CDO Mail Gmail
Парни привет, Столкнулся с проблемой: Есть прилоожение, в ней есть отсылка сообщений на gmail почту. Procedure SendMail PARAMETERS pText, UserName iMsg = CreateObject('CDO.message') iConf = CreateObject("CDO.Configuration") iConf.Load(-1) flds = iConf.Fields With flds .Item([ http://schemas.microsoft.com/cdo/configuration/sendusing%5D)]http://schemas.microsoft.com/cdo/configuration/sendusing]) = 2 &&‘NTLM method .Item([ http://schemas.microsoft.com/cdo/configuration/smtpserver%5D)]http://schemas.microsoft.com/cdo/configuration/smtpserver]) = [smtp.gmail.com] .Item([ http://schemas.microsoft.com/cdo/configuration/smptserverport%5D)]http://schemas.microsoft.com/cdo/configuration/smptserverport]) = 465 .Item([ http://schemas.microsoft.com/cdo/configuration/smtpauthenticate%5D)]http://schemas.microsoft.com/cdo/configuration/smtpauthenticate]) = 1 .Item([ http://schemas.microsoft.com/cdo/configuration/smtpusessl%5D)]http://schemas.microsoft.com/cdo/configuration/smtpusessl]) = .T. .Item([ http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout%5D)]http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout]) = 60 .Item([ http://schemas.microsoft.com/cdo/configuration/sendusing%5D)]http://schemas.microsoft.com/cdo/configuration/sendusing]) = 2 .Item([ http://schemas.microsoft.com/cdo/configuration/sendusername%5D)]http://schemas.microsoft.com/cdo/configuration/sendusername]) = [xxxxxxx_somegoogleaccount@gmail.com] .Item([ http://schemas.microsoft.com/cdo/configuration/sendpassword%5D)]http://schemas.microsoft.com/cdo/configuration/sendpassword]) = [SomeAccountPassword] .Update EndWith With iMsg .Configuration = iConf .To = ALLTRIM(EmailAddress) .From = [terravasabi@gmail.com] .Subject = [Order cancellation: ]+ UserName .HTMLBody = pText .Send EndWith RELEASE iMsg RELEASE iConf На машинке под windows 7 почта ходит без проблем. С машинки под windows 10 вываливается ошибка: cdo.message.1 the transport failed to connect to the server. ПОрты на машиинке открыты 465 и 587 telenet резолвит соединение без проблем. Перепробовал и порт вместо 465 на 587 - та же ошибка - cdo.message.1 the transport failed to connect to the server. Менял .Item([ http://schemas.microsoft.com/cdo/configuration/sendusing%5D)]http://schemas.microsoft.com/cdo/configuration/sendusing]) = 2 на 1 Ругается на какую-то директорию. Выключил полностью файерволы, добавил порты в правила брэндмауэра. Ничего не помогает. Может кто-то сталкивался или знает в чем проблема? Всем спасибо ... |
| 05.12.2018, 12:54:41 |
CDO Mail Gmail
Valerii, Код: sql 1. 2. 3. 4. Разница понятна? ... |
| 05.12.2018, 14:00:02 |
CDO Mail Gmail
Sergey SizovValerii, Код: sql 1. 2. 3. 4. Разница понятна? нет. не очень. ... |
| 05.12.2018, 14:06:10 |
CDO Mail Gmail
Sergey SizovValerii, Код: sql 1. 2. 3. 4. Разница понятна? Я изменил на iMsg.Configuration.Load(-1) результат тот же. Под 7 все работает без нареканий на 10 вылетает ошибка 1429 .... Error Nr: 1429 Error Msg: OLE IDispatch exception code 0 from CDO.Message.1: The transport failed to connect to the server. ... |
| 05.12.2018, 14:10:44 |
CDO Mail Gmail
