Новый релиз GT.M V5.4-001
GT.M V5.4-001 is a significant new release that adds support for Linux on IBM System z. SuSE Linux Enterpriise Server 10 and 11 are the Supported OS distributions. Also the GT.M trigger functionality introduced with field test grade support in V5.4-000 is now considered deployable with production grade support. There are also a number of bug fixes, robustness improvements, and numerous smaller enhancements, as detailed in the Release Notes (http://tinco.pair.com/bhaskar/gtm/doc/articles/ GTM_V5_4_001_Release_Notes.html). These include: * More user friendly and robust shell scripts in the database encryption reference plugin. * The new $gtm_snaptmpdir environment for MUPIP INTEG temporary files. * Better time resolution for M profiling. The software can be downloaded from the GT.M project at Source Forge (http://sourceforge.net/projects/fis-gtm). ... |
| 07.07.2010, 10:39:37 |
start [/forum/search_topic.php?author=Lehamen&author_mode=last_posts&do_search=1]: |
25ms |
51ms |
64ms |
| others: | 930ms |
| total: | 1165ms |
