Функция Additem
Дан код: dddd =getdir() if not EMPTY(dddd) THISFORM.Text12.Value=dddd endif SET PATH TO (dddd) gnDbcnumber = ADIR(mArray,'&dddd\*.txt') && Create array THISFORM.list1.RowsourceType=0 FOR nCount = 1 TO gnDbcnumber && Loop for number of databases *!* ? countfile(nCount,1) && Display database names THISFORM.list1.additem(mArray(nCount,1)) ---"ПРИ КОМПИЛИРОВАНИИ ВЫЛЕТАЕТ ОШИБКА, НЕ НАШЕЛ РЕШЕНИЕ ПРОБЛЕМЫ(((" ENDFOR thisform.refresh SET PATH TO HOME( ) && Set path to Visual FoxPro directory ... |
| 18.02.2014, 08:58 |
Функция Additem
Код: sql 1. ... |
| 18.02.2014, 09:13 |
start [/forum/topic.php?desktop=1&fid=41&tid=1582730]: |
141ms |
| others: | 197ms |
| total: | 386ms |
