DB2 CRITICAL DOWN
добрый день. подскажите причину такого резкого падения DB2 DB2 v10.5.0.4 - AIX LEVEL: Severe Section relink failure: Relink ID 00000000 @ 0A0001000270F2C0 to ID D4B9AACB @ 0A00020036654FE0 ADM14005E The following error occurred: "AppErr". First Occurrence Data Capture (FODC) has been invoked in the following mode: "Automatic". Diagnostic information has been recorded in the Спасибо. ... |
| 17.03.2017, 12:07:40 |
DB2 CRITICAL DOWN
Amiri, Добрый день. Причин может быть несколько, по такой информации не определить. По-хорошему надо отрывать PMR. Ну или хоть несколько соседних записей из db2diag.log рядом с этой и ее саму полность покажите. ... |
| 17.03.2017, 15:29:49 |
DB2 CRITICAL DOWN
Mark Barinstein, SOFTWARE PROGRAM Recommended Actions RERUN THE APPLICATION PROGRAM IF PROBLEM PERSISTS THEN DO THE FOLLOWING CONTACT APPROPRIATE SERVICE REPRESENTATIVE Detail Data SIGNAL NUMBER 11 USER'S PROCESS ID: 3736014 FILE SYSTEM SERIAL NUMBER 14 INODE NUMBER 69760 CORE FILE NAME /db2dump/FODC_Trap_2017-03-17-11.30.00.665683_0000/3736014.000.core/core PROGRAM NAME db2sysc STACK EXECUTION DISABLED 0 COME FROM ADDRESS REGISTER ?? PROCESSOR ID hw_fru_id: 4 hw_cpu_id: 36 ADDITIONAL INFORMATION sqlra_cac D4C sqlra_cac D48 sqlrr_sig C68 glue_poin 58 sqloExecu 5C ?? sqloDumpD 488 ?? Symptom Data REPORTABLE 1 INTERNAL ERROR 0 SYMPTOM CODE PCSS/SPI2 FLDS/db2sysc SIG/11 FLDS/sqlra_cac VALU/d4c FLDS/sqlrr_sig ... |
| 17.03.2017, 15:34:48 |
DB2 CRITICAL DOWN
Mark Barinstein, 2017-03-17-11.30.00.679013+180 E19060924A789 LEVEL: Error PID : 3736014 TID : 82548 PROC : db2sysc 0 EDUID : 82548 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, relation data serv, sqlrr_dump_ffdc, probe:30 MESSAGE : ADM14005E The following error occurred: "AppErr". First Occurrence Data Capture (FODC) has been invoked in the following mode: "Automatic". Diagnostic information has been recorded in the directory named "/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_8254 8_000/". 2017-03-17-11.30.00.680268+180 E19061714A798 LEVEL: Error PID : 3736014 TID : 84301 PROC : db2sysc 0 EDUID : 84301 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, oper system services, sqloEDUCodeTrapHandler, probe:30 MESSAGE : ADM14005E The following error occurred: "AppErr". First Occurrence Data Capture (FODC) has been invoked in the following mode: "Automatic". Diagnostic information has been recorded in the directory named "/db2dump/FODC_AppErr_2017-03-17-11.30.00.671886_3736014_8430 1_000/". MESSAGE : ADM0001C A severe error has occurred. Examine the administration notification log and contact IBM Support if necessary. 2017-03-17-11.30.00.681728+180 I19063098A900 LEVEL: Severe PID : 3736014 TID : 82548 PROC : db2sysc 0 EDUID : 82548 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, relation data serv, sqlrr_dump_ffdc, probe:250 DATA #1 : SQLCA, PD_DB2_TYPE_SQLCA, 136 bytes sqlcaid : SQLCA sqlcabc: 136 sqlcode: -901 sqlerrml: 40 sqlerrmc: Section relink: Section IDs do not match sqlerrp : SQLRI3D2 sqlerrd : (1) 0x00000000 (2) 0x00000000 (3) 0x00000000 (4) 0x00000000 (5) 0xFFFFFDC4 (6) 0x00000000 sqlwarn : (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) sqlstate: 2017-03-17-11.30.00.682123+180 I19063999A658 LEVEL: Severe PID : 3736014 TID : 82548 PROC : db2sysc 0 EDUID : 82548 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, relation data serv, sqlrr_dump_ffdc, probe:275 MESSAGE : MASTER TIME INFO DATA #1 : Hexdump, 32 bytes 0x0A00020115960D30 : 0000 0000 58B1 EA5D 02A3 0000 000A 4FCC ....X..]