no 2 table rows can have duplicate column values
ошибка при обновлении данных: Invalid insert or update value(s): object columns are constrained - no 2 table rows can have duplicate column values. violation of PRIMARY or UNIQUE KEY constraint "PK_CARDS" on table "CARDS". unknown ISC error 335545072. LI-V6.3.1.32609 Firebird 3 при выполнении: MERGE INTO CARDS M USING (SELECT CARDID,BARCODE,CARDON,CARDTYPE,ID,FIO,TEL,TELHOME,CORRECTION,RATING FROM "##CARDS4_LOAD" WHERE :SHORT_DISCOUNT_ = 0 OR (:SHORT_DISCOUNT_ = 1 AND ID > :MODIFY_ AND ID < 99991231)) P ON P.CARDID = M.CARDID WHEN MATCHED THEN UPDATE SET M.BARCODE = P.BARCODE, M.CARDON = P.CARDON, M.CARDTYPE = P.CARDTYPE, M.ID = P.ID, M.FIO = P.FIO, M.TEL = P.TEL, M.TELHOME = P.TELHOME, M.CORRECTION = P.CORRECTION, M.RATING = P.RATING WHEN NOT MATCHED THEN INSERT(CARDID,BARCODE,CARDON,CARDTYPE,ID,FIO,TEL,TELHOME,CORRECTION,RATING) VALUES(P.CARDID,P.BARCODE,P.CARDON,P.CARDTYPE,P.ID,P.FIO,P.TEL,P.TELHOME,P.CORRECTION,P.RATING); с параметрами: SHORT_DISCOUNT_=1 MODIFY_=20161020 хотя в таблицах CARDS и "##CARDS4_LOAD" дублей по CARDID нет проверял так: select cardid,count(*) cnt from "##CARDS_LOAD" group by cardid having count(*)>1 select cardid,count(*) cnt from CARDS group by cardid having count(*)>1 CREATE TABLE CARDS ( CARDID VARCHAR(10) NOT NULL, BARCODE VARCHAR(13), CARDON SMALLINT, CRDDATEON VARCHAR(255), CRDDATEOFF VARCHAR(255), CARDTYPE INTEGER, CLIENT INTEGER, SUMALL NUMERIC(16,2), STAT INTEGER, ID BIGINT DEFAULT 0 NOT NULL, UPDATE_DATE D_DATETIME DEFAULT '30-DEC-1899' NOT NULL, FIO VARCHAR(150), TEL VARCHAR(50), TELHOME VARCHAR(50), CORRECTION INTEGER DEFAULT 0 NOT NULL, RATING INTEGER DEFAULT 0 NOT NULL ); ALTER TABLE CARDS ADD CONSTRAINT PK_CARDS PRIMARY KEY (CARDID); CREATE INDEX CARDS_BARCODE_IDX ON CARDS (BARCODE); CREATE INDEX CARDS_IDX ON CARDS (ID); CREATE INDEX CARDS_IDX1 ON CARDS (STAT, BARCODE); CREATE INDEX CARDS_UPDATE_DATE_IDX ON CARDS (UPDATE_DATE); CREATE TABLE "##CARDS4_LOAD" EXTERNAL 'CARDS4_LOAD.DAT' ( ID D_IDENTITY NOT NULL, CARDID VARCHAR(10) NOT NULL, BARCODE D_BARCODE, CARDON D_BOOLEAN, CRDDATEON D_DATETIME, CRDDATEOFF D_DATETIME, CARDTYPE INTEGER NOT NULL, CLIENT INTEGER, SUMALL D_MONEY, STAT INTEGER, FIO VARCHAR(150), TEL VARCHAR(50), TELHOME VARCHAR(50), CORRECTION INTEGER, RATING INTEGER, EOL CHAR(2) CHARACTER SET OCTETS ); ... |
| 26.10.2016, 15:16 |
someone2ошибка при обновлении данных: Invalid insert or update value(s): object columns are constrained - no 2 table rows can have duplicate column values. violation of PRIMARY or UNIQUE KEY constraint "PK_CARDS" on table "CARDS". unknown ISC error 335545072.Тут должно быть значение ключа, iirc someone2хотя в таблицах CARDS и " ##CARDS4_LOAD " дублей по CARDID нет проверял так: select cardid,count(*) cnt from " ##CARDS_LOAD " group by cardid having count(*)>1Ы ? ... |
| 26.10.2016, 15:21 |
вот блин, спасибо за помощь ... |
| 26.10.2016, 15:29 |
start [/forum/topic.php?desktop=1&fid=40&tid=1561893]: |
184ms |
38ms |
| others: | 237ms |
| total: | 513ms |
