1z0-042
QUESTION 47: You work as a database administrator for Certkiller .com. You want to be notified when the number of disk I/O increases by 10% of what it was yesterday. You create a baseline metric for yesterday's disk I/O performance. How do you use the baseline metrics to achieve your objective? A. Save the baseline in the database B. Save the baseline in the Database Control Home Page C.Create a procedure to read and apply the baseline to disk I/O metrics D.Apply the baseline to the disk I/O metrics in the Mange Metrics page E.Alter the disk I/O metrics to include baseline by using the ALTER METRICScommnd Answer: D На странице Mange Metrics нет такого параметра "disk I/O" Как это понимать? ... |
| 17.10.2007, 11:36:03 |
1z0-042
и еще один вопрос неoсилил QUESTION 53: You work as a database administrator for Certkiller .com. In your organization, you have four databases, Certkiller DB01, Certkiller DB02, Certkiller DB03, and Certkiller DB04, which are located in Berlin, Frankfurt,Rammstein, and Munich respectively, and which were created using Database Configuration Assistant (DBCA). You want to perform administrative tasks on these databases that include startup and shutdown, taking regular backups, and so on, fromFrankfurtusing Oracle tools. Which Oracle file would you enable to perform this task? A. Control file B. Password file C.Parameter file D.Online redo log file E.Listener controller file F.Server parameter file Answer: B причем тут "enable Password file" и что это значит? ... |
| 17.10.2007, 13:22:25 |
1z0-042
sa22причем тут "enable Password file" и что это значит? Поищите по форуму что-ли... ... |
| 17.10.2007, 13:24:52 |
1z0-042
Видимо имеется ввиду, что для подключения админа используется файл паролей... ... |
| 17.10.2007, 13:26:37 |
1z0-042
tru55Видимо имеется ввиду, что для подключения админа используется файл паролей... ... который должен быть "enabled" :) ... |
| 17.10.2007, 13:32:16 |
1z0-042
sa22QUESTION 47: You work as a database administrator for Certkiller .com. You want to be notified when the number of disk I/O increases by 10% of what it was yesterday. You create a baseline metric for yesterday's disk I/O performance. How do you use the baseline metrics to achieve your objective? A. Save the baseline in the database B. Save the baseline in the Database Control Home Page C.Create a procedure to read and apply the baseline to disk I/O metrics D.Apply the baseline to the disk I/O metrics in the Mange Metrics page E.Alter the disk I/O metrics to include baseline by using the ALTER METRICScommnd Answer: D На странице Mange Metrics нет такого параметра "disk I/O" Как это понимать? Baseline создается на странице Manage Metrics ... |
| 17.10.2007, 13:41:03 |
1z0-042
juks@gala.net sa22QUESTION 47: You work as a database administrator for Certkiller .com. You want to be notified when the number of disk I/O increases by 10% of what it was yesterday. You create a baseline metric for yesterday's disk I/O performance. How do you use the baseline metrics to achieve your objective? A. Save the baseline in the database B. Save the baseline in the Database Control Home Page C.Create a procedure to read and apply the baseline to disk I/O metrics D.Apply the baseline to the disk I/O metrics in the Mange Metrics page E.Alter the disk I/O metrics to include baseline by using the ALTER METRICScommnd Answer: D На странице Mange Metrics нет такого параметра "disk I/O" Как это понимать? Baseline создается на странице Manage Metrics я не пойму где они нашли "disk I/O" ... |
| 17.10.2007, 13:59:23 |
1z0-042
Я сейчас тоже готовлюсь и понял что вопросы очень часто тупо копируют текст из Оракловых Workshops. По первому вопросу там так и сказано Password file: Allows users to connect remotely to the database and perform administrative tasks то есть о чем вас прямо и спросили. По второму - может и нет там про диски ничего :) но тут понятно что из всех ответов - только это более менее внятный - про трешхолды и бейзлайны. Впрочем я не удивлен, вчера сам задавал вопрос по 042 - где ответ был академически правильный, но практически нет. ... |
| 17.10.2007, 16:02:50 |
1z0-042
1Z0-042You work as a database administrator for Certkiller .com. Your listener process, L1, is currently listening to three databases: CertK INDB04, Certkiller DB05 and Certkiller DB06. Using Database Configuration Assistant (DBCA) you create one more database, Certkiller DB07, and enable dynamic registration. Which two commands of Listener Control Utility (lsnrct1) would you use to determine whether the dynamic registration occurred for the database, Certkiller DB07, with the L1 listener process? Choose two A.SHOW L1 B.SPAWN L1 C.STATUS L1 D.SERVICES L1 E.STATUS LISTENER F.SERVICES LISTENER G.SHOWcurrent_listener Answer: C, E Моя непонятка: при чем тут E.STATUS LISTENER ? Ведь в вопросе явно спрашивают как проверить динамическую регистрацию именно на листенере L1. ... |
| 06.11.2009, 08:01:19 |
1z0-042
studyozus1Z0-042You work as a database administrator for Certkiller .com. Your listener process, L1, is currently listening to three databases: CertK INDB04, Certkiller DB05 and Certkiller DB06. Using Database Configuration Assistant (DBCA) you create one more database, Certkiller DB07, and enable dynamic registration. Which two commands of Listener Control Utility (lsnrct1) would you use to determine whether the dynamic registration occurred for the database, Certkiller DB07, with the L1 listener process? Choose two A.SHOW L1 B.SPAWN L1 C.STATUS L1 D.SERVICES L1 E.STATUS LISTENER F.SERVICES LISTENER G.SHOWcurrent_listener Answer: C, E Моя непонятка: при чем тут E.STATUS LISTENER ? Ведь в вопросе явно спрашивают как проверить динамическую регистрацию именно на листенере L1. Я вас не пойму. Вы ищете подтверждения что все эти пробные экзамены полны ошибок? Да это так. :D ... |
| 07.11.2009, 06:21:55 |
1z0-042
А вот у меня после сдачи этого экзамена возникло такое ощущение, что если в ответе на вопрос есть EM или какой-нибудь Tune advicer, то этот ответ почти всегда правильный.... скрытая реклама ))) Модератор: Тема перенесена из форума "Oracle". ... |
| 08.11.2009, 19:25:51 |
start [/forum/topic.php?desktop=1&fid=34&tid=1550543]: |
194ms |
42ms |
| others: | 197ms |
| total: | 482ms |