......O. 0x0A00020115960D40 : 00B4 296A 02D8 24CB 0000 0000 001F 4000 ..)j..$.......@. 2017-03-17-11.30.00.682528+180 I19064658A230 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: MASTER TIME INFO Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.687072+180 E19065790A973 LEVEL: Critical PID : 3736014 TID : 17107 PROC : db2sysc 0 EDUID : 17107 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, SQO Memory Management, sqloDiagnoseFreeBlockFailure, probe:10 MESSAGE : ADM14001C An unexpected and critical error has occurred: "Panic". The instance may have been shutdown as a result. "Automatic" FODC (First Occurrence Data Capture) has been invoked and diagnostic information has been recorded in directory "/db2dump/FODC_Trap_2017-03-17-11.30.00.665683_0000/". Please look in this directory for detailed evidence about what happened and contact IBM support if necessary to diagnose the problem. 2017-03-17-11.30.00.694186+180 I19066764A219 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: SQLCA Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.695249+180 I19066984A559 LEVEL: Severe PID : 3736014 TID : 82548 PROC : db2sysc 0 EDUID : 82548 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, relation data serv, sqlrr_dump_ffdc, probe:400 ... |
| 17.03.2017, 15:41:09 |
DB2 CRITICAL DOWN
Mark Barinstein, ! EDUID : 82548 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, runtime interpreter, sqlriSectRelink, probe:572 DATA #1 : <preformatted> Section relink failure: Relink ID 00000000 @ 0A0001000270F2C0 to ID D4B9AACB @ 0A00020036654FE0 2017-03-17-11.30.00.679013+180 E19060924A789 LEVEL: Error PID : 3736014 TID : 82548 PROC : db2sysc 0 ... |
| 17.03.2017, 15:44:22 |
DB2 CRITICAL DOWN
все в таком духе(( 2017-03-17-11.30.00.695630+180 I19067544A563 LEVEL: Severe PID : 3736014 TID : 82548 PROC : db2sysc 0 EDUID : 82548 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, relation data serv, sqlrr_dump_ffdc, probe:450 MESSAGE : PACKAGE DATA #1 : Hexdump, 11 bytes 0x0A0001002C545FE0 : 5031 3332 3633 3633 3838 37 P1326363887 2017-03-17-11.30.00.696000+180 I19068108A221 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: CREATOR Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.696226+180 I19068330A221 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: PACKAGE Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.696462+180 I19068552A226 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: REQUEST TYPE Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.731689+180 E19068779A2506 LEVEL: Severe PID : 3736014 TID : 17107 PROC : db2sysc 0 EDUID : 17107 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, SQO Memory Management, sqloDiagnoseFreeBlockFailure, probe:999 MESSAGE : Memory validation failure, diagnostic file dumped. DATA #1 : String, 28 bytes Corrupt pool free tree node. DATA #2 : File name, 33 bytes 3736014.17107.mem_diagnostics.txt CALLSTCK: (Static functions may not be resolved correctly, as they are resolved to the nearest symbol) [0] 0x09000000088770D8 diagnoseMemoryCorruptionAndCrash__13SQLO_MEM_POOLFUlCPCcCb + 0x448 [1] 0x090000000AFB3578 