BDE и Dialect 3
Как настроить БДЕ для работы с SQL Dialect 3? ... |
| 09.03.2004, 15:59 |
BDE и Dialect 3
InterBase version support, Dialect 3 features --------------------------------------------- Delphi 7 supports InterBase 6.5. The client version and server version must be the same. Currently, the driver does not support the ARRAY type. To use the new InterBase 6.5 Dialect 3 features in BDE, add an entry to your Windows registry under HKEY_LOCAL_MACHINE\SOFTWARE\Borland\Database Engine \Settings\Drivers\Intrbase\Db Open\SQLDIALECT and set the String Value to "3". When an InterBase alias is created, the new entry will be available in the .CFG file. To use InterBase 5.6, SQLDIALECT can be set to "1" (existing IB aliases which do not have the SQLDIALECT entry default to SQLDIALECT=1 or to the registry setting when the SQLDIALECT entry is added to the registry). InterBase 6.5 implementation note --------------------------------- If you are using a WebSnap application with InterBase 6.5, a local database connection is not recommended. Instead, use a client/server connection specified by a protocol-specific prefix to the path to the database. Examples: Local connection (not recommended): C:\PathTo\Database\DBName.gdb TCP/IP connection on Windows: saturn:C:\PathTo\Database\DBName.gdb TCP/IP connection on UNIX: jupiter:/usr/PathTo/Database/DBName.gdb NetBEUI connection: \\venus\C:\PathTo\Database\DBName.gdb IPX/SPX connection: mars@vol2:\PathTo\Database\DBName.gdb If the WebSnap application is on the same machine as the server, you can use localhost: localhost:C:\PathTo\Database\DBName.gdb INTERBASE driver behavioral difference: --------------------------------------- NUMERIC data type mapping. The dbExpress driver for INTERBASE now maps NUMERIC data types to fldBCD instead of fldINT16, fldINT32, fldFLOAT. dbExpress --------- TSQLDataSet now has DefaultRowsetSize = 20 (Oracle only). To use a different RowSetSize, add the RowSetSize property manually (e.g., "RowsetSize = 200") into dbxconnections.ini, for existing connections, or into dbxdrivers.ini to have the RowSetSize property included in new connections. RowsetSize can also be modified in code, as shown here: "SQLConnection1.Params.Values['RowsetSize'] := '200'" ... |
| 09.03.2004, 16:07 |
start [/forum/topic.php?desktop=1&fid=40&tid=1579075]: |
55ms |
32ms |
| others: | 231ms |
| total: | 347ms |
