Oриентацию страницы на принтер
Подскажите пожалуйста как выставить в программе ориентацию страницы на принтер, не очень удобно каждый раз менять вручную в настройках. у меня файл rtf. ... |
| 21.02.2018, 15:11:55 |
При чем тут RTF ? Отправка на печать как происходит? ... |
| 21.02.2018, 15:41:48 |
oShell = CREATEOBJECT("wscript.shell") oShell.Run("WORDPAD "+_rtfFile+" /p ", 0, .T.) ... |
| 21.02.2018, 16:05:45 |
#DEFINE IDOK 1 #DEFINE IDCANCEL 2 #DEFINE DM_OUT_BUFFER 2 #DEFINE DM_IN_BUFFER 8 #DEFINE DM_IN_PROMPT 4 #DEFINE DM_ORIENTATION 1 #DEFINE DM_PAPERSIZE 2 #DEFINE DM_PAPERLENGTH 4 #DEFINE DM_PAPERWIDTH 8 #DEFINE DMORIENT_PORTRAIT 1 #DEFINE DMORIENT_LANDSCAPE 2 #DEFINE OFFS_ORIENT_FLAG 41 && offset to Orientation flag #DEFINE OFFS_ORIENT_VALUE 45 && offset to Orientation value DO decl PRIVATE hWindow, cPrinter, cDriver, cPort, hPrinter, nBufsize, cDevmode hWindow = GetActiveWindow() STORE "" TO cPrinter, cDriver, cPort DO GetPrnName hPrinter = 0 = OpenPrinter(cPrinter, @hPrinter, 0) IF hPrinter = 0 = MessageB("Could not open default printer. ", 48, "Error") RETURN ENDIF * being called this way the function returns DEVMODE buffer required size nBufsize = DocumentProperties(hWindow, hPrinter, cPrinter,0,0,0) cDevmode = Repli(Chr(0), nBufsize) DO SetOrient WITH DMORIENT_LANDSCAPE DO OpenDialog = ClosePrinter(hPrinter) * end of main PROCEDURE SetOrient(nOrient) * DEVMODE is adjusted programmatically * DM_IN_PROMPT not used -- the dialog window is not shown LOCAL dmFlags * reading printer configuration = DocumentProperties(hWindow, hPrinter, cPrinter,; @cDevmode, 0, DM_OUT_BUFFER) * setting ORIENTATION flag and value dmFlags = buf2word(SUBSTR(cDevmode, OFFS_ORIENT_FLAG, 4)) dmFlags = BitOr(dmFlags, DM_ORIENTATION) cDevmode = STUFF(cDevmode, OFFS_ORIENT_FLAG, 4, num2dword(dmFlags)) cDevmode = STUFF(cDevmode, OFFS_ORIENT_VALUE, 2, num2word(nOrient)) * using modified DEVMODE structure in the next call = DocumentProperties(hWindow, hPrinter, cPrinter,; @cDevmode, @cDevmode, DM_IN_BUFFER+DM_OUT_BUFFER) PROCEDURE OpenDialog * showing printer settings dialog = DocumentProperties(hWindow, hPrinter, cPrinter,; @cDevmode, @cDevmode, DM_IN_PROMPT+DM_IN_BUFFER+DM_OUT_BUFFER) PROCEDURE GetPrnName * retrieves default printer name from the Registry LOCAL lcBuffer, lcPrinter, lcDriver, lcPort lcBuffer = Repli(Chr(0), 120) = GetProfileString("Windows", "Device", ",,,",; @lcBuffer, Len(lcBuffer)) lcBuffer = STRTRAN(lcBuffer, Chr(0), "") DIMEN arrPos[3] arrPos[1] = AT(",", lcBuffer, 1) arrPos[2] = AT(",", lcBuffer, 2) arrPos[3] = Len(lcBuffer) cPrinter = SUBSTR(lcBuffer, 1, arrPos[1]-1) cDriver = SUBSTR(lcBuffer, arrPos[1]+1, arrPos[2]-arrPos[1]-1) cPort = SUBSTR(lcBuffer, arrPos[2]+1, arrPos[3]-arrPos[2]) RELEASE arrPos FUNCTION buf2dword (lcBuffer) RETURN Asc(SUBSTR(lcBuffer, 1,1)) + ; BitLShift(Asc(SUBSTR(lcBuffer, 2,1)), 8) +; BitLShift(Asc(SUBSTR(lcBuffer, 3,1)), 16) +; BitLShift(Asc(SUBSTR(lcBuffer, 4,1)), 24) FUNCTION buf2word (lcBuffer) RETURN Asc(SUBSTR(lcBuffer, 1,1)) + ; Asc(SUBSTR(lcBuffer, 2,1)) * 256 FUNCTION num2dword (lnValue) #DEFINE m0 256 #DEFINE m1 65536 #DEFINE m2 16777216 LOCAL b0, b1, b2, b3 b3 = Int(lnValue/m2) b2 = Int((lnValue - b3*m2)/m1) b1 = Int((lnValue - b3*m2 - b2*m1)/m0) b0 = Mod(lnValue, m0) RETURN Chr(b0)+Chr(b1)+Chr(b2)+Chr(b3) этот код записывает параметры принтера в файл, но не печатает пейзаж : FUNCTION num2word(lnValue) RETURN Chr(MOD(m.lnValue,256)) + CHR(INT(m.lnValue/256)) PROCEDURE decl DECLARE INTEGER OpenPrinter IN winspool.drv; STRING pPrinterName, INTEGER @phPrinter, INTEGER pDefault DECLARE INTEGER GetProfileString IN kernel32; STRING lpApp, STRING lpKey, STRING lpDefault,; STRING @lpReturnedString, INTEGER nSize DECLARE INTEGER ClosePrinter IN winspool.drv INTEGER hPrinter DECLARE INTEGER GetActiveWindow IN user32 DECLARE INTEGER DeleteDC IN gdi32 INTEGER hdc DECLARE INTEGER DocumentProperties IN winspool.drv; INTEGER hWnd, INTEGER hPrinter, STRING pDeviceName,; STRING @pDevModeOutput, STRING @pDevModeInput, INTEGER fMode ... |
| 22.02.2018, 15:27:08 |
start [/forum/topic.php?desktop=1&fid=41&tid=1581819]: |
176ms |
78ms |
| others: | 191ms |
| total: | 484ms |
