ВАКАНСИЯ: Senior QA Automation Engineer (Kiev)
Vacancy opened in Kiev. Main requirements : - 2+ years of .net development; - 2+ experience with test automation back-end and Web based front-end as well (including leading experience, automation framework development, automation processes setup and support); - Expert in Selenium RC (any other Test Automation tools are the plus); - Strong knowledge of OOP concepts; - Deep understanding n-tier architecture ; - Be able to manipulate XML based configuration files, XML parsing, XML schemas; - SQL (retrieving data from databases); - Good English written and spoken skills; - Have good interpersonal and communication skills; The system is a composition of back-end (.net) and Web-based (.net) data analysis application with complex organized Web UI, using a variety of the newest technologies. The project would become a highly available, scalable and secure driver safety and risk management solution that should provide great user experience. Responsibility : - responsible for automated scripts creation/execution; - test automation of web application (including AJAX and Silverlight); - Collaboration with QA team to refine the requirements; - compiling and reviewing results of automation test execution; - problems isolation and defects reporting; - automation test team leading; If you are interested, please, contact Zoya via ICQ 323735604 ... |
| 17.12.2009, 14:31:42 |
start [/forum/topic.php?desktop=1&fid=36&tid=1554862]: |
255ms |
| others: | 232ms |
| total: | 546ms |
