Refresh
Помогте пожалуста, кто знает! Есть форма на которой 3 вкладки PageFrame, на них выводится информция из таблицы. Внизу формы ставлю кнопку передвинутся на одну запись, а как обновить информацию на вкладках? Я использую Refresh, но не выходит. PROCEDURE Obl_Info LOCAL lKod_T, lKod_obl lKod_T = kod_t lKod_obl = kod_obl SYS(2002) FormOblInfo=CREATEOBJECT("Form3", lKod_T, lKod_obl) FormOblInfo.Show(1) DEFINE CLASS Form3 as Form AutoCenter = .T. Height = 500 && Width = 600 ShowWindow = 2 BackColor = RGB(255,250,205) Icon = 'c:\ProjVFP\MainProj\Bmp\flag_ukraine.ico' Name = "FORM3" ********************************************************************************************************************** ADD OBJECT text1 AS textbox WITH ; Name = "Text1" ,; ReadOnly = .T.,; controlsource = "Name_r",; ColorSource = 2,; DisabledBackColor = RGB(255,250,205),; ForeColor = RGB(178,34,34),; BorderStyle = 0 ,; Width = 600,; Height = 30,; Alignment = 2,; FontName = 'Courier New',; FontBold = .T.,; FontSize = 15 ********************************************************************************************************************** ADD OBJECT text2 AS textbox WITH ; Name = "Text2",; ReadOnly = .T.,; ColorSource = 2,; DisabledBackColor = RGB(255,250,205),; ForeColor = RGB(0,139,0),; BorderStyle = 0,; Alignment = 2,; top = 20,; Width = 600,; Height = 25,; FontName = 'Courier New',; FontItalic = .T.,; FontBold = .T.,; FontSize = 12 ********************************************************************************************************************** ADD OBJECT shapeln AS shape WITH ; Name = "shapeln",; SpecialEffect = 0,; top = 50,; left = 5,; Width = 590,; Height = 1 ************************************************************************************************************************ ADD OBJECT pageframe1 AS pageframe WITH ; PageCount = 3,; Top = 60, ; Left = 10, ; Width = 580, ; Height = 380,; Tabs = .T., ; Name = "Pageframe1", ; Themes = .T.,; Page1.Caption = "Ñèìâîë³êà", ; Page1.FontName = 'Courier New',; Page1.FontBold = .T.,; Page1.FontSize = 10,; Page1.ForeColor = RGB(0,0,255),; Page1.Name = "Page1", ; Page2.Caption = "Êàðòà", ; Page2.FontName = 'Courier New',; Page2.FontBold = .T.,; Page2.FontSize = 10,; Page2.ForeColor = RGB(0,0,255),; Page2.Name = "Page2" ,; Page3.Caption = "²íôîðìàö³ÿ",; Page3.FontName = 'Courier New',; Page3.FontBold = .T.,; Page3.FontSize = 10,; Page3.ForeColor = RGB(0,0,255),; Page3.Name = "Page3" ************************************************************************************************************************ ADD OBJECT CmndBtn2 AS CommandButton WITH ; FontBold .T.,; PROCEDURE init PARAMETERS lKod_T, lKod_obl * This.text2.value = kod_t IF SEEK(lKod_T,"Typt") this.text2.controlsource = "typt.name_t" ENDIF With THISFORM.pageframe1 .Page1.AddObject('Image1','image') With .Page1.Image1 .Top = 80 .Left = 20 .pictureval = prapor .Visible = .T. Endwith .Page1.AddObject('Image2','image') WITH .Page1.Image2 .PictureVal = gerb .Left = 320 .Top = 80 .Visible = .T. ENDWITH .Page1.AddObject('Label1','Label') WITH .Page1.Label1 .Caption = 'Ïðàïîð' .Top = 60 .Left = 120 .Width = 60 .Height = 20 .FontName = 'Arial' .FontBold = .T. .FontSize = 12 .ForeColor = RGB(178,34,34) .BackColor = RGB(255, 255, 255) .Visible = .T. .Name = 'Label1' ENDWITH .Page1.AddObject('Label2','Label') WITH .Page1.Label2 .Caption = 'Ãåðá' .Top = 60 .Left = 410 .Width = 60 .Height = 20 .FontName = 'Arial' .FontBold = .T. .FontSize = 12 .ForeColor = RGB(178,34,34) .BackColor = RGB(255, 255, 255) .Visible = .T. .Name = 'Label2' ENDWITH .Page2.AddObject('Image3','image') WITH .Page2.Image3 .Stretch = 1 .pictureval = karta .Width = 580 .Height = 350 .Visible = .T. ENDWITH .Page3.AddObject('Editbox1','EditBox') WITH .Page3.Editbox1 .ControlSource = 'r_info' .Width = 580 .Height = 352 * .BackColor = RGB(255,250,205) .FontName = 'Arial' .FontBold = .T. .FontSize = 12 .Visible = .T. ENDWITH ENDWITH PROCEDURE CmndBtn2.Click SKIP 1 *THISFORM.pageframe1.SetFocus THISFORM.pageframe1.REFRESH ENDDEFINE ... |
| 16.02.2011, 14:43 |
Refresh
Например, так: THISFORM.pageframe1.page1.REFRESH THISFORM.pageframe1.page2.REFRESH и т.д. ....................................................... Также на клик каждой вкладки вешаешь this.refresh, дабы при переходе по вкладкам все на них рефрешилось ... |
| 16.02.2011, 15:15 |
Refresh
igorbik, Не получается , что-то не пойму ... |
| 16.02.2011, 19:14 |
Refresh
Vitaliy Victorovich, что не получается? Рефрешить или скипануть? Какие ошибки вылетают? ... |
| 16.02.2011, 22:06 |
Refresh
Не обновляется вкладка. Дело в втом, что на вкладках я вывожу картинки. Выдается информация, что достигнут конец файла т.е. таблицу она скипает проходит, а информацию на вкладке, когда перешла на следующую запись, не обновляет. ... |
| 17.02.2011, 09:46 |
start [/forum/topic.php?desktop=1&fid=41&tid=1584551]: |
180ms |
31ms |
| others: | 226ms |
| total: | 470ms |
