вопрос из 070-228
Кто-нибудь знает правильный ответ на вопрос который приводится ниже? В разных braindump-ах по разному - где c, где d. Может кто-нибудь обоснует? 27.You are the administrator of a Microsoft Windows NT Server 4 0 computer The server is the PDC in your domain and also runs SQL Server 2000. The server has four processors and 1 GB of RAM. Your network consists of 500 client computers that are running Microsoft Windows Millennium Edition. Users report that when they log on in the morning their computers respond slowly and occasionally return error messages. You use System Monitor to monitor processor performance and RAM utilization You discover that the % Total Time and % User Time counters average 90 percent and the % Privileged Time counter averages 20 percent. The Available Mbytes counter averages 800 MB. You need to improve server performance for user logons. What should you do? a. Increase the physical RAM on the computer to 2 GB b. Increase the virtual RAM on the computer to 4 GB c. Configure SQL Server to use only processors 1,2, and 3 d. Configure SQL Server to use only processors 0, 1, and 2 ... |
| 18.02.2005, 12:00:48 |
вопрос из 070-228
Before you change the setting of affinity mask, keep in mind that Windows NT 4.0 and Windows 2000 assign deferred process call (DPC) activity associated with NICs to the highest numbered processor in the system. In systems with more than one installed and active NIC, each additional card's activity is assigned to the next highest numbered processor. For example, an eight-processor system with two NICs has DPCs for each NIC assigned to processor 7 and to processor 6. Note You can use System Monitor (Performance Monitor in Windows NT 4.0) to view and analyze individual processor usage. это выдержка из BOL, таким образом правильный ответ d ... |
| 18.02.2005, 12:14:22 |
вопрос из 070-228
Я поискал и сам нашел такое обьяснение(думаю оно правильное): Answer: C Explanation: The system monitor clearly indicates that the processors are overloaded. We need to decide which processors we should use for SQL Server. Processor 0 is the default CPU for the I/O subsystem. Network Interface Cards (NIC) are assigned to the remaining CPUs, starting from the highest-numbered CPU. The NIC would get processor 3. SQL Server would be using all four processors by default. The Windows NT/2000/XP operating system use processor 0. In order to avoid the logon problems we should not let SQL Server to use this processor. Instead SQL Server should be configured to use processor 1, 2, and 3. ... |
| 18.02.2005, 13:04:42 |
start [/forum/topic.php?desktop=1&fid=34&tid=1551738]: |
173ms |
48ms |
| others: | 231ms |
| total: | 498ms |