MemTreePut__13SQLO_MEM_POOLFP8SMemNodeUlP17SqloChunkSubgroup + 0x88 [2] 0x090000000AF997C8 sqlofmblkEx + 0x274 [3] 0x090000000AF9A6C0 __dt__16sqlrlCatalogScanFv + 0xC0 Standard input [4] 0x09000000098920EC sqlrlcAuthidsFindRolelist__FP8sqlrr_cbP11sqlr_aainfoUlP13SQLO_MEM_POOLPP19sqlrlcRolesRequiredPUlT6T3 + 0x1F8 [5] 0x0900000009892D64 sqlrlcAuthidsFindRolelist__FP8sqlrr_cbP11sqlr_aainfoUlP13SQLO_MEM_POOLPP19sqlrlcRolesRequiredPUlT6T3 + 0x5D8 [6] 0x090000000988F3A0 sqlrlcRequestRolelistsForAuthid__FP8sqlrr_cbP11sqlr_aainfobN23 + 0x278 [7] 0x090000000A681A1C sqlrr_sql_request_pre__FP14db2UCinterfaceUiiP16db2UCprepareInfoP15db2UCCursorInfo + 0x754 [8] 0x090000000A37A87C sqlrr_open__FP14db2UCinterfaceP15db2UCCursorInfo + 0x390 [9] 0x090000000A37A87C sqlrr_open__FP14db2UCinterfaceP15db2UCCursorInfo + 0x390 [10] 0x090000000A4CFD14 sqljsParseRdbAccessed__FP13sqljsDrdaAsCbP13sqljDDMObjectP14db2UCinterface + 0x2DA0 [11] 0x090000000A4DE3EC @72@sqljsSqlam__FP14db2UCinterfaceP8sqeAgentb + 0x7E4 [12] 0x090000000A4DE3EC @72@sqljsSqlam__FP14db2UCinterfaceP8sqeAgentb + 0x7E4 [13] 0x090000000A4DDFE0 @72@sqljsSqlam__FP14db2UCinterfaceP8sqeAgentb + 0x3D8 [14] 0x09000000097A53A4 @72@sqljsDriveRequests__FP8sqeAgentP14db2UCconHandle + 0xA8 [15] 0x09000000097A5EB0 @72@sqljsDrdaAsInnerDriver__FP18SQLCC_INITSTRUCT_Tb + 0x5F4 [16] 0x0900000009E357D0 RunEDU__8sqeAgentFv + 0x48254 [17] 0x0900000009DD44F8 RunEDU__8sqeAgentFv + 0x124 [18] 0x090000000AE9EFD4 EDUDriver__9sqzEDUObjFv + 0x12C [19] 0x0900000009FBD018 sqloEDUEntry + 0x394 [20] 0x0900000000542E10 _pthread_body + 0xF0 [21] 0xFFFFFFFFFFFFFFFC ?unknown + 0xFFFFFFFF 2017-03-17-11.30.00.768481+180 I19071286A229 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: APM COMMON INFO Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.768871+180 I19071516A225 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: CONTEXT MCB Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.769088+180 I19071742A227 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: PACKAGE ENTRY Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.769291+180 I19071970A234 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: CACHED PACKAGE ENTRY Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.769502+180 I19072205A233 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: Recursive dump_sect Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.769722+180 I19072439A228 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: SECTION NUMBER Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.769927+180 I19072668A227 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: SECTION ENTRY Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.770122+180 I19072896A227 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: SIBLING ENTRY Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.770334+180 I19073124A233 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: common section info Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.770543+180 I19073358A231 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: workspace sibling Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.770741+180 I19073590A231 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: workspace mhashcb Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.771055+180 I19073822A660 LEVEL: Severe PID : 3736014 TID : 82548 PROC : db2sysc 0 EDUID : 82548 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, relation data serv, sqlrr_dump_section, probe:25 MESSAGE : MASTER TIME INFO DATA #1 : Hexdump, 32 bytes 0x0A00020115960D30 : 0000 0000 58B1 EA5D 02A3 0000 000A 4FCC ....X..]