тем кому интересно что то отличное от MS SQL и Oracle -ASE News
Sybase ASE: a continuing surprise Published: 8th July 2005 By: Philip Howard Contact The Author Copyright © 2005 Bloor Research Channel: Data Management Sybase is scheduled to release version 15 of Adaptive Server Enterprise (ASE) in the autumn. Given that Sybase is no longer regarded as one of the 800lb gorillas in the database market, it is an ongoing surprise as to just how good ASE is. It is also a surprise that the next version is ASE 15.0 whereas the current release is 12.5. To deal with the latter question first: the reason for Sybase skipping both 13 and 14 is apparently that, while we know that 13 is unlucky in the West, it seems that 14 is unlucky in the East and, particularly, in China. As far as the database itself is concerned, the point to remember is that Sybase has a separate product for data warehousing: Sybase IQ. Therefore developments for ASE are only focused on transactional environments and the database does not require a lot of the stuff that you need to have for data warehousing. On the other hand, the company has concentrated heavily on supporting query processing within on-line environments, to the extent that there is a good case to be made for Sybase ASE being the best performing database for hybrid environments. As far as the new release is concerned, there are a number of significant enhancements. Amongst other things, there will be a number of new partitioning options that will support sub-indexes within partitions, extended XML support (which was already extensive, with advanced features such as hierarchical index support), expanded security capabilities (including new data encryption features), a re-developed optimiser, support for computed columns with functional indexes based on those columns and, in the first point release (15.1) there will be support for shared-disk clusters. This will be similar to Oracle’s RAC (real application clusters) except that Sybase will also support the definition of sub-clusters, which should help to maintain service levels. The revamped optimiser is particularly interesting as it uses and extends (in fact, Sybase has multiple patent filings as a result) techniques derived from work done by Graefe and McKenna on the Volcano Optimizer Generator in the early 90s. In particular, it makes use of the fact that if you are walking an index then there is an implicit order that you can take advantage of when responding to a query. In simple terms, what this means is that you minimise the number of times that you have to go through an index. For relevant queries (such as joins with expressions but no indexes, vector aggregation with Group By, and multiple scalar aggregation) the new optimiser has produced some very significant performance gains. For example: in tests, the least improved of these resulted in I/O savings of 83% and query performance improvements of 186%. On top of all of this, ASE is also relatively inexpensive. A recent study into total cost of ownership by The Standish Group found that Sybase ASE undercut all of its main competitors (Oracle, Microsoft and IBM) on both Windows and Linux (not Microsoft) platforms by as much as 37%. With comparable or better performance than the big three database vendors and a lower cost of ownership, you can see why Sybase remains a cause of surprise: why is it that more companies do not think of implementing ASE? Beats me. Next Article Today Licensing / Reprint Information Reader Comments ... |
| 26.07.2005, 17:32:28 |
http://www.sybase.com/detail?id=1030108 ... |
| 26.07.2005, 17:46:31 |
А зачем изучать СУБД работ на которую на рынке не сыскать днем с фонарем? Особенно в свете пропагандируемых фирмой Sybase попыток изжить профессию DBA как таковую. Сдается мне что DBA были есть и будут, а вот Sybase загнется. ... |
| 28.07.2005, 04:35:36 |
Зл0йА зачем изучать СУБД работ на которую на рынке не сыскать днем с фонарем? Особенно в свете пропагандируемых фирмой Sybase попыток изжить профессию DBA как таковую. Сдается мне что DBA были есть и будут, а вот Sybase загнется. Эт мы еще посмотрим, кто загнется :) Пока у Sybase ген директор китаец и Китай основной потребитель Sybase, загинаться будет кто угодно, но не Sybase :) ... |
| 28.07.2005, 08:14:15 |
