Вылетает FOX
Добрый день.. Проблема есть, вылетает FoxPro..=( В общем идея такая, что на форме в ините я сначала делаю таблицу (курсор), потом грид привязываю к таблице.. В общем вот инит: Lparameters kto_vyzval Create Cursor zapros ; (Tabula C(30), Lauks C(30), Kriteria C(2), Filtrs C(50), Kriteria5 C(2), OR5 C(50), Kriteria6 C(2), OR6 C(50), Kriteria7 C(2), ; OR7 C(50), Kriteria8 C(2), OR8 C(50), Kriteria9 C(2), OR9 C(50), Kriteria10 C(2), OR10 C(50), Kriteria11 C(2), OR11 C(50), Kriteria12 C(2), ; OR12 C(50), Kriteria13 C(2), OR13 C(50), Kriteria14 C(2), OR14 C(50), Kriteria15 C(2), OR15 C(50), Kriteria16 C(2), OR16 C(50), Kriteria17 C(2), ; OR17 C(50), Kriteria18 C(2), OR18 C(50), Kriteria19 C(2), OR19 C(50), Kriteria20 C(2), OR20 C(50)) Select zapros Thisform.pageframe1.page1.meklet.ColumnCount=6 Thisform.pageframe1.page1.meklet.RecordSource='zapros' Thisform.pageframe1.page1.meklet.column1.ControlSource='zapros.tabula' Thisform.pageframe1.page1.meklet.column1.AddObject("Combo1","COMBOBOX") With Thisform.pageframe1.page1.meklet.column1.Combo1 .Width = 120 .RowSourceType = 0 .ColumnCount = 1 .RowSource="" .Style = 2 .Visible = .T. Endwith Thisform.pageframe1.page1.meklet.column1.CurrentControl='combo1' Thisform.pageframe1.page1.meklet.column1.Sparse=.F. Thisform.pageframe1.page1.meklet.column1.header1.Caption="Tabula" Thisform.pageframe1.page1.meklet.column1.Width=130 Thisform.pageframe1.page1.meklet.column2.ControlSource='zapros.lauks' Thisform.pageframe1.page1.meklet.column2.AddObject("Combo1","COMBOBOX") With Thisform.pageframe1.page1.meklet.column2.Combo1 .Width = 120 .RowSourceType = 0 && Collection .ColumnCount = 1 .RowSource="" .Style = 2 .Visible = .T. Endwith Thisform.pageframe1.page1.meklet.column2.CurrentControl='combo1' Thisform.pageframe1.page1.meklet.column2.Sparse=.F. Thisform.pageframe1.page1.meklet.column2.header1.Caption="Lauks" Thisform.pageframe1.page1.meklet.column2.Width=160 Thisform.pageframe1.page1.meklet.column3.ControlSource='zapros.kriteria' Thisform.pageframe1.page1.meklet.column3.AddObject("Combo1","COMBOBOX") With Thisform.pageframe1.page1.meklet.column3.Combo1 .Width = 40 .RowSourceType = 0 .ColumnCount = 1 .RowSource="" .Style = 2 .Visible = .T. Endwith Thisform.pageframe1.page1.meklet.column3.CurrentControl='combo1' Thisform.pageframe1.page1.meklet.column3.Sparse=.F. Thisform.pageframe1.page1.meklet.column3.header1.Caption="" Thisform.pageframe1.page1.meklet.column3.Width=40 Thisform.pageframe1.page1.meklet.column3.Combo1.AddItem('=') Thisform.pageframe1.page1.meklet.column3.Combo1.AddItem('>') Thisform.pageframe1.page1.meklet.column3.Combo1.AddItem('<') Thisform.pageframe1.page1.meklet.column3.Combo1.AddItem('<>') Thisform.pageframe1.page1.meklet.column3.Combo1.AddItem('<=') Thisform.pageframe1.page1.meklet.column3.Combo1.AddItem('>=') Thisform.pageframe1.page1.meklet.column4.ControlSource='zapros.filtrs' Thisform.pageframe1.page1.meklet.column4.header1.Caption="Filtrs" Thisform.pageframe1.page1.meklet.column4.Width=210 