Team Foundation Server 2008
ПОставил себе для теста сие чудо... но возникла беда, нехочет создаваться проект из VS 2008 :(... можете подсказать с чем связана беда? Win 2003 Server SP2, Sql Server 2005 Sp2, Team Foundation Server 2008. AD не установлен. При попытке создать выдает такое... Error Unable to connect to the Windows SharePoint Services at bmw Explanation The Project Creation Wizard was not able to connect to the Windows SharePoint Services at bmw. The reason for the failed connection cannot be determined at this time. Because the connection failed, the wizard was not able to complete creating the Windows SharePoint Services site. User Action Contact the administrator for the Windows SharePoint Services at bmw to confirm that the server is available on the network. Also, you might find additional helpful information in the project creation log. The log shows each action taken by the wizard at the time of the failure and may include additional details about the error. Warning TF30144: The New Team Project Wizard attempted to roll back all of the steps taken to this point but was unsuccessful. Contact your Team Foundation Server administrator for further instructions. Сам детальный лог.. его концовка 2008-04-15 18:05:52Z | Module: WSS | Thread: 10 | Owner Email: 2008-04-15 18:06:07Z | Module: WSS | Thread: 10 | Creating Document Library : Security retry#: 0 2008-04-15 18:06:07Z | Module: WssSiteCreator | Thread: 10 | TF30267: Exception: System.Net.WebException: Сбой запроса с состоянием HTTP 403: Forbidden. в System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) в System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) в Microsoft.TeamFoundation.Proxy.Portal.Lists.GetListCollection() в Microsoft.VisualStudio.TeamFoundation.WssUtilities.FetchList(Lists listProxy, WssListType type) в Microsoft.VisualStudio.TeamFoundation.WssUtilities.FetchListTitles(Lists listProxy, WssListType type) в Microsoft.VisualStudio.TeamFoundation.WssUtilities.CreateList(Lists listProxy, String name, String description, WssListType type) в Microsoft.VisualStudio.TeamFoundation.WssSiteCreator.CreateDocLib(ProjectCreationContext context, Lists list, String name, String desc) в Microsoft.VisualStudio.TeamFoundation.WssSiteCreator.HandleDocumentLibraryCreation(ProjectCreationContext context, XmlNode taskNode) в Microsoft.VisualStudio.TeamFoundation.WssSiteCreator.Execute(ProjectCreationContext context, XmlNode taskXml) ---begin Exception entry--- Time: 2008-04-15 18:06:07Z Module: Engine Event Description: TF30162: Task "SharePointPortal" from Group "Portal" failed Exception Type: Microsoft.TeamFoundation.Client.PcwException Exception Message: Unable to connect to the Windows SharePoint Services at bmw Exception Details: The Project Creation Wizard was not able to connect to the Windows SharePoint Services at bmw. The reason for the failed connection cannot be determined at this time. Because the connection failed, the wizard was not able to complete creating the Windows SharePoint Services site. Stack Trace: в Microsoft.VisualStudio.TeamFoundation.WssSiteCreator.Execute(ProjectCreationContext context, XmlNode taskXml) в Microsoft.VisualStudio.TeamFoundation.ProjectCreationEngine.TaskExecutor.PerformTask(IProjectComponentCreator componentCreator, ProjectCreationContext context, XmlNode taskXml) в Microsoft.VisualStudio.TeamFoundation.ProjectCreationEngine.RunTask(Object taskObj) -- Inner Exception -- Exception Type: System.Net.WebException Exception Message: Сбой запроса с состоянием HTTP 403: Forbidden. WebException: Response Status Code: Forbidden WebException: Response Status Message: Forbidden WebException: Status : ProtocolError Stack Trace: в System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) в System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) в Microsoft.TeamFoundation.Proxy.Portal.Lists.GetListCollection() в Microsoft.VisualStudio.TeamFoundation.WssUtilities.FetchList(Lists listProxy, WssListType type) в Microsoft.VisualStudio.TeamFoundation.WssUtilities.FetchListTitles(Lists listProxy, WssListType type) в Microsoft.VisualStudio.TeamFoundation.WssUtilities.CreateList(Lists listProxy, String name, String description, WssListType type) в Microsoft.VisualStudio.TeamFoundation.WssSiteCreator.CreateDocLib(ProjectCreationContext context, Lists list, String name, String desc) в Microsoft.VisualStudio.TeamFoundation.WssSiteCreator.HandleDocumentLibraryCreation(ProjectCreationContext context, XmlNode taskNode) в Microsoft.VisualStudio.TeamFoundation.WssSiteCreator.Execute(ProjectCreationContext context, XmlNode taskXml) -- end Inner Exception -- --- end Exception entry --- 2008-04-15 18:06:07Z | Module: Engine | Thread: 10 | TF30202: Task "" from Group "" will not be run because a prior task failed. 