Установка и запуск GT.M v6.0
Установил GT.M и по инструкции в Administration and Operations Guide и по инструкции Acculturation Workshop ( http://www.netfort.cz/gtm/acculturation/workshop_111118/index.html), со всеми ньюансами GT.M v6.0 Release Notes. Возможно gtm_V60000_linux_i686_pro.tar.gz - не для Linux x64? Ошибок при установке не было, была необходимость установки i686 библиотек Ncurses и ICU и создание символьных ссылок для них, и это для GT.M x64? Вроде бы находил о подобном от Bhaskar'а. Запуск не из под root выполняется с ошибками: [lee@LeeCentOSx64 ~]$ source /usr/lib/fis-gtm/V6.0-000_x86_64/gtmprofile %GTM-E-SYSCALL, Error received from system call stat -- called from module /usr/library/V60000/src/zro_search.c at line 95 %SYSTEM-E-ENO13, Permission denied %GTM-E-SYSCALL, Error received from system call stat -- called from module /usr/library/V60000/src/zro_search.c at line 95 %SYSTEM-E-ENO13, Permission denied %GTM-E-SYSCALL, Error received from system call stat -- called from module /usr/library/V60000/src/zro_search.c at line 95 %SYSTEM-E-ENO13, Permission denied %GTM-E-SYSCALL, Error received from system call stat -- called from module /usr/library/V60000/src/zro_search.c at line 95 %SYSTEM-E-ENO13, Permission denied %GTM-E-SYSCALL, Error received from system call stat -- called from module /usr/library/V60000/src/zro_search.c at line 95 %SYSTEM-E-ENO13, Permission denied %GTM-E-ZGBLDIRACC, Cannot access global directory /home/lee/.fis-gtm/V6.0-000_x86/g/gtm.gld. Cannot continue. %SYSTEM-E-ENO2, No such file or directory %GTM-E-ZGBLDIRACC, Cannot access global directory /home/lee/.fis-gtm/V6.0-000_x86/g/gtm.gld. Cannot continue. %SYSTEM-E-ENO2, No such file or directory Права какие то дать пользователю или GT.M? Далее GT.M запускается, но войти в GDE не получается. [lee@LeeCentOSx64 ~]$ /usr/lib/fis-gtm/V6.0-000_x86_64/gtm GTM>do ^GDE %GTM-E-SYSCALL, Error received from system call stat -- called from module /usr/library/V60000/src/zro_search.c at line 95 %SYSTEM-E-ENO13, Permission denied GTM> Что это за файл такой - /usr/library/V60000/src/zro_search.c и почему прав нет? Если запускать GT.M от root, то все без ошибок, но и создает все в /root/.fis-gtm/. Или это не так важно? :) ... |
| 08.10.2012, 14:49:31 |
Для примера можете посмотреть как устанавливают VistA в GT.M Там все детально рассказывается (я ссылки указал) http://seaislandsystems.com/vxVistA/HowToPort.html Также интересный линки http://www.divconq.com/2011/intro-m-part-1/ http://www.osehra.org/home [lee@LeeCentOSx64 ~]$ /usr/lib/fis-gtm/V6.0-000_x86_64/gtm Я всегда устанавливаю в папку /usr/local/gtm60 Там и создаю базу(посмотрите на подобие выше пример для VistA) Можете посмотреть и скачать на сайте специальную учебную программу. http://sourceforge.net/projects/fis-gtm/files/GT.M%20Acculturation%20Workshop/ Я например все делаю из под root-а, хотя это не приветствуется. :) ... |
| 08.10.2012, 17:02:48 |
Так же можете задавать вопросов на сайте: https://groups.google.com/forum/?fromgroups#!forum/comp.lang.mumps Там ребята ответят. Правда тоже на английском. :) ... |
| 08.10.2012, 17:16:33 |
ValeriuДля примера можете посмотреть как устанавливают VistA в GT.M Там все детально рассказывается (я ссылки указал) http://seaislandsystems.com/vxVistA/HowToPort.html Также интересный линки http://www.divconq.com/2011/intro-m-part-1/ http://www.osehra.org/home Спасибо. Посмотрю. Я последнюю кстати нашел вчера :) Но там слишком все... Надо разбираться, пока что надо заниматься текущей задачей, но это перенесу на выходные. ValeriuЯ всегда устанавливаю в папку /usr/local/gtm60 Там и создаю базу(посмотрите на подобие выше пример для VistA) Можете посмотреть и скачать на сайте специальную учебную программу. http://sourceforge.net/projects/fis-gtm/files/GT.M%20Acculturation%20Workshop/ Я например все делаю из под root-а, хотя это не приветствуется. :) Это я понял, что не важно куда устанавливаешь, там дальше переменные указывать и все. И GT.M Acculturation Workshop я кстати привел в начале :) только вот не мог найти где эту виртуальную машину можно скачать (да и пока не актуально). Поэкспериментирую дома. Или чуть позже создам еще одну виртуальную CentOS. А пока буду работать под root. Надо пока уйти в прикладные задачи: создание базы данных и работы с данными... :) Не подскажете, кто тут работает в GT.M с C/C++ или Python? ... |
| 08.10.2012, 17:18:54 |
Не подскажете, кто тут работает в GT.M с C/C++ или Python? Сами спросили. Может и ответят. Мало нас. :) ... |
| 08.10.2012, 17:50:07 |
ValeriuНе подскажете, кто тут работает в GT.M с C/C++ или Python? Сами спросили. Может и ответят. Мало нас. :) Уже вроде бы я самостоятельно все больше и больше понимаю как все делается... :) ... |
| 08.10.2012, 18:45:21 |
И все равно не пойму, какой вариант брать: GT.M-x86-Linux - gtm_V60000_linux_i686_pro.tar.gz или GT.M-amd64-Linux - gtm_V60000_linux_x8664_pro.tar.gz Первое как бы указывает, что это i686, а значит 32-бит, второе - x8664 - 64-бит. ... |
| 09.10.2012, 01:04:44 |
start [/forum/topic.php?desktop=1&fid=39&tid=1557362]: |
41ms |
69ms |
| others: | 337ms |
| total: | 523ms |
