Подключение базы с сетевого диска из под windows
Вот здесь было описано для 5 http://www.sql.ru/forum/296911/oshibka-pri-dobavlenii-oblasti-i-bd?hl=??????? ???? Здесь можно было задать имя и пароль пользователя "Also specify in Caché configuration "Network Server Username" and "Network Server Password" the same username and password as Windows user who can access network folder "\\ComputerName\Folder" Как сделать аналогично для версии 2012 ? ... |
| 18.11.2013, 16:48:18 |
Достаточно запустить службу Cache из под пользователя которому будет доступна эта сетевая папка. ... |
| 18.11.2013, 16:51:19 |
DAiMor, Не пойдет Как сделать аналогично 5 ? ... |
| 18.11.2013, 16:56:03 |
| 18.11.2013, 16:57:36 |
kalinDAiMor, Не пойдет Как сделать аналогично 5 ?только так, по другому теперь не получится авторWindows Network Server Username and Password Change In previous versions, Caché would install and start its services on Windows with a default username of “_SYSTEM”, and a password of “_sys” unless configured otherwise. The values for the username and password were set via the Configuration Manager using the Advanced tab and the “Input/Output” option. In version 5.1, during upgrade, these values (or the default values if none were set) will be stored in the Windows service definition created for the upgrade. Administrators may change the values using the Windows Management Interface. From the Windows Start menu, navigate to Programs, then Administrative Tools, and finally Component Services. Select the appropriate Caché service and from the Action menu choose Properties. The username and password are accessed via the Log On tab. ... |
| 18.11.2013, 16:58:56 |
start [/forum/topic.php?desktop=1&fid=39&tid=1557022]: |
52ms |
67ms |
| others: | 368ms |
| total: | 567ms |
