Cache' 2007.1 Release
InterSystems is pleased to announce that Cache' 2007.1 is now available as a production release. For an overview of the new capabilities added by 2007.1, see the release notes posted on our Web site at http://www.intersystems.com/cache/downloads/documentation/2007_1/pdfs/GCRN.pdf Cache' 2007.1.0 is available immediately for the following platforms: Apple Mac OS X 10.4 for PowerPC Apple Mac OS X 10.4 for x86 HP OpenVMS 7.3-2, 8.2, 8.3 for Alpha HP Tru64 UNIX 5.1B for Alpha HP HP-UX 11i v2 for Itanium HP OpenVMS 8.2-1, 8.3 for Itanium HP HP-UX 11.0 for PA-RISC-32 HP HP-UX 11i v2 for PA-RISC-64 IBM AIX 5L V5.2, V5.3 for System p5-32 IBM AIX 5L V5.2, V5.3 for System p5-64 Microsoft Windows 2000 (SP4), XP Pro (SP2), Server 2003 (SP1) for x86-32 Microsoft Windows Server 2003 (SP1) for x86-64 Microsoft Windows Server 2003 (SP1) for Itanium Red Hat Enterprise Linux AS v.4 for x86-32 Red Hat Enterprise Linux AS v.4 for x86-64 Red Hat Enterprise Linux AS v.4 for Itanium SUSE Linux Enterprise Server 9 (SP3), 10 (SP1) for x86-32 SUSE Linux Enterprise Server 9 (SP3), 10 (SP1) for x86-64 Testing is ongoing for Solaris, which will be released at a later date. (For those of you who care, the released version is build 369.) This is an announcement mailing list for Cache'. Cache' news, release information, and support issues from InterSystems Corporation will be sent to this list. The information is also posted to our website. All the Cache' support issues announced on this list are at: http://www.intersystems.com/support/cflash/index.html Current release information is available at: http://www.intersystems.com/cache/technology/product-tables/current-prodlist.html Now available - Ensemble-News mailing list. You can get more information and sign up at: http://www.intersystems.com/support/mailinglist.html You can also sign up for our monthly e-UpDate newsletter. In it you will find timely information about Cache' and InterSystems. See the latest edition and sign up at: http://www.intersystems.com/e-update Вадим ... |
| 02.07.2007, 10:17:48 |
Интересно кто-то из сообщества скачал и попробовал? Если есть опыт поделитесь! Я знаю несколько партнеров, которые уже сделали свои решения на Cache' 2007.1. У них вроде бы все отлично! Вадим ... |
| 06.07.2007, 19:02:50 |
С радостью поделились бы опытом использования, только не знаем где скачать. И на intersystems.ru и на intersystems.com последняя версия - 5.2.3. ... |
| 06.07.2007, 19:59:32 |
Работаем с большими потоками данных в разных местах Иногда - очень редко - возникает проблема из-за трактовки текста типа "5E-7" который превращается в число (выполните например команду W +"5e6" ) Нам такие фокусы не нужны - можно ли как-то отключить преобразование ? Отслеживать программно - теперь уже нереально слишком много задач и пользователей (в принципе можно было бы заменять латинские буквы "e" "E" на русские - но тогда могут появится другие проблемы) Как с этим в новых версиях ? Есть ли [недокументированнная] возможность отключения? Может кто сталкивался ? ==================== ... |
| 08.07.2007, 02:29:37 |
Почему портал английский (в 348 была русский) ? ... |
| 09.07.2007, 07:51:12 |
Александр КПочему портал английский (в 348 была русский) ? Cache 2007.1.0.369.0 - портал англоязычный, все остальное на русском. Учитывая, что портал (System Manager Portal) берет свои настройки с настроек браузера, во всяком случае в 5.2 так было, перепробовал IE6, Avant Brouser, Mozilla FireFox, Opera но результат - англоязычный портал. Установлена локаль RUW8, в портале в списке доступных языков интерфейса русского даже нет. Запустил cnls.exe решил перезагрузить локаль, решил поменять на Англоязычный интерфейс, а потом обратно на Русский, но при смене локали на Английский Cache вообще не запускается. В cconsole.log дает ошибку при старте Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. Самое простое переустановить, но интересует вопрос о русификации портала. ... |
| 23.07.2007, 05:42:31 |
В вашем случае на базах похоже стоит тип сортировки, который английской локалью не поддерживается, например Cyrilic2. ... |
| 23.07.2007, 05:52:44 |
А в портале просто нет русского интерфейса ... |
| 23.07.2007, 05:53:53 |
Блок А.Н.В вашем случае на базах похоже стоит тип сортировки, который английской локалью не поддерживается, например Cyrilic2. Действительно тип сортировки стоял Cyrilic2, но есть ли возможность теперь поменять локаль из терминала обратно на RUW8? ... |
| 23.07.2007, 06:28:28 |
Зачем из терминала? cnls уже не запускается? ... |
| 23.07.2007, 07:03:36 |
Блок А.Н.Зачем из терминала? cnls уже не запускается? Если бы запускался, то вопрос бы не возник Я не могу запустить портал, он у меня неактивный. Сервис не запущен, как не пытаюсь его запустить не хочет. Ни из командной строки ни из списка служб. Хотя в терминал пускает. Если это из за типа сортировки, то возникает вопрос как поменять локаль из терминала. ... |
| 23.07.2007, 07:30:16 |
Два решения приходят в голову - переставить каше и посмотреть cboot, там что-то было с локалями. Ничего более умного. К сожалению... Кстати, какая последняя версия каше локализована? А то есть программисты, которые очень хотят именно русского интерфейса. Локализация же вынесена в dll, то есть ее наверно можно переносить? ... |
| 23.07.2007, 20:37:40 |
start [/forum/topic.php?desktop=1&fid=39&tid=1559286]: |
43ms |
62ms |
| others: | 320ms |
| total: | 489ms |
