в db2diag такие странные ошибки SQL0444N
Что могло произойти чтоб такое появилось? Спасибо. 2017-06-16-14.45.03.445103+180 I321338A1242 LEVEL: Severe PID : 11272570 TID : 13111 PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : DB1 APPHDL : 0-35 APPID: *LOCAL.db2inst1.170616114506 AUTHID : db2inst1 HOSTNAME: DBSERVER EDUID : 13111 EDUNAME: db2agent (DB1) 0 FUNCTION: DB2 UDB, routine_infrastructure, sqlerRoutineResolveAddress, probe:10 MESSAGE : ZRC=0xFFFFFE44=-444 SQL0444N Routine "" (specific name "") is implemented with code in library or path "", function "" which cannot be accessed. Reason code: "". DATA #1 : SQLCA, PD_DB2_TYPE_SQLCA, 136 bytes sqlcaid : SQLCA sqlcabc: 136 sqlcode: -444 sqlerrml: 70 sqlerrmc: *IAG_HIST PD_GET_DIAG_HIST ...e/db2dbroutext pd_get_diag_hist_v10fp3 6 sqlerrp : SQLERLIB sqlerrd : (1) 0x00000000 (2) 0x00000000 (3) 0x00000000 (4) 0x00000000 (5) 0x00000000 (6) 0x00000000 sqlwarn : (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) sqlstate: 42724 DATA #2 : String, 23 bytes pd_get_diag_hist_v10fp3 DATA #3 : String, 12 bytes db2dbroutext 2017-06-16-14.45.03.733306+180 I322581A1252 LEVEL: Severe PID : 11272570 TID : 15424 PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : DB1 APPHDL : 0-44 APPID: *LOCAL.db2inst1.170616114514 AUTHID : db2inst1 HOSTNAME: DBSERVER EDUID : 15424 EDUNAME: db2agent (DB1) 0 FUNCTION: DB2 UDB, routine_infrastructure, sqlerRoutineResolveAddress, probe:10 MESSAGE : ZRC=0xFFFFFE44=-444 SQL0444N Routine "" (specific name "") is implemented with code in library or path "", function "" which cannot be accessed. Reason code: "". DATA #1 : SQLCA, PD_DB2_TYPE_SQLCA, 136 bytes sqlcaid : SQLCA sqlcabc: 136 sqlcode: -444 sqlerrml: 70 sqlerrmc: *SUBCLASS MON_GET_SERVICE_SUBCLASS ... monGetServiceSubClass_v105fp4 6 sqlerrp : SQLERLIB sqlerrd : (1) 0x00000000 (2) 0x00000000 (3) 0x00000000 (4) 0x00000000 (5) 0x00000000 (6) 0x00000000 sqlwarn : (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) sqlstate: 42724 DATA #2 : String, 29 bytes monGetServiceSubClass_v105fp4 DATA #3 : String, 16 bytes db2dbrouttrusted 2017-06-16-14.45.03.775167+180 I323834A1241 LEVEL: Severe PID : 11272570 TID : 3342 PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : DB1 APPHDL : 0-30 APPID: *LOCAL.db2inst1.170616114502 AUTHID : db2inst1 HOSTNAME: DBSERVER EDUID : 3342 EDUNAME: db2agent (DB1) 0 FUNCTION: DB2 UDB, routine_infrastructure, sqlerRoutineResolveAddress, probe:10 MESSAGE : ZRC=0xFFFFFE44=-444 SQL0444N Routine "" (specific name "") is implemented with code in library or path "", function "" which cannot be accessed. Reason code: "". DATA #1 : SQLCA, PD_DB2_TYPE_SQLCA, 136 bytes sqlcaid : SQLCA sqlcabc: 136 sqlcode: -444 sqlerrml: 70 sqlerrmc: *GET_HADR MON_GET_HADR ...outine/db2dbrouttrusted monGetHadr_v105fp4 6 sqlerrp : SQLERLIB sqlerrd : (1) 0x00000000 (2) 0x00000000 (3) 0x00000000 (4) 0x00000000 (5) 0x00000000 (6) 0x00000000 sqlwarn : (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) sqlstate: 42724 DATA #2 : String, 18 bytes monGetHadr_v105fp4 DATA #3 : String, 16 bytes db2dbrouttrusted 2017-06-16-14.45.04.138249+180 I325076A1249 LEVEL: Severe PID : 11272570 TID : 12340 PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : DB1 APPHDL : 0-32 APPID: *LOCAL.db2inst1.170616114501 AUTHID : db2inst1 HOSTNAME: DBSERVER EDUID : 12340 EDUNAME: db2agent (DB1) 0 FUNCTION: DB2 UDB, routine_infrastructure, sqlerRoutineResolveAddress, probe:10 MESSAGE : ZRC=0xFFFFFE44=-444 SQL0444N Routine "" (specific name "") is implemented with code in library or path "", function "" which cannot be accessed. Reason code: "". DATA #1 : SQLCA, PD_DB2_TYPE_SQLCA, 136 bytes sqlcaid : SQLCA sqlcabc: 136 sqlcode: -444 sqlerrml: 70 sqlerrmc: *CHE_STMT MON_GET_PKG_CACHE_STMT ...usted monGetPkgCacheStmt_v105fp4 6 sqlerrp : SQLERLIB sqlerrd : (1) 0x00000000 (2) 0x00000000 (3) 0x00000000 (4) 0x00000000 (5) 0x00000000 (6) 0x00000000 sqlwarn : (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) sqlstate: 42724 DATA #2 : String, 26 bytes monGetPkgCacheStmt_v105fp4 DATA #3 : String, 16 bytes db2dbrouttrusted ... |
| 16.06.2017, 14:56:27 |
Amiri, Что выдают: db2 "select * from sysibm.sysversions" db2level ... |
| 17.06.2017, 22:44:28 |
Доброе утро. Mark BarinsteinAmiri, Что выдают: db2 "select * from sysibm.sysversions" db2level VERSIONNUMBER VERSION_TIMESTAMP AUTHID VERSIONBUILDLEVEL 10050100 2014-07-30-17.46.14.486991 DB2INST1 s130816 10050400 2015-04-16-10.11.34.774051 DB2INST1 special_32948 # DB21085I This instance or install (instance name, where applicable: "db2inst1") uses "64" bits and DB2 code release "SQL10051" with level identifier "0602010E". Informational tokens are "DB2 v10.5.0.1", "s130816", "IP23519", and Fix Pack "1". Product is installed at "/db2inst1/db2_software". ... |
| 19.06.2017, 09:03:15 |
Amiri, Добрый день. У вас база под FP4, а экземпляр под FP1. Не надо так делать, если не хотите проблем. ... |
| 19.06.2017, 18:48:42 |
Mark Barinstein, Спасибо. Не заметил. ... |
| 20.06.2017, 09:12:02 |
Amiri, Но как такое может быть ? Инсталляция была так ./installFixPack -b DB2DIR И обновить инстанс так DB2DIR/instance/db2iupdt iname ... |
| 20.06.2017, 09:20:25 |
AmiriНо как такое может быть?Восстановили базу из архива, взятого на другой системе? ... |
| 21.06.2017, 23:05:37 |
Mark Barinstein, Да. Именно так. ... |
| 22.06.2017, 08:47:42 |
Код: sql 1. пробовали? ... |
| 24.06.2017, 17:35:45 |
mustaccio, Нет. Я думал процедуры выполненные выше покрывают все действия этой команды по обновлению экземпляра. Просто мне не известен пароль пользователя инстанса. Хожу через sudo. ... |
| 28.06.2017, 12:32:08 |
Amiri, Что выдает из каталога с фикспаком (там где installFixPack)? Код: plaintext ... |
| 28.06.2017, 13:01:41 |
start [/forum/topic.php?desktop=1&fid=43&tid=1600426]: |
183ms |
58ms |
| others: | 201ms |
| total: | 493ms |
