ALTER PROCEDURE: портится русское описание параметра процедуры
Привет. FB2.5.8 CS, charset WIN1251 В некоторых случаях при alter procedure портится описание параметра, если оно (описание) содержит кириллические символы. Удалось получить воспроизводимый пример путем выжимки метаданных из рабочей БД: create domain D_01 as integer; create domain D_02 as varchar(1024); create domain D_03 as varchar(2048); create domain D_04 as varchar(32); create domain D_05 as varchar(100); create domain D_06 as integer default 0 check ( value is null or value in ( 0, 1 ) ); create domain D_07 as varchar(512); create domain D_08 as varchar(1023); create table T01 ( ID D_01 not null, F01 D_08 not null, F02 D_08, F03 D_05, F04 computed by ( F01 || iif ( coalesce(F02, '') = '', '', ' ' || F02 ) || iif ( coalesce( F03, '') = '', '', ' ' || F03 ) ), F05 computed by ( trim( F01 ) || coalesce( ' ' || upper( left( trim( F02 ), 1 ) ) || '.', '' ) || coalesce( ' ' || upper( left( trim( F03 ), 1 ) ) || '.', '' ) ) ); create table T02 ( ID D_01 not null, F01 D_04, F02 D_05, F03 D_05, F04 D_05, F05 D_02, F06 D_05 ); create table T03 ( ID D_01 not null, F01 D_04 not null, F02 D_01, F03 D_07, F04 D_07, F05 D_05, F06 D_05, F07 D_05 ); create table T04 ( ID D_01, F01 D_04 not null, F02 D_01, F03 D_01, F04 D_06 default 1 not null, F05 D_06 default 0 not null, F06 D_06 default 0, F07 D_01 default 0 not null ); create table T05 ( ID D_01, F01 D_08 not null, F02 D_08 ); set term ^ ; create or alter procedure P01 ( I_P01 D_05, I_P02 D_01 = null, I_P03 D_01 = null, I_P04 D_06 = 0 ) as declare variable L_V01 D_01; declare variable L_V02 D_04; declare variable L_V03 D_03; declare variable L_V04 D_05; declare variable L_V05 D_05; declare variable L_V06 D_05; declare variable L_V07 D_07; declare variable L_V08 D_07; begin if ( :I_P01 containing '~AB~' ) then begin for select a.F01, a.F02, a.F04 || ' ' || a.F03 as L_V03, a.F05 as L_V04, a.F06 as L_V05, a.F07 as L_V06 from T03 a join T02 b on ( b.ID = a.F02 ) where not a.F02 is null into :L_V02, :L_V01, :L_V03, :L_V04, :L_V05, :L_V06 do begin if ( coalesce( trim( :L_V05 ), '' ) = '' ) then if ( :L_V06 > '' ) then L_V05 = :L_V06; L_V07 = null; if ( :I_P04 = 1 ) then begin for select b.F02 from T04 a join T05 b on ( b.ID = a.F02 and a.F05 = 0 and a.F06 = 0 and a.F07 = 0 and a.F04 = 1 ) where a.F01 = :L_V02 order by b.F01 into :L_V07 do begin if ( :L_V07 > '' ) then L_V07 = :L_V07 || '^' || :L_V07; else L_V07 = :L_V07; end for select b.F05 from T04 a join T01 b on ( b.ID = a.F03 and a.F05 = 0 and a.F06 = 0 and a.F07 = 0 and a.F04 = 1 ) where a.F01 = :L_V02 order by b.F04 into :L_V07 do begin if (:L_V07 > '') then L_V07 = :L_V07 || '^' || :L_V07; else L_V07 = :L_V07; end end update T02 a set a.F01 = :L_V02, a.F02 = coalesce( :L_V04, a.F02 ), a.F03 = coalesce( :L_V06, a.F03 ), a.F04 = coalesce( :L_V05, a.F04 ), a.F05 = coalesce( :L_V03, a.F05 ), a.F06 = coalesce( :L_V08, a.F06 ) where a.ID = :L_V01; end end end ^ set term ; ^ comment on parameter P01.I_P01 is 'QWR-ЧШЯ'; Сценарий таков: - создаем пустую БД с чарсетом WIN1251 (размер сраницы 16384 ежличо). - выполняем скрипт, который под спойлером; - запрос: Код: sql 1. 