Sergey SizovValerii, Код: sql 1. 2. 3. 4. Разница понятна? Изменил код согласно твоей логики: iMsg = CreateObject('CDO.message') *iConf = CreateObject("CDO.Configuration") *iConf.Load(-1) *flds = iConf.Fields iMsg.Configuration = CreateObject("CDO.Configuration") iMsg.Configuration.Load(-1) flds = iMsg.Configuration.Fields With flds .Item([ http://schemas.microsoft.com/cdo/configuration/sendusing%5D)]http://schemas.microsoft.com/cdo/configuration/sendusing]) = 2 &&‘NTLM method .Item([ http://schemas.microsoft.com/cdo/configuration/smtpserver%5D)]http://schemas.microsoft.com/cdo/configuration/smtpserver]) = [smtp.gmail.com] .Item([ http://schemas.microsoft.com/cdo/configuration/smptserverport%5D)]http://schemas.microsoft.com/cdo/configuration/smptserverport]) = 465 .Item([ http://schemas.microsoft.com/cdo/configuration/smtpauthenticate%5D)]http://schemas.microsoft.com/cdo/configuration/smtpauthenticate]) = 1 .Item([ http://schemas.microsoft.com/cdo/configuration/smtpusessl%5D)]http://schemas.microsoft.com/cdo/configuration/smtpusessl]) = .T. .Item([ http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout%5D)]http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout]) = 15 .Item([ http://schemas.microsoft.com/cdo/configuration/sendusing%5D)]http://schemas.microsoft.com/cdo/configuration/sendusing]) = 2 .Item([ http://schemas.microsoft.com/cdo/configuration/sendusername%5D)]http://schemas.microsoft.com/cdo/configuration/sendusername]) = [xxxxxxxx@gmail.com] .Item([ http://schemas.microsoft.com/cdo/configuration/sendpassword%5D)]http://schemas.microsoft.com/cdo/configuration/sendpassword]) = [xxxxxxxxxxxx] .Update EndWith * build email parts With iMsg .Configuration = iMsg * .Configuration = iConf .To = ALLTRIM(pEmailAddress) .From = [xxxxxxxxxxxx@gmail.com] .Subject = [Order cancellation: ]+ WaiterName .HTMLBody = pText .Send EndWith RELEASE iMsg RELEASE iConf Посыпались Type Mismatch на вот этом месте .Configuration = iMsg Я уже ничего не могу понять в этой логике. ... |
| 05.12.2018, 14:24:49 |
CDO Mail Gmail
ValeriiSergey SizovValerii, Код: sql 1. 2. 3. 4. Разница понятна? Изменил код согласно твоей логики: iMsg = CreateObject('CDO.message') *iConf = CreateObject("CDO.Configuration") *iConf.Load(-1) *flds = iConf.Fields iMsg.Configuration = CreateObject("CDO.Configuration") iMsg.Configuration.Load(-1) flds = iMsg.Configuration.Fields With flds .Item([ http://schemas.microsoft.com/cdo/configuration/sendusing%5D)]http://schemas.microsoft.com/cdo/configuration/sendusing]) = 2 &&‘NTLM method .Item([ http://schemas.microsoft.com/cdo/configuration/smtpserver%5D)]http://schemas.microsoft.com/cdo/configuration/smtpserver]) = [smtp.gmail.com] .Item([ http://schemas.microsoft.com/cdo/configuration/smptserverport%5D)]http://schemas.microsoft.com/cdo/configuration/smptserverport]) = 465 .Item([ http://schemas.microsoft.com/cdo/configuration/smtpauthenticate%5D)]http://schemas.microsoft.com/cdo/configuration/smtpauthenticate]) = 1 .Item([ http://schemas.microsoft.com/cdo/configuration/smtpusessl%5D)]http://schemas.microsoft.com/cdo/configuration/smtpusessl]) = .T. .Item([ http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout%5D)]http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout]) = 15 .Item([ http://schemas.microsoft.com/cdo/configuration/sendusing%5D)]http://schemas.microsoft.com/cdo/configuration/sendusing]) = 2 .Item([ http://schemas.microsoft.com/cdo/configuration/sendusername%5D)]http://schemas.microsoft.com/cdo/configuration/sendusername]) = [xxxxxxxx@gmail.com] .Item([ http://schemas.microsoft.com/cdo/configuration/sendpassword%5D)]http://schemas.microsoft.com/cdo/configuration/sendpassword]) = [xxxxxxxxxxxx] .Update EndWith * build email parts With iMsg .Configuration = iMsg * .Configuration = iConf .To = ALLTRIM(pEmailAddress) .From = [xxxxxxxxxxxx@gmail.com] .Subject = [Order cancellation: ]+ WaiterName .HTMLBody = pText .Send EndWith RELEASE iMsg RELEASE iConf Посыпались Type Mismatch на вот этом месте .Configuration = iMsg Я уже ничего не могу понять в этой логике. Убрал .Configuration = iMsg так как это повторяет iMsg.Configuration = CreateObject("CDO.Configuration") и пошла снова основная ошибка транспорта. ... |
| 05.12.2018, 14:30:23 |
CDO Mail Gmail
ValeriiValeriiпропущено... Изменил код согласно твоей логики: iMsg = CreateObject('CDO.message') *iConf = CreateObject("CDO.Configuration") *iConf.Load(-1) *flds = iConf.Fields iMsg.Configuration = CreateObject("CDO.Configuration") iMsg.Configuration.Load(-1) flds = iMsg.Configuration.Fields With flds .Item([ http://schemas.microsoft.com/cdo/configuration/sendusing%5D)]http://schemas.microsoft.com/cdo/configuration/sendusing]) = 2 &&‘NTLM method .Item([ http://schemas.microsoft.com/cdo/configuration/smtpserver%5D)]http://schemas.microsoft.com/cdo/configuration/smtpserver]) = [smtp.gmail.com] .Item([ http://schemas.microsoft.com/cdo/configuration/smptserverport%5D)]http://schemas.microsoft.com/cdo/configuration/smptserverport]) = 465 .Item([ http://schemas.microsoft.com/cdo/configuration/smtpauthenticate%5D)]http://schemas.microsoft.com/cdo/configuration/smtpauthenticate]) = 1 .Item([ http://schemas.microsoft.com/cdo/configuration/smtpusessl%5D)]http://schemas.microsoft.com/cdo/configuration/smtpusessl]) = .T. .Item([ http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout%5D)]http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout]) = 15 .Item([ http://schemas.microsoft.com/cdo/configuration/sendusing%5D)]http://schemas.microsoft.com/cdo/configuration/sendusing]) = 2 .Item([ http://schemas.microsoft.com/cdo/configuration/sendusername%5D)]http://schemas.microsoft.com/cdo/configuration/sendusername]) = [xxxxxxxx@gmail.com] .Item([ http://schemas.microsoft.com/cdo/configuration/sendpassword%5D)]http://schemas.microsoft.com/cdo/configuration/sendpassword]) = [xxxxxxxxxxxx] .Update EndWith * build email parts With iMsg .Configuration = iMsg * .Configuration = iConf .To = ALLTRIM(pEmailAddress) .From = [xxxxxxxxxxxx@gmail.com] .Subject = [Order cancellation: ]+ WaiterName .HTMLBody = pText .Send EndWith RELEASE iMsg RELEASE iConf Посыпались Type Mismatch на вот этом месте .Configuration = iMsg Я уже ничего не могу понять в этой логике. Убрал .Configuration = iMsg так как это повторяет iMsg.Configuration = CreateObject("CDO.Configuration") и пошла снова основная ошибка транспорта. Это на уровне связи с smtp сервером TLS, SSL ...... Н а гугле разрешил приложениям соединяться к этому аккаунту , с 7 - все ок. На 10 вот эти грабли. ... |
| 05.12.2018, 14:32:58 |
CDO Mail Gmail
Valerii, наконец-то добрались руки до сей темы. После разрешения на Gmail принимать коннекты от CDO всё совершенно спокойно отправилось. На WIN 10. ... |
| 06.12.2018, 20:44:11 |
start [/forum/topic.php?desktop=1&fid=41&tid=1581714]: |
47ms |
76ms |
| others: | 193ms |
| total: | 365ms |
