Use the keyFieldsList property of the cursor
hConn=SQLCONNECT('serv') nSet=SQLSETPROP(hConn, "Asynchronous", .F. ) nSet=SQLSETPROP(hConn, "Transactions", 1 ) =SQLEXEC(hConn,"SELECT *FROM plat WHERE plat.reg=9","plat") lSuccess=CURSORSETPROP("SendUpdates", .T.) lSuccess=CURSORSETPROP("Tables", "plat") lSuccess=CURSORSETPROP("UpdateNameList","fiomen plat.fiomen") lSuccess=CURSORSETPROP("WhereType",4) lSuccess=CURSORSETPROP("KeyFieldList","user_s") lSuccess=CURSORSETPROP("UpdatableFieldList","fiomen") BROWSE USE =SQLDISCONN (hConn) Выдает сообщение "No key columns are spec.. for the update table "plat". Use the keyFieldsList property of the cursor" В чем причина, ребята ??? ... |
| 04.11.2003, 17:07 |
/topic/17953&hl=UpdateNameList ... |
| 04.11.2003, 18:05 |
Попробуй вот так lSuccess=CURSORSETPROP("Tables", "dbo.plat") lSuccess=CURSORSETPROP("UpdateNameList","fiomen dbo.plat.fiomen") ... |
| 04.11.2003, 18:15 |
start [/forum/search_topic.php?author=AZTECA&author_mode=last_posts&do_search=1]: |
36ms |
| others: | 642ms |
| total: | 758ms |
