Помогите найти ответы
Буду признателен, если кто-то поможет мне найти ответы на данные вопросы. 1. Give an example of test plan for testing Web application? 2. Which software testing automation tools would you use for testing Web application? 3.What means load/perfomance testing? Why it is important? 4.What kind of test do you know? Give a detail explanation for each of them. 5.What is client-server application? Give an example. 6.What nuances are in testing of client server application? 7.How usual test report should look like? Give an example. 8.What black box techniques do you know? Give an example and explanation. 9.Do you know lifecycle of software development (SDLC)? Where testing seats? 10.How do you define Quality Assurance for yourself? 11.Define and explain Unit, System and Integration testing. 12.Generate test cases for string replacement. 13.Explain how will you test calculator. 14.If you want to test Web application on local PC, what do you need? 15.What is the difference of testing Web application on server, and Web application on a local PC? 16.How will you test something (any application) if you do not have it's specification? 17. What kind of application can you test with above mentioned software? Explain for each. ... |
| 11.01.2006, 03:08:34 |
CAБуду признателен, если кто-то поможет мне найти ответы на данные вопросы. 1. Give an example of test plan for testing Web application? 2. Which software testing automation tools would you use for testing Web application? 3.What means load/perfomance testing? Why it is important? 4.What kind of test do you know? Give a detail explanation for each of them. 5.What is client-server application? Give an example. 6.What nuances are in testing of client server application? 7.How usual test report should look like? Give an example. 8.What black box techniques do you know? Give an example and explanation. 9.Do you know lifecycle of software development (SDLC)? Where testing seats? 10.How do you define Quality Assurance for yourself? 11.Define and explain Unit, System and Integration testing. 12.Generate test cases for string replacement. 13.Explain how will you test calculator. 14.If you want to test Web application on local PC, what do you need? 15.What is the difference of testing Web application on server, and Web application on a local PC? 16.How will you test something (any application) if you do not have it's specification? 17. What kind of application can you test with above mentioned software? Explain for each. собеседование?:)) ... |
| 11.01.2006, 17:48:31 |
нет, просто пытаюсь самостоятельно заниматься изучением тестирования. ... |
| 11.01.2006, 19:51:30 |
Что-то уж больно мне это напоминает вопросы для рекрутов по тестированию моей недавней конторы... Щас линком поделюсь... :) Posted via ActualForum NNTP Server 1.3 ... |
| 12.01.2006, 00:47:33 |
Похоже всё-таки собеседование, странно что нет вопроса про тестирование белого ящика. :) ... |
| 12.01.2006, 17:07:15 |
victor_01Похоже всё-таки собеседование, странно что нет вопроса про тестирование белого ящика. :) Это не подготовка к собеседованию! Это самостоятельное изучение предмета. Просто в интернете был найдет список вопросов. На многие уже есть ответ. На эти ответа нет, в силу недостаточности моих знаний. Если есть возможность/желание/знание, помогите найти ответы на данные вопросы. Можно указать литературу, в которой я смогу это найти. ... |
| 13.01.2006, 03:03:41 |
1. Give an example of test plan for testing Web application? Вот тут есть информация по тест плану http://www.sqatester.com/documentation/testplansmpl.htm 2. Which software testing automation tools would you use for testing Web application? Это зависит от самого web приложения, возможно это просто web сайт - тогда возможно будет достаточно простой проверки работоспособности ссылок для этих целей подходит например Rational Site Check, Если более серьёзное приложение, требующее заполнения каких нибудь форм, то может быть достаточно Rational Robot, если это приложение содержит сложные html объекты такие как выпадающие меню, dhtml деревья то можно использовать Rational XDE Tester, но взависимости от выбранного средства возрастает время создания тестов и время их выполнения. Для тестирование производительности можно например использовать JMeter 3.What means load/perfomance testing? Why it is important? Это тестирование производительности системы, тоесть эмулируется работа сразу n-го количества пользователей замеряется время реакции системы. 4.What kind of test do you know? Give a detail explanation for each of them. http://www.sqatester.com/methodology/testreviews.htm 5.What is client-server application? Give an example. Любой интернет магазин. ... |
| 13.01.2006, 14:18:57 |
victor 01 , спасибо огромное! ... |
| 13.01.2006, 18:20:54 |
start [/forum/topic.php?desktop=1&fid=36&tid=1555128]: |
203ms |
38ms |
| others: | 229ms |
| total: | 506ms |
