Найчите плиз работать с потоками в Cache ObjectScript
Сабж собственно. Такой класс: Class user.test Extends %Persistent { Property pr1 As %String; Property pr2 As list Of %Integer; Property pr3 As %CharacterStream; } В терминале делаю так: Set or=##class(user.test).%OpenId(22) set or.pr3=##class(%Library.GlobalCharacterStream).%New() do or.pr3.WriteLine("11111 1111111 1111111111 1 11") do or.pr3.Rewind() write or.pr3.Read() do or.pr3.%Save() do or.%Save() Здесь вроде все нормально. Делаем kill Set or=##class(user.test).%OpenId(22) // а дальше, как прочесть??? write or.pr3 // ничего не выводит write or.pr3.Read() // ругается <INVALID OREF> set s=##class(%Library.GlobalCharacterStream).%Open(or.pr3) write s.Read() // пусто set s=##class(%Library.GlobalCharacterStream).%OpenId(or.pr3) write s.Read() // пусто ну как с ним быть? ... |
| 10.01.2007, 11:57:42 |
Из документации тынц. Stream Properties If you need to store large quantities of data, such as images or PostScript files, you can do so by defining a stream property. Caché supports two kinds of streams: binary streams and character streams. Binary streams are for large binary objects, such as pictures, while character streams can be used to store large amounts of text, such as a chapter in a book. Some examples of this are: Class MyApp.JournalEntry Extends %Persistent [ClassType = persistent] { Property ItemDate As %Date; Property PictureOfTheDay As %Stream [ Collection = binarystream ]; Property EventsOfTheDay As %Stream [ Collection = characterstream ]; } You can manipulate a stream property using a %Stream object. This object maintains, for instance, a pointer to the current position within the data. The %Stream object's Write method adds the specified data to the stream at the current pointer position. For example: Set entry = ##class(JournalEntry).%New() Do entry.EventsOfTheDay.Write("Slacking.") The Read method returns the specified number of bytes or characters in a string. For example: Set events = entry.EventsOfTheDay.Read(100) For more information on Streams, refer to the Streams chapter. ... |
| 10.01.2007, 12:38:29 |
все равно ничего не понял. Как прочесть сохраненый поток? ... |
| 10.01.2007, 12:59:11 |
Код: plaintext 1. 2. 3. 4. 5. Записываем Код: plaintext 1. 2. 3. Читаем Код: plaintext 1. 2. ... |
| 10.01.2007, 13:42:31 |
ГР Код: plaintext 1. 2. 3. 4. 5. 6. Читаем Код: plaintext 1. 2. 3. ... |
| 10.01.2007, 15:07:19 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. ... |
| 11.01.2007, 10:22:38 |
ZvezDuke Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. Пусто. ... |
| 12.01.2007, 09:37:41 |
Давайте так. Вот пример кода, который не работает поробуйте подправить так что бы работал. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. ... |
| 15.01.2007, 16:46:54 |
Вообще, первая строчка определения класса должна выглядеть так: Class User.test3 Extends %Persistent [ ClassType = persistent, ProcedureBlock ] а не Class User.test3 Extends %Persistent Вот точно рабочий пример: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. ... |
| 15.01.2007, 18:30:44 |
Maksim UMВообще, первая строчка определения класса должна выглядеть так: Class User.test3 Extends %Persistent [ ClassType = persistent, ProcedureBlock ] а не Class User.test3 Extends %Persistent Вот точно рабочий пример: Код: plaintext 1. 2. 3. 4. 5. 6. 7. Уже проблемы. В Cache` 5.2 коллекция может быть или list или array. Точка. Maksim UM[/src]ClassMethod Test() { s or=##class(User.test3).%New() s or.pr1="qwerty" do or.pr3.WriteLine("12312312873897123")[/src] И получаю <INVALID OREF>. Оно и правильно экземпляр класса не создан. ... |
| 16.01.2007, 15:26:07 |
Мой пример работает в Cache 5.0.20 ks_0987 Уже проблемы. В Cache` 5.2 коллекция может быть или list или array. Точка. Так в чем проблема? Там просто немного отличается от 5.0.20... ks_0987 ClassMethod Test() { s or=##class(User.test3).%New() s or.pr1="qwerty" do or.pr3.WriteLine("12312312873897123")[/src]И получаю <INVALID OREF>. Оно и правильно экземпляр класса не создан. Да, в этот момент еще не создан. Все очень просто, нужно перед работой с потоком сохранить объект, тк для записи потока нужен уникальный ID объекта. Код: plaintext 1. 2. 3. 4. ... |
| 19.01.2007, 08:46:03 |
start [/forum/topic.php?desktop=1&fid=39&tid=1559431]: |
42ms |
45ms |
| others: | 351ms |
| total: | 500ms |
