if в запросе
подскажите как для IB сделать проветку типа IF, но сразув запросе, по такому же принципу как в MySQL. Спасибо ... |
| 05.01.2003, 18:11:14 |
if в запросе
Только через UDF. Кажется, у меня есть такая dll, там сделана ф-ция "IIF". ... |
| 05.01.2003, 18:53:53 |
if в запросе
Запросто: IIF '(' search_condition ',' value_if_true ',' value_if_false ')'. Это работает под Yaffil ... |
| 08.01.2003, 11:23:07 |
if в запросе
В FB 1.5 есть такое: * New COALESCE internal function (SF #451917). Allow a column value to be calculated by a number of expressions, the first expression returning a non NULL value is returned as the column value. Syntax: COALESCE (value {, value} ... ) Notes: 1. COALESCE (V1, V2) is equivalent to the following case specification: CASE WHEN V1 IS NOT NULL THEN V1 ELSE V2 END 2. COALESCE (V1, V2, ..., Vn), for n >= 3, is equivalent to the following case specification: CASE WHEN V1 IS NOT NULL THEN V1 ELSE COALESCE (V2, ..., Vn) END 3. The function has the same meaning as NVL one in Oracle. Example: SELECT PROJ_NAME AS Projectname, COALESCE(e.FULL_NAME, '[> not assigned <]') AS Employeename FROM PROJECT p LEFT JOIN EMPLOYEE e ON (e.EMP_NO = p.TEAM_LEADER) * New NULLIF internal function (SF #451917). Return a NULL value for a sub-expression if it has a specific value, otherwise return the value of the sub-expression. Syntax: NULLIF (value, value) Note: NULLIF (V1, V2) is equivalent to the following case specification: CASE WHEN V1 = V2 THEN NULL ELSE V1 END Example: UPDATE PRODUCTS SET STOCK = NULLIF(STOCK, 0) * New CASE internal function (SF #451917). Allow the result of a column to be determined by a the results of a case expression. Syntax: <case_specification> = <simple_case> | <searched_case> <simple_case> = CASE value <simple_when_clause> ... [ELSE value] END <simple_when_clause> = WHEN value THEN value <searched_case> = CASE <searched_when_clause> ... [ELSE value] END <searched_when_clause> = WHEN <search_condition> THEN value Note: The function has the same meaning as DECODE one in Oracle. Examples: 1. Simple case: SELECT o.ID, o.Description, CASE o.Status WHEN 1 THEN 'confirmed' WHEN 2 THEN 'in production' WHEN 3 THEN 'ready' WHEN 4 THEN 'shipped' ELSE 'unknown status ''' || o.Status || '''' END FROM Orders o 2. Searched case: SELECT o.ID, o.Description, CASE WHEN (o.Status IS NULL) THEN 'new' WHEN (o.Status = 1) THEN 'confirmed' WHEN (o.Status = 3) THEN 'in production' WHEN (o.Status = 4) THEN 'ready' WHEN (o.Status = 5) THEN 'shipped' ELSE 'unknown status ''' || o.Status || '''' END FROM Orders o ... |
| 08.01.2003, 12:59:54 |
start [/forum/topic.php?desktop=1&fid=40&tid=1580963]: |
80ms |
28ms |
| others: | 225ms |
| total: | 383ms |
