XMLadapter
Zdrastvuite! Mozet kto znaet. Kak pri formiravanie XML dokumenta palucit UpperCase bukvi v nazvanie poljah. S menja trebuet: - <DirectDebit> <From>HABA</From> <To>HLIZ</To> <Timestamp>20040519180102023</Timestamp> <SequenceNo>14</SequenceNo> <Extension /> , a palucit magu: - <DirectDebit> <from>UDEK</from> <to>HABA</to> <timestamp>20040519180102020</timestamp> <sequenceno>2</sequenceno> <extension /> ... |
| 06.09.2004, 02:42 |
XMLadapter
Zabil dabavit: Close Databases All Local oXMLAdapter As Xmladapter oXMLAdapter = Newobject('XMLAdapter') oXMLAdapter.Unicode= .F. oXMLAdapter.UTF8Encoded= .T. oXMLAdapter.RespectCursorCP= .F. oXMLAdapter.NoCPTrans=.F. oXMLAdapter.XMLSchemaLocation='' oXMLAdapter.XMLName = Strconv("FIDAVISTA",12) Select d.From,d.To,Timestamp,SequenceNo,Extension From xml_banka!directdebit1 d Into Cursor DirectDebit _FileName='BDDR'+Left(DirectDebit.To,4)+Transform(SequenceNo,"@L 999")+'.xml' oXMLAdapter.AddTableSchema('DirectDebit') oXMLTable1 = oXMLAdapter.Tables.Item(1) Select contractno,payref1,payref2,details,ccy,Round(amountrequested,2) amountrequested,Extension; FROM xml_banka!debitrequest1 Into Cursor debitrequest oXMLAdapter.AddTableSchema('DebitRequest') oXMLTable2 = oXMLAdapter.Tables.Item(2) oXMLFields1 = oXMLTable1.Fields.Item(1) * nepomagaet* oXMLFields1.Name = "From" oXMLFields1.Alias = "From" **oXMLFields1.XMLName= "From" %% a tak nelzja oXMLAdapter.ToXML("MyRequest.xml",'', .T.,.T.) ... |
| 06.09.2004, 08:36 |
start [/forum/topic.php?desktop=1&fid=41&tid=1595874]: |
407ms |
29ms |
| others: | 336ms |
| total: | 826ms |
