Проблема с запускомк CACHE на linux
Добрый день! Пытаюсь запустить каше под Linux-ом. Вроде поднимается, но при запуске пишет такое: ~# ccontrol start cache Using 'cache.cpf' configuration file This copy of Cache has been licensed for use exclusively by: License missing or unreadable. Copyright (c) 1986-2005 by InterSystems Corporation Any other use is a violation of your license agreement WARNING: Switch is set and may affect production for up to 10 seconds. Waiting for system activity to finish... ready. Setting to InterSystems defaults ... done. Error running Startup <DYNAMIC LIBRARY LOAD>ParseFileBoot+11^%occMsgXML - Logins are disabled В чем может быть проблема? Система: Ubuntu 6.10 :)) Версия СУБД: 5.0.19 ... |
| 07.04.2007, 15:13:12 |
уже нашли. вопрос снимается. ... |
| 07.04.2007, 15:34:30 |
подскажите как Вы решили эту проблему у меня аналогичная ситуация вот протокол старта cache по redhat7.3 ~# ccontrol start cache Using 'cache.cpf' configuration file This copy of Cache has been licensed for use exclusively by: License missing or unreadable. Copyright (c) 1986-2005 by InterSystems Corporation Any other use is a violation of your license agreement WARNING: Switch is set and may affect production for up to 10 seconds. Waiting for system activity to finish... ready. Setting to InterSystems defaults ... done. Error running Startup <DYNAMIC LIBRARY LOAD>ParseFileBoot+11^%occMsgXML - Logins are disabled ... |
| 18.05.2007, 03:17:32 |
Мы когда-то ставили 5.0.17 на АСП Линукс 10. Вот что ответил support По поводу вашей проблемы Возможно будет полезно. Set LD_LIBRARY_PATH to bin catalog of cache installation before using cinstall script LD_LIBRARY_PATH=cache/5015/bin:$LD_LIBRARY_PATH export LD_LIBRARY_PATH before run install put missed file see below ./cinstall It is assumed that cache will be installed in dir /cache/5015. Missed localized messages in distr. Copy files from Windows distr ( Hint Install subdir) to somewhere: Errors_ru.xml ObjectMessages_ru.xml CSPMessages_ru.xml It is possible that STU could failed to finish cache startup. In that case cache -s ../mgr -B Load localized messages manually. for what execute code like S dir=... S lang="ru" for f="Errors","CSP_Messages","ObjectMessages" { S sc(f)=$$Import^%occMessages(dir_"/"_f_"_"_lang_".xml") } Then restart cache. location of locale files in unix distr distr/Cache/install/misc location localized message in windows distr Install В общем, в дистр Каше для Линуха не положили эксемелки с сообщениями об ошибках. Каше не может их загрузить - не завершает инициализацию - потому при запуске валится с такой страшной ошибкой. Надоть скопировать их из виндовозного дистра в соотв. папочку никсового и переставить Каше, либо загрузить их вручную, как описывает саппорт (такого я не делал). ----------------------- МУМПС форева СКЛ маздай ... |
| 06.06.2007, 14:59:17 |
Насколько я понял в Linux файлы должны располагаться в ./dist/Cache/install/misc ? Названия файлов регистрозависимые или нет? ... |
| 27.06.2007, 11:12:55 |
start [/forum/topic.php?desktop=1&fid=39&tid=1559308]: |
29ms |
62ms |
76ms |
| others: | 332ms |
| total: | 546ms |
