не выводит данные скрипт
Пишу скрипт в поле таблицы базы данных: insert into T_CNT_FRM select distinct t1.ko '' fs spec, 2 as idc, 3 as gr_st, t1.zn as lft, NULL as rt, NULL as delta from frm_data_1 t1 left join frm_data_1 t2 on t1.ko=t2.ko and t1.st=t2.st and t1.s1=t2.s1 and t2.gr=3 where t1.st not in('3','5') and t1.gr=3 and t1.s1<>'0' and t1.zn=0 and t2.zn>0 and t2.zc is NULL; (Раздел 1. Гр.3 стр.2 и 5 > 0) и при запуске в форме ничего не выводит, а другой скрипт написанный уже нормально работает, чтото понять не могу где ошибся insert into T_CNT_FRM select distinct t1.ko, t1.s1 as spec, 7 as idc, 9 as gr_st, t1.zn as lft, NULL as rt, NULL as delta from frm_data_1 t1 left join frm_data_1 t2 on t1.ko=t2.ko and t1.st=t2.st and t1.s1=t2.s1 and t2.gr=9 where t1.st not in('1','2','3','4','5','6','7') and t1.gr=7 and t1.s1<>'0' and t1.zn>0 and t2.zc is NULL; (Раздел 1. Если гр.7 > 0, то гр.9 не может быть пустой) ... |
| 05.07.2020, 09:42 |
start [/forum/topic.php?desktop=1&fid=40&tid=1560303]: |
147ms |
30ms |
| others: | 241ms |
| total: | 460ms |
