Visual FoxPro 9.0 Beta Component Refresh available
Сабж лежит тут Ken Levy has posted the following regarding updates to the public beta:The Visual FoxPro 9.0 Beta Components Refresh download contains a refresh of various components and source code libraries delivered with the public Visual FoxPro 9.0 beta. It addresses issues in these components, adds refinements, and introduces some Visual FoxPro Foundation Class (FFC) classes not previously available. Updates include components and source code for some reporting system components, BROWSER.APP, BUILDER.APP, and ANCHOREDITOR.APP included in XSOURCE update. To apply the new Anchor property builder, simply run AnchorEditor.app once the files have been installed and it will register itself in FoxCode.dbf so that the new Anchor editor will be active when you are selected on the Anchor property in the Property Sheet. ... |
| 21.08.2004, 10:48 |
start [/forum/topic.php?desktop=1&fid=41&tid=1595959]: |
158ms |
31ms |
| others: | 239ms |
| total: | 477ms |