Зл0йА зачем изучать СУБД работ на которую на рынке не сыскать днем с фонарем? Особенно в свете пропагандируемых фирмой Sybase попыток изжить профессию DBA как таковую. Сдается мне что DBA были есть и будут, а вот Sybase загнется. раньше на телефонных станциях не мыслили работу без спец. девушек, соединяющих провода... ... |
| 28.07.2005, 08:28:15 |
Vo pervih, eto to gde ne najti rabotu po ASE ? Raboti hvataet, na 1 poziciju po Sybase 2 kandidata , na 1 po Oracle - 10. Vo vtorih, pechalno kogda takie kak Vi reclamirujut RDBMS po principu - posmatri na Market , vmesto togo chobi podumatj chto dlaja konkretnoj zadachi bolee podhodit. Eto kak bi skazatj pomjagche - ne proffesiolalno po menshej mere. V tretjih - topik ja nazval "тем кому интересно что то отличное от MS SQL и Oracle " , ne interesno - ne zasorajne forum pozalusta pustimi postingami. ... |
| 28.07.2005, 17:00:42 |
ASCRUS Зл0йА зачем изучать СУБД работ на которую на рынке не сыскать днем с фонарем? Особенно в свете пропагандируемых фирмой Sybase попыток изжить профессию DBA как таковую. Сдается мне что DBA были есть и будут, а вот Sybase загнется. Эт мы еще посмотрим, кто загнется :) Пока у Sybase ген директор китаец и Китай основной потребитель Sybase, загинаться будет кто угодно, но не Sybase :) Китайцы за софт не платят. Почитают за низкое. ... |
| 29.07.2005, 01:19:19 |
pppVo pervih, eto to gde ne najti rabotu po ASE ? Raboti hvataet, na 1 poziciju po Sybase 2 kandidata , na 1 po Oracle - 10. Vo vtorih, pechalno kogda takie kak Vi reclamirujut RDBMS po principu - posmatri na Market , vmesto togo chobi podumatj chto dlaja konkretnoj zadachi bolee podhodit. Eto kak bi skazatj pomjagche - ne proffesiolalno po menshej mere. V tretjih - topik ja nazval "тем кому интересно что то отличное от MS SQL и Oracle " , ne interesno - ne zasorajne forum pozalusta pustimi postingami. На восточном побережье США работ на ASE по сравнению с Oracle и DB2 просто нет. Цифры "в пределах ошибки измерения". Наличие работ на ASE за пределами восточного побережья США меня не интересует. ... |
| 29.07.2005, 01:22:50 |
Зл0й pppVo pervih, eto to gde ne najti rabotu po ASE ? Raboti hvataet, na 1 poziciju po Sybase 2 kandidata , na 1 po Oracle - 10. Vo vtorih, pechalno kogda takie kak Vi reclamirujut RDBMS po principu - posmatri na Market , vmesto togo chobi podumatj chto dlaja konkretnoj zadachi bolee podhodit. Eto kak bi skazatj pomjagche - ne proffesiolalno po menshej mere. V tretjih - topik ja nazval "тем кому интересно что то отличное от MS SQL и Oracle " , ne interesno - ne zasorajne forum pozalusta pustimi postingami. На восточном побережье США работ на ASE по сравнению с Oracle и DB2 просто нет. Цифры "в пределах ошибки измерения". Наличие работ на ASE за пределами восточного побережья США меня не интересует. Восточное побережье США находится за пределами МКАД, то бишь настоящая глубинка ;) Так что делать выводы о том, что ASE никому не нужен, потому что не нужен по вакансиям в "глубинке" немного поспешно, нужно ориентироваться на новые, стремительно развивающиеся рынки IT индустрии. ... |
| 29.07.2005, 05:42:44 |
Зл0й pppVo pervih, eto to gde ne najti rabotu po ASE ? Raboti hvataet, na 1 poziciju po Sybase 2 kandidata , na 1 po Oracle - 10. Vo vtorih, pechalno kogda takie kak Vi reclamirujut RDBMS po principu - posmatri na Market , vmesto togo chobi podumatj chto dlaja konkretnoj zadachi bolee podhodit. Eto kak bi skazatj pomjagche - ne proffesiolalno po menshej mere. V tretjih - topik ja nazval "тем кому интересно что то отличное от MS SQL и Oracle " , ne interesno - ne zasorajne forum pozalusta pustimi postingami. На восточном побережье США работ на ASE по сравнению с Oracle и DB2 просто нет. Цифры "в пределах ошибки измерения". Наличие работ на ASE за пределами восточного побережья США меня не интересует. вы HR-manager восточного побережья США? :) ... |
| 29.07.2005, 05:54:15 |
Рыжий Кот Зл0й На восточном побережье США работ на ASE по сравнению с Oracle и DB2 просто нет. Цифры "в пределах ошибки измерения". Наличие работ на ASE за пределами восточного побережья США меня не интересует. вы HR-manager восточного побережья США? :) У меня там гнездо. ... |
| 01.08.2005, 20:31:59 |
