Вопрос по ShellExecute
В программе ставлю код: Declare Long ShellExecute in Shell32 ; Long hWnd, String lpOperation, String lpFile, String lpParameters, String lpDirectory, ; Integer ShowCmd mKod=ShellExecute(0, "open", "fSelect.rar", NULL, "C:\", 1) Какое значение будет у переменной "mKod" если в системе RAR или любая другая нужная система (WORD,EXCEL и т.д.) отсуствует? ... |
| 20.01.2004, 10:15 |
0 The operating system is out of memory or resources. ERROR_FILE_NOT_FOUND The specified file was not found. ERROR_PATH_NOT_FOUND The specified path was not found. ERROR_BAD_FORMAT The .EXE file is invalid (non-Win32 .EXE or error in .EXE image). SE_ERR_ACCESSDENIED The operating system denied access to the specified file. SE_ERR_ASSOCINCOMPLETE The filename association is incomplete or invalid. SE_ERR_DDEBUSY The DDE transaction could not be completed because other DDE transactions were being processed. SE_ERR_DDEFAIL The DDE transaction failed. SE_ERR_DDETIMEOUT The DDE transaction could not be completed because the request timed out. SE_ERR_DLLNOTFOUND The specified dynamic-link library was not found. SE_ERR_FNF The specified file was not found. SE_ERR_NOASSOC There is no application associated with the given filename extension. SE_ERR_OOM There was not enough memory to complete the operation. SE_ERR_PNF The specified path was not found. SE_ERR_SHARE A sharing violation occurred. Что-то из этого, скорее ERROR_FILE_NOT_FOUND, а конкретное значение получить можно в заголовочном файле VC++ или BCB SHELLAPI.H ... |
| 20.01.2004, 10:36 |
start [/forum/topic.php?desktop=1&fid=41&tid=1597297]: |
72ms |
33ms |
| others: | 223ms |
| total: | 366ms |