2008-04-15 18:06:07Z | Module: Engine | Thread: 10 | TF30202: Task "Site" from Group "Reporting" will not be run because a prior task failed. 2008-04-15 18:06:07Z | Module: Engine | Thread: 10 | TF30202: Task "Populate Reports" from Group "Reporting" will not be run because a prior task failed. 2008-04-15 18:06:07Z | Module: Engine | Thread: 10 | TF30202: Task "" from Group "" will not be run because a prior task failed. ---begin Exception entry--- Time: 2008-04-15 18:06:10Z Module: Engine Event Description: TF30002: The New Team Project Wizard encountered an error deleting the project Exception Type: System.Net.WebException Exception Message: Сбой запроса с состоянием HTTP 403: Forbidden. WebException: Response Status Code: Forbidden WebException: Response Status Message: Forbidden WebException: Status : ProtocolError Stack Trace: в System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) в System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) в Microsoft.TeamFoundation.Proxy.Portal.Lists.GetListCollection() в Microsoft.TeamFoundation.Client.TeamProjectDeleter.WssSiteExists() в Microsoft.TeamFoundation.Client.TeamProjectDeleter.DoWssDelete() --- end Exception entry --- ---begin Exception entry--- Time: 2008-04-15 18:06:10Z Module: Engine Event Description: TF30002: The New Team Project Wizard encountered an error deleting the project Exception Type: System.Net.WebException Exception Message: Сбой запроса с состоянием HTTP 403: Forbidden. WebException: Response Status Code: Forbidden WebException: Response Status Message: Forbidden WebException: Status : ProtocolError Stack Trace: в System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) в System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) в Microsoft.TeamFoundation.Proxy.Portal.Lists.GetListCollection() в Microsoft.TeamFoundation.Client.TeamProjectDeleter.WssSiteExists() в Microsoft.TeamFoundation.Client.TeamProjectDeleter.DoWssDelete() --- end Exception entry --- 2008-04-15 18:06:10Z | Module: Engine | Thread: 12 | Attempting to delete MSF folder "C:\Documents and Settings\Администратор\Local Settings\Temp\TPW_tmp61F.tmp" 2008-04-15 18:06:11Z | Module: Engine | Thread: 12 | The temporary folder C:\Documents and Settings\Администратор\Local Settings\Temp\TPW_tmp61F.tmp used to store the process template was removed. Подскажите где грабли :( оч надо... ... |
| 15.04.2008, 19:47 |
автор...Exception Message: Сбой запроса с состоянием HTTP 403: Forbidden... с правами видимо надо разбираться ... |
| 15.04.2008, 21:03 |
тоесть это надо ковырять IIS ? ... |
| 16.04.2008, 12:47 |
не думаю, что дело так глубоко - аж в правах ты начни с того, понимаешь ли ты принцип его работы? это штука весьма непростая ты должен очень четко понимать, что это просто надстройка над ШарПоинтом и РепортСервером (ну и конечно в основании пирамиды лежит SQL) ковырять надо НЕ ИИС - это самый нижний уровень, с точки зрения ТИМ2008 - это что-то близкое к электропитанию компьютера скорее всего проблемы на верхних уровнях иерахии - в ШарПоинте в нем и есть все твои проблемы скорее всего ... |
| 18.04.2008, 13:20 |
А что касается VS2008, то она общается с ТИМом посредством вот таких 22 служб Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. понимаешь ли ты как каждая их них работает, что требует в АУ? как должен работать отчетный портал ШарПоинта под ТИМом? ответь для себя сначала на все эти вопросы - на халяву такие системы не поднимаются у нас на работе например чел, который поднял всю эту среду - получил за ее понятие 4 тысячи долларов премии я сам ее поднимал раза три за сравнимые суммы - это все весьма непросто и с наскока такие системы не ставятся ... |
| 18.04.2008, 13:26 |
урка1у нас на работе например чел, который поднял всю эту среду - получил за ее понятие 4 тысячи долларов премии я сам ее поднимал раза три за сравнимые суммы - это все весьма непросто и с наскока такие системы не ставятся Вот так вот начинаешь понимать, что начинал работать в "неправильных" местах :) Кагда я первый раз поднимал 2005 мне и спасибо то особо никто не сказал :) ... |
| 20.04.2008, 11:56 |
А нам так вообще сказали: "Вы что охренели целых пол рабочих дня ставили. Могли бы после работы в свободное время поставить или в обед" Честно так и сказали :-) ... |
| 03.05.2008, 19:22 |
извините, что пишу немного не в тему но у меня такая проблема. Решил поставить Team Foundation Server 2008 и в процессе установки он выплюнул такую ошибку TF220066. как её устранить, можт подскажете. у меня стоит Windows server 2008, SQL SERVER 2008, VSTS 2008 ну и SQL SERVER 2005 Express ... |
| 10.09.2008, 20:49 |
start [/forum/topic.php?desktop=1&fid=37&tid=1555617]: |
30ms |
48ms |
| others: | 206ms |
| total: | 320ms |
