Вышел Cache' Managed Provider для .Net
Cache' Managed Provider for .Net is now available as production release software. This component will be available in two ways: - Immediately, as an add-on component that can be downloaded from our Web site for use with Cache' version 5.1. Note that this download consists only of client-side components; no additional Cache' server-side software is required. - Later this year, as an integral part of Cache' 5.2. Key features of the Cache' Managed Provider for .Net include: - High performance native object access with auto generated proxy classes. - Complete relational access via ADO.Net . - 100% managed code implementation, for easy deployment in .Net environments. - Thread safety for use in multi-threaded applications. The is supported on 32-bit Windows systems and requires MS Windows Framework 2.0. (Earlier versions of the .Net Framework are not supported.) An announcement will be made soon regarding the Cache' Managed Provider for .Net for 64-bit Windows systems. For more information or to download the Cache' Managed Provider for .Net, visit our Web site at: http://www.intersystems.com/cache/dotnet Вадим ... |
| 28.01.2006, 13:03:07 |
Информация про Cache' Managed Provider для .Net на русском языке: Cache' Managed Provider для .Net]http://www.intersystems.ru/cache/dotnet/index.html Вадим ... |
| 31.01.2006, 11:10:59 |
start [/forum/topic.php?desktop=1&fid=39&tid=1559642]: |
44ms |
58ms |
| others: | 315ms |
| total: | 492ms |