Если Sybase хорошая, то откуда я об этом узнаю, если ею никто не пользуется. Реклама не имеет значения. Не знают - не пользуются, не пользуются - не знают, итд. Наверно, так ей и суждено остаться неизвестной, хотя сейчас фирма подыскала подходящее для себя место на рынке, но и там обходятся другими СУБД. Кроме того, мне сильно не нравится, что фирма Sybase нашкодила, продав технологию Sybase SQL Server фирме Microsoft, и что-то я не видел сообщений, что она раскаивается и просит прощения у народа. ... |
| 01.08.2005, 22:25:28 |
Ещё есть постгрис и ДБ2. И Линтер. И куча разного. ... |
| 01.08.2005, 23:17:03 |
Partisan MЕсли Sybase хорошая, то откуда я об этом узнаю, если ею никто не пользуется. Реклама не имеет значения. Не знают - не пользуются, не пользуются - не знают, итд. Наверно, так ей и суждено остаться неизвестной, хотя сейчас фирма подыскала подходящее для себя место на рынке, но и там обходятся другими СУБД. Кроме того, мне сильно не нравится, что фирма Sybase нашкодила, продав технологию Sybase SQL Server фирме Microsoft, и что-то я не видел сообщений, что она раскаивается и просит прощения у народа. Да, вроде люди её юзают, причём выкидываеют перед этим InterBase, к примеру. Сам видел :) ... |
| 02.08.2005, 00:03:16 |
Partisan MЕсли Sybase хорошая, то откуда я об этом узнаю, если ею никто не пользуется. Реклама не имеет значения. Не знают - не пользуются, не пользуются - не знают, итд. Наверно, так ей и суждено остаться неизвестной, хотя сейчас фирма подыскала подходящее для себя место на рынке, но и там обходятся другими СУБД. Кроме того, мне сильно не нравится, что фирма Sybase нашкодила, продав технологию Sybase SQL Server фирме Microsoft, и что-то я не видел сообщений, что она раскаивается и просит прощения у народа. Все гораздо проще. Когда-то двано, лет 10-12 тому назад, Sybase был вполне приемлемой СУБД по тогдашним меркам. Даже где-то пошустрее конкурентов, если в обработку транзакций особо не упираться. Имел довольно много клиентов среди финансовых учреждений в США. Потом Sybase ухитрился выпустить версию которая при неблагоприятном стечении обстоятельств невосстановимо теряла данные. На этом рынок Sybase сдулся, окончательно и бесповоротно. Фирма от этого удара не оправилсь до сих пор. ... |
| 02.08.2005, 06:24:12 |
Зл0йSybase сдулся, окончательно и бесповоротно. Фирма от этого удара не оправилсь до сих пор. Вишфулл зинкин. Весьма популярна в Канаде, стоит почти во всех банках. Недавно отстроили весьма приличный головной офис. ... |
| 02.08.2005, 07:41:26 |
В Крупнейших Украинских банках Сайбейз (АSА и особенно ASE)используется в а Опердне и других критических прилдожениях. Просто Сайбейз работает по крупным клиентам, с которых можно реально заработать деньги. Недавно с удивлением узнал, что в нашем свифт-сервере как СУБД стоит ASA. А популярность у сайбеза в наших действительно низкая, впрочем как и у DB2. Но ведь это не о чем больше, кроме как о популярности не говорит... все наши на www.corba.kubsu.ru ... |
| 02.08.2005, 10:15:35 |
Osnovnoj rinok ASE v severnoj amerike - banki i finansovie organizacii + goverment. Na East net raboti ??? ))) Da ne smeshi, tolko tam ono i estj, New York, Chicago , New Jersey, Boston. Gde finansi - tam i Sybase ASE. V Canade v practicheski lubom banke estj chto to na Sybase. Po povodu rosta popularnosti, Sybase sgorodil glupostj dge to v 90x godah krupno porugavshisj s SAP, v rezultate sejchas kusajut lokti ( SAP to sejchas ogo go kakaja baza klientov), plus tupoj marketing i menedzemt todo vrmeni. A na ASE gnatj ne nado - ochenj horoshaja baza. ... |
| 02.08.2005, 17:27:53 |
Sybase Reports Strong 2005 Second Quarter Results, Exceeding First Call Consensus Estimates На этом рынок Sybase сдулся, окончательно и бесповоротно. Фирма от этого удара не оправилсь до сих пор. Nu ni tak uz i sdulsja ))) -------------------------------------------------------------------------------- Year-Over-Year Synopsis: Total Revenue Increases 9% Database License Revenue Increases 19% Mobile & Wireless Business Grows 21% Pro Forma and GAAP Operating Income Increase 48% and 76%, Respectively -------------------------------------------------------------------------------- DUBLIN, Calif. – July 21 ,2005 – Sybase, Inc. (NYSE: SY), a leading provider of enterprise infrastructure and wireless software, today reported that total revenues for the quarter increased 9% to $204.4 million from total revenues of $188.0 million for the second quarter of 2004. License revenues increased 12% to $67.9 million for the second quarter ended June 30, 2005 compared with the same quarter a year ago. ... |