2. 3. 4. вернет: Код: sql 1. 2. Теперь выполним alter procedure (текст процедуры не менялся): set term ^ ; create or alter procedure P01 ( I_P01 D_05, I_P02 D_01 = null, I_P03 D_01 = null, I_P04 D_06 = 0 ) as declare variable L_V01 D_01; declare variable L_V02 D_04; declare variable L_V03 D_03; declare variable L_V04 D_05; declare variable L_V05 D_05; declare variable L_V06 D_05; declare variable L_V07 D_07; declare variable L_V08 D_07; begin if ( :I_P01 containing '~AB~' ) then begin for select a.F01, a.F02, a.F04 || ' ' || a.F03 as L_V03, a.F05 as L_V04, a.F06 as L_V05, a.F07 as L_V06 from T03 a join T02 b on ( b.ID = a.F02 ) where not a.F02 is null into :L_V02, :L_V01, :L_V03, :L_V04, :L_V05, :L_V06 do begin if ( coalesce( trim( :L_V05 ), '' ) = '' ) then if ( :L_V06 > '' ) then L_V05 = :L_V06; L_V07 = null; if ( :I_P04 = 1 ) then begin for select b.F02 from T04 a join T05 b on ( b.ID = a.F02 and a.F05 = 0 and a.F06 = 0 and a.F07 = 0 and a.F04 = 1 ) where a.F01 = :L_V02 order by b.F01 into :L_V07 do begin if ( :L_V07 > '' ) then L_V07 = :L_V07 || '^' || :L_V07; else L_V07 = :L_V07; end for select b.F05 from T04 a join T01 b on ( b.ID = a.F03 and a.F05 = 0 and a.F06 = 0 and a.F07 = 0 and a.F04 = 1 ) where a.F01 = :L_V02 order by b.F04 into :L_V07 do begin if (:L_V07 > '') then L_V07 = :L_V07 || '^' || :L_V07; else L_V07 = :L_V07; end end update T02 a set a.F01 = :L_V02, a.F02 = coalesce( :L_V04, a.F02 ), a.F03 = coalesce( :L_V06, a.F03 ), a.F04 = coalesce( :L_V05, a.F04 ), a.F05 = coalesce( :L_V03, a.F05 ), a.F06 = coalesce( :L_V08, a.F06 ) where a.ID = :L_V01; end end end ^ set term ; ^ После этого запрос Код: sql 1. 2. 3. 4. вернет Код: sql 1. 2. Размер RDB$DESCRIPTION увеличился на 3 символа (по количеству кириллических символов - "ЧШЯ"). Запрос Код: sql 1. 2. 3. 4. возвращает "QWR-ЧШЯ^^^", т.е. дескрипшн дополнился тремя ASCIIZ. С уважением, Polesov. ... |
| 25.07.2018, 16:51 |
А ты чарсет коннекта правильно указываешь? В 3.0 воспроизводится? Posted via ActualForum NNTP Server 1.5 ... |
| 25.07.2018, 17:00 |
Dimitry Sibiryakov, чарсет коннекта WIN1251, FB3.0 у меня нету. ... |
| 25.07.2018, 17:01 |
Polesov, его поставить из снапшотов 3 минуты если что ... |
| 25.07.2018, 17:09 |
Симонов Денис, да пока нет нужды - у нас в продакшн 2.5.8 ... |
| 25.07.2018, 17:16 |
start [/forum/topic.php?desktop=1&fid=40&tid=1561031]: |
148ms |
| others: | 204ms |
| total: | 403ms |
