Вопрос по 70-316
You work as a software developer at TestKing.com. You develop a Windows-based application that includes two objects named TestKingContact and TestKingEmployee. TestKingEmployee inherits from TestKingContact, and TestKingContact exposes an event named DataSaved. You want to raise the DataSaved event from TestKingEmployee. What should you do? A. Call the RaiseEvent method from TestKingEmployee and pass DataSaved as the event name. B. Add the Public keyword to the DataSaved declaration in TestKingContact. Call the RaiseEvent method from TestKingEmployee. C. In TestKingContact, create a protected method named RaiseDataSaved that explicitly raises the DataSaved event. Call RaiseDataSaved from TestKingEmployee. D. In TestKingEmployee, create a protected method named RaiseDataSaved that explicitly raises the DataSaved event in TestKingContact. Call RaiseDataSaved to fire the event. В тесткинге правильный ответ А. Но метод RaiseEvent есть только в Visual Basic. ... |
| 08.09.2006, 14:10:23 |
Вопрос по 70-316
You work as a software developer at TestKing.com. You create a form in your Windows-based application. The form contains a command button named checkTestKingButton. When checkTestKingButton is clicked, the application must call a procedure named GetTestKing. Which two actions should you take? (Each correct answer presents part of the solution. Choose two) A. Add arguments to the GetTestKing declaration to accept System.Object and System.EventArgs. B. Add arguments to the checkTestKingButton_Click declaration to accept System.Object and System.EventArgs. C. Add code to GetTestKing to call checkTestKingButton_Click. D. Add the following code segment at the end of the GetTestKing declaration: Handles checkTestKingButton.Click E. Add the following code segment at the end of the checkTestKingButton_Click procedure: Handles GetTestKing В тесткинге правильный ответ BD. Тоже. Слово Handles есть только в Visual Basic. ... |
| 08.09.2006, 14:19:13 |
start [/forum/topic.php?desktop=1&fid=34&tid=1551351]: |
33ms |
28ms |
| others: | 201ms |
| total: | 305ms |