| 02.08.2005, 17:36:11 |
to Partisan M, S prodazej SQL Servera onu bolshe vsego sebe samim to i nagadili ))) ... |
| 02.08.2005, 17:39:31 |
Господа! по моему на форуме программеров не стоит обсуждать рынок продаж и ревеню фирмы SYBASE. Наше дело писать программы и и использовать покупной софт- по моему с этим все согласны. Замечание по поводу доходов фирмы - с 1994 года, когда я узнал что фирма Мерседес находится на грани банкротства, я слежу за их состоянием. Так оно не меняется к лучшему или меняется очень медленно. Но ведь сам атомобиль то какой!!! Причем здесь доходы? Аналогичная картина с компьютерами Apple Macintosh. У нас их почти нет. Доходы у фирмы небольшие, очень много уходит на НИР И ОКР, но зато какой компьютер и система! Микрософт повторяет наиболее красивые решения через 2-3 года после Apple. Наша доля в мире компьютеров Apple около 1 процента - но это ничего не доказывает - дорого для нас! Оракл в 1994 имел 2 больших клиентов в России и много людей говорили что нам ни к чему все это - Парадокс и Dbase рулят! И где все это? Про Sybase -ASA база практически бесплатная. Нас не волнует маркетинговая политика Sybase, а качество этой АСА почти как MS SQL. С той лишь разницей, что Sybase ориентируется на мобильного клиента и беспроводные решения и поэтому у нее сильно развито репликации и синхронизация данных. Аналог (и родной брат MS SQL ) это Sybase ASE. Где найти на рынке? Кто на митинском, а кто может просто купить в Sybase и других фирмах типа Axoft. На митинском доля рынка MS SQL и Sybase ASA. ASE - одна и та же. Про ревеню в митино - не знаю. ... |
| 18.08.2005, 11:13:47 |
Вчера почитал техническую презентацию про ASE15 http://www.sybase.com/sb_content/1027266/ISUG_ASE15_TechInsight_May.pdf Кому лень качать и читать: Например появилась такая интересная возможность как: расположение данных таблицы на нескольких девайсах в зависимости от значения поля - партицирование. Пример: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. И много других реально полезных возможностей. В конце презентации есть данные тестирования ASE 12.5 и ASE15 на реалььных приложениях со смещанной нагрузкой. В общем пятнашка выходжит быстрее в зависимости от типа приложения так: Real-world customer mixed workload: On average this application runs 20% faster in 15.0 Real-world customer star-schema and complex queries: Star-Schema Query runs 90% faster in 15.0 On average this application runs 50% faster in 15.0 • TPC-H query execution (untuned): On average runs 40% faster in 15.0 все наши на www.corba.kubsu.ru ... |
| 18.08.2005, 16:59:04 |
интересно, а UDF хотябы появились? ... |
| 18.08.2005, 18:09:28 |
Странно, все кто открывает топики типа отличия даной СУБД от другой, зачем-то рекламируют какую-то конкретную, кричат, с пеной у рта. Если вы хотите рассказать миру, что вы рулез и пользуете самую классную СУБД в мире, так делайте это в пивной. Каждый DBA знает, что нет ничего фундаментального, я и с dbase начинал, и всяких разностей навидался. Суть в том, что в один момент времени можно заниматься только одной системой хранения данных, и при ее выборе не стоит обращать внимания на ЛИЧНЫЕ пристратия. Честно говоря, сейчас на рынке больших БД можно сравнивать только Oracle и DB2, последний, в связи с не верной маркетинговой политикой, мало представлен в Росии, я надеюсь нас интересует в основном эта страна. Хотя и их сравнивать не совсем правильно, они изначально построены на разных принципах. ... |
| 19.08.2005, 06:40:43 |
2alexey_tm: Вообще-то этот топик называется ASE News. В ASE15 появляется много новых возможностей относительно ASE12.5 и это стоит обсудить и посравнивать. Топиков про сравнение Oracle vs Db2 vs MSSql200x пруд пруди, и чем вам так не приглянулся этот топик мне непонятно. P.S. ASE - это большая СУБД, и кол-во реально работающих систем на ней в наших краях (ИМХО) будет больше чем у DB2. все наши на www.corba.kubsu.ru ... |
| 19.08.2005, 10:06:54 |
start [/forum/topic.php?desktop=1&fid=35&tid=1553743]: |
180ms |
77ms |
| others: | 245ms |
| total: | 551ms |
