DBGrid and duplicate records after index field changed (FireDAC)
DBGrid is linked to FDTable with CachedUpdates which has two fields as index linked to another table via PART_NO + ITEM_NO pair. This index is also Primary key. I have a big issue when user is trying to modify ITEM_NO with another value then DBGrid is showing more than one record duplicating other one (not edited one). What is going on? How to avoid "virtual" duplication? Thanks, Fred ... |
| 17.05.2019, 23:01 |
I fixed this issue by replacing TFDTable with TFDQuery but bug in TFDTable functionality still there so it needs to be fixed. How to let FireDAC system developer about this bug? ... |
| 18.05.2019, 03:20 |
FredFF, FireDac author - "Dmitry Arefiev" A discussion of FireDac there can be contacted by the author. ... |
| 18.05.2019, 10:41 |
start [/forum/topic.php?desktop=1&fid=40&tid=1560711]: |
51ms |
34ms |
| others: | 235ms |
| total: | 357ms |
