Cache', Ensemble and Microsoft Vista
March 6, 2007 Cache', Ensemble and Microsoft Vista InterSystems testing has revealed a number of issues that prevent installation and operation of existing Cache' and Ensemble versions on Microsoft Vista. Many of these are related to new operating system security features. Based on what we have discovered to date -- and we need to keep in mind that more issues may yet surface -- our plan is as follows: 1.The 2007.2 versions of Cache' and Ensemble will fully support Microsoft Vista for both server and client configurations. 2.It is possible that the 2007.1 versions of Cache' and Ensemble will run on Vista with certain limitations and some manual "work arounds". For instance, Vista introduces a new version of Microsoft's IIS Web server which drops support for the mechanism (called ISAPI) which is used to connect CSP to IIS. The work around is to manually re-enable ISAPI support in IIS. (Alternatively, customers may decide to use Apache instead of IIS.) In 2007.2 we will move to a new IIS connection mechanism for CSP. 3.Cache' and Ensemble versions prior to 2007.1 will not be supported on Microsoft Vista. From a licensing standpoint, Microsoft Vista is not a new platform. We will continue to have three Windows platforms: x86 32 bit, x86 64 bit, and Itanium. Moving from one Windows version to another does not constitute a platform change. Moving from one processor family to another is a platform change, whether or not the Windows version changes. For instance: Moving from Windows XP on an x86-64 computer to Vista on that same computer is not a platform change. Moving from Windows XP on an x86-32 computer to Vista on an x86-64 computer is a platform change. (Making the same change from an x86-32 computer to an x86-64 computer with Windows XP on both is also a platform change.) If you have any additional questions about our plans for Vista, please contact Andreas Dieckow (Andreas.Dieckow@intersystems.com). ... |
| 07.03.2007, 16:20:27 |
start [/forum/topic.php?desktop=1&fid=39&tid=1559404]: |
30ms |
39ms |
| others: | 320ms |
| total: | 440ms |