Thisform.pageframe1.page1.meklet.column5.ControlSource='zapros.kriteria5' Thisform.pageframe1.page1.meklet.column5.AddObject("Combo1","COMBOBOX") With Thisform.pageframe1.page1.meklet.column5.Combo1 .Width = 40 .RowSourceType = 0 .ColumnCount = 1 .RowSource="" .Style = 2 .Visible = .T. Endwith Thisform.pageframe1.page1.meklet.column5.CurrentControl='combo1' Thisform.pageframe1.page1.meklet.column5.Sparse=.F. Thisform.pageframe1.page1.meklet.column5.header1.Caption="" Thisform.pageframe1.page1.meklet.column5.Width=40 Thisform.pageframe1.page1.meklet.column5.Combo1.AddItem('=') Thisform.pageframe1.page1.meklet.column5.Combo1.AddItem('>') Thisform.pageframe1.page1.meklet.column5.Combo1.AddItem('<') Thisform.pageframe1.page1.meklet.column5.Combo1.AddItem('<>') Thisform.pageframe1.page1.meklet.column5.Combo1.AddItem('<=') Thisform.pageframe1.page1.meklet.column5.Combo1.AddItem('>=') Thisform.pageframe1.page1.meklet.column6.ControlSource='zapros.or5' Thisform.pageframe1.page1.meklet.column6.header1.Caption="OR..." Thisform.pageframe1.page1.meklet.column6.Width=210 После этого, у меня получается в гриде 6 столбцов которые нормально работают. Мне нужно при изменении последнего столбца, добавлять еще 2, поэтому я пишу на BerforeRowColChange: Lparameters nColIndex If (nColIndex=This.ColumnCount) source=this.Columns(this.ColumnCount).controlsource dot=AT('or',source) s=RIGHT(source, LEN(source)-(dot+1)) d=VAL(s)+1 If (d<10) N=1 Else N=2 ENDIF nam = 'kriteria' + Str(d,N) c_s="zapros." + (nam) co=this.ColumnCount+2 This.ColumnCount=co This.Columns(co-1).ControlSource=c_s This.Columns(co-1).AddObject("Combo1","COMBOBOX") With This.Columns(co-1).Combo1 .Width = 40 .RowSourceType = 0 .ColumnCount = 1 .RowSource="" .Style = 2 .Visible = .T. Endwith This.Columns(co-1).CurrentControl='combo1' This.Columns(co-1).Sparse=.F. This.Columns(co-1).Width=160 This.Columns(co-1).header1.Caption="" This.Columns(co-1).Width=40 This.Columns(co-1).Combo1.AddItem('=') This.Columns(co-1).Combo1.AddItem('>') This.Columns(co-1).Combo1.AddItem('<') This.Columns(co-1).Combo1.AddItem('<>') This.Columns(co-1).Combo1.AddItem('<=') This.Columns(co-1).Combo1.AddItem('>=') nam = 'or' + Str(d,N) c_s="zapros." + (nam) This.Columns(co).ControlSource=c_s This.Columns(co).header1.Caption="OR..." This.Columns(co).Width=210 ENDIF После этого кода Фокс благополучно вылетает с ошибкой: Fatal error: Exception code=C0000005 @ 2/14/2007 4:35:22 PM. Не могу понять в чем дело, помогите пожалуйста.. ... |
| 14.02.2007, 17:48 |
Вылетает FOX
Когда-то про эту ошибку что-то говорил ВладимирМ. Попробуй поищи поиском, может найдешь. ... |
| 15.02.2007, 15:15 |
Вылетает FOX
А не проще сразу добавить эти два столбца и просто скрывать/показывать по условию ... |
| 15.02.2007, 15:30 |
start [/forum/topic.php?desktop=1&fid=41&tid=1589870]: |
67ms |
50ms |
| others: | 227ms |
| total: | 397ms |
