHESTRATE.OU_ID,ORCHESTRATE.PRIM_CST_ID,ORCHESTRATE.PRIM_AR_ID,ORCHESTRATE.PYMT_DOC_ID,ORCHESTRATE.PYMT_DOC_TP_CODE,ORCHESTRATE.CR_NET_CASH_FLOW_AMT,ORCHESTRATE.DB_NET_CASH_FLOW_AMT,ORCHESTRATE.NET_CASH_FLOW_AMT_DMST,ORCHESTRATE.TXN_CRT_DT,ORCHESTRATE.TXN_BOOK_DT,ORCHESTRATE.TXN_DT,ORCHESTRATE.TXN_TM,ORCHESTRATE.TXN_VAL_DT,ORCHESTRATE.TXN_VAL_TM,ORCHESTRATE.DVC_ID,ORCHESTRATE.TXN_DSC,ORCHESTRATE.REFR_NBR,ORCHESTRATE.EXG_RATE,ORCHESTRATE.BRK_COST_AMT,ORCHESTRATE.BRK_COST_CCY_ID,ORCHESTRATE.DPRCN_IND,ORCHESTRATE.SRC_STM_ID,ORCHESTRATE.DB_AU_CST_ID,ORCHESTRATE.CR_AU_CST_ID) ... |
| 03.09.2015, 13:51:49 |
Very slow INSERTs
Amiri, SET.TXN ... |
| 03.09.2015, 13:53:30 |
Very slow INSERTs
Amiri, Не вижу плана запроса... ... |
| 04.09.2015, 10:22:50 |
Very slow INSERTs
Mark Barinstein, а какой план запроса может быть у массового insert? Кажется нашли проблему дело в медленном СХД (там простые SATA диски) Спасибо. ... |
| 04.09.2015, 14:06:25 |
Very slow INSERTs
Amiriа какой план запроса может быть у массового insert?Самый удивительный, если есть зависимые от этой таблицы объекты. ... |
| 04.09.2015, 15:27:33 |
Very slow INSERTs
Amiri, PARTITION BY RANGE ( MSR_PRD_ID NULLS LAST, SRC_STM_ID NULLS LAST ) А скажите, чем вызвано такое партицианирование? я правильно написал это слово? Судя по названиям полей ноги растут из BDW. Как много у вас источноков данных, неужели столько же сколько дат - MSR_PRD...? И MSR_PRD_ID is Null - das ist fantastisch. ... |
| 12.09.2015, 20:11:58 |
start [/forum/topic.php?desktop=1&fid=43&tid=1600735]: |
104ms |
30ms |
| others: | 206ms |
| total: | 383ms |
