source code of class
Hi, Anybody know, how to get source code of class?? I easy to get source code of routines, just to use %Library.routine, but there isn't something like %Library.class and %Library(%Dictionary).classdefinition is not enough to get source code of class, only properties and stuff like that:/ thanks for help, grynien ... |
| 13.05.2008, 15:40:59 |
something like this: Код: plaintext 1. 2. 3. ... |
| 14.05.2008, 15:02:52 |
Thanks for answer, but only give it a methods code, but I want to have entire code of the class you can see in the stuido, at the moment I am using $system.obj.export to export entire code to xml file (isn't what I want to have), but I can't do it in better way :/ ... |
| 14.05.2008, 16:06:18 |
start [/forum/topic.php?desktop=1&fid=39&tid=1558895]: |
27ms |
72ms |
56ms |
| others: | 338ms |
| total: | 555ms |
