Проблема с запуском cache
При запуске в терминале выдает ... |
| 29.09.2009, 09:58:15 |
alexey.shПри запуске в терминале выдает Error attaching shared memory The system was probably shut down or crashed while Cache was running -- continuing startup. Using 'cache.cpf' configuration file Shared memory segment does not exist Deleting cache.ids file and continuing Automatically configuring buffers Allocated 312MB shared memory: 256MB global buffers, 6MB routine buffers Creating a WIJ file to hold 31 megabytes of data ... |
| 29.09.2009, 09:59:37 |
Чет знакомое http://sql.ru/forum/actualsearch.aspx?search=Error+attaching+shared+memory&sin=0&a=&ma=0&bid=56&dt=-1&s=1&so=1 ... |
| 30.09.2009, 06:02:57 |
start [/forum/topic.php?desktop=1&fid=39&tid=1558377]: |
28ms |
72ms |
89ms |
| others: | 345ms |
| total: | 600ms |
