Enabled
Dobroe den! U menya v Init form takoy kod SELECT table_pr ThisForm.cDel.Enabled = EMPTY(ALIAS('table_pr')) Thisform.cDel.Enabled = .F. Thisform.cDel.Refresh Thisform.Refresh A koqda ya dobavlyu novix zapisey v table_pr xochu chto cDel stal dostupnim. Thisform.cDel.Enabled = .T. A on poprejdemu Enabled.Qde je oshibka? Zarane bloqadaryu. ... |
| 25.11.2005, 13:19:52 |
Enabled
Varread()Dobroe den! U menya v Init form takoy kod SELECT table_pr ThisForm.cDel.Enabled = EMPTY(ALIAS('table_pr')) Thisform.cDel.Enabled = .F. Thisform.cDel.Refresh Thisform.Refresh A koqda ya dobavlyu novix zapisey v table_pr xochu chto cDel stal dostupnim. Thisform.cDel.Enabled = .T. A on poprejdemu Enabled.Qde je oshibka? Zarane bloqadaryu. Как я понимаю на форме cDel это CommadButton. Тогда лучше в Init-е самой кнопки: Код: plaintext 1. 2. 3. 4. Код: plaintext 1. 2. ... |
| 25.11.2005, 13:40:02 |
start [/forum/topic.php?desktop=1&fid=41&tid=1592944]: |
178ms |
45ms |
| others: | 208ms |
| total: | 478ms |