......O. 0x0A00020115960D40 : 00B4 296A 02D8 24CB 0000 0000 001F 4000 ..)j..$.......@. 2017-03-17-11.30.00.771435+180 I19074483A230 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: MASTER TIME INFO Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.771631+180 I19074714A233 LEVEL: Severe ... |
| 17.03.2017, 15:57:20 |
DB2 CRITICAL DOWN
Причём до этого все хорошо и онлайн бекап прошёл и а 11:30 Все просто упало! ... |
| 17.03.2017, 15:59:02 |
DB2 CRITICAL DOWN
Amiri, Там есть в db2diag.log сообщения типа: MESSAGE : CREATOR ... MESSAGE : PACKAGE ... ? ... |
| 17.03.2017, 16:36:33 |
DB2 CRITICAL DOWN
Amiri 2017-03-17-11.30.00.695630+180 I19067544A563 LEVEL: Severe PID : 3736014 TID : 82548 PROC : db2sysc 0 EDUID : 82548 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, relation data serv, sqlrr_dump_ffdc, probe:450 MESSAGE : PACKAGE DATA #1 : Hexdump, 11 bytes 0x0A0001002C545FE0 : 5031 3332 3633 3633 3838 37 P1326363887 2017-03-17-11.30.00.696000+180 I19068108A221 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: CREATOR Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.696226+180 I19068330A221 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: PACKAGE Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin 2017-03-17-11.30.00.696462+180 I19068552A226 LEVEL: Severe PID:3736014 TID:82548 NODE:000 Title: REQUEST TYPE Dump File:/db2dump/FODC_AppErr_2017-03-17-11.30.00.660471_3736014_82548_000/3736014.82548.000.dump.bin ... |
| 17.03.2017, 16:45:24 |
DB2 CRITICAL DOWN
Amiri, Код: plaintext 1. ... |
| 17.03.2017, 18:05:11 |
DB2 CRITICAL DOWN
Mark Barinstein, В понедельник смогу выполнить. ... |
| 17.03.2017, 20:34:36 |
DB2 CRITICAL DOWN
Mark Barinstein, Добрый день. увы, ничего нет в логе такого рода. $ db2diag -t 2017-03-17-11.29.00:2017-03-17-11.32.00 -g "funcname=sqlrr_dump_ffdc,data:=MESSAGE : CREATOR" $ $ db2diag -t 2017-03-17-11.29.00:2017-03-17-11.32.00 -g "funcname=sqlrr_dump_ffdc,data:=MESSAGE : PACKAGE" $ ... |
| 20.03.2017, 12:12:11 |
DB2 CRITICAL DOWN
Amiri, Добрый день. Рядом с этим: Код: plaintext 1. 2. 3. 4. 5. 6. 7. должно быть похожее, только с: Код: plaintext ... |
| 20.03.2017, 12:32:13 |
DB2 CRITICAL DOWN
Mark Barinstein, 2017-03-17-11.30.00.695249+180 I19066984A559 LEVEL: Severe PID : 3736014 TID : 82548 PROC : db2sysc 0 EDUID : 82548 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, relation data serv, sqlrr_dump_ffdc, probe:400 MESSAGE : CREATOR DATA #1 : Hexdump, 8 bytes 0x0A0001002C545FEB : 5341 5054 4F4F 4C53 SAPTOOLS 2017-03-17-11.30.00.695630+180 I19067544A563 LEVEL: Severe PID : 3736014 TID : 82548 PROC : db2sysc 0 EDUID : 82548 EDUNAME: db2agent (DB) 0 FUNCTION: DB2 UDB, relation data serv, sqlrr_dump_ffdc, probe:450 MESSAGE : PACKAGE DATA #1 : Hexdump, 11 bytes 0x0A0001002C545FE0 : 5031 3332 3633 3633 3838 37 P1326363887 ... |
| 20.03.2017, 13:22:40 |
DB2 CRITICAL DOWN
Так что-же случилось? Все файлы трейсов бинарные и нечитабельны. Как найти причину такого поведения БД db2 ... |
| 21.03.2017, 11:25:17 |
start [/forum/topic.php?desktop=1&fid=43&tid=1600472]: |
186ms |
47ms |
| others: | 215ms |
| total: | 482ms |
