Filter i View
Estj takoj vopros, dejstvujet li komanda filter to na view. V helpe u menja pro eto nichego ne skazano, no pri zapuske programmi komanda reccount nahodit vse, nefiltrovanije zapisi tozzhe. Pitalsja, do togo kak zapustitj view otfiltrovatj tablicu, view eto po barabanu, nahodit vse zapisi. Ne hochu prosto dopolnitelnije parametri v view vvoditj. esli estj vozmozhnostj otfiltrovatj view bez pomoschi sql, to kak? help ... |
| 03.05.2006, 17:47 |
Filter i View
Chtenije i podschet zapisej idjet srazu posle requery. vot kod: SET FILTER TO ctemp.mode_id=inf_temp[2] IN ctemp REQUERY("cTemp") x=RECCOUNT("cTemp") overall=0 IF x<>0 THEN DECLARE det1(x, 4) SELECT cTemp COPY TO ARRAY det1 FOR x=1 TO RECCOUNT("cTemp") STEP 1 overall=overall+det1[x, 3] ENDFOR endif set filter i requery pitalsja takzhe pomenjatj mestami. Nolj emocij ... |
| 03.05.2006, 18:39 |
Filter i View
SET FILTER TO ALLTRIM(ctemp.mode_id) == inf_temp[2] IN ctemp REQUERY("ctemp") ... |
| 03.05.2006, 18:43 |
Filter i View
Alltrim rabotajet tolko s tekstom. U menja id Integer ... |
| 03.05.2006, 18:45 |
Filter i View
Сразу не заметил вот что значит писать транслитом: Вот HELP The value RECCOUNT( ) returns isn't affected by SET DELETED and SET FILTER. ... |
| 03.05.2006, 18:51 |
Filter i View
hm, jasno. A kakoj-nitj analog eto komandi jestj? ... |
| 05.05.2006, 10:11 |
Filter i View
COUNT [Scope] [FOR lExpression1] [WHILE lExpression2] [TO VarName] [NOOPTIMIZE] ... |
| 05.05.2006, 10:17 |
start [/forum/topic.php?desktop=1&fid=41&tid=1591764]: |
222ms |
26ms |
| others: | 231ms |
| total: | 521ms |
