Тестовы вопрос по репликации
Добрый день всем! Есть сомнения по поводу правильного ответа в данном тестовом вопросе: You administer all the deployments of Microsoft SQL Server 2012 in your company. You need to ensure that an OLTP database that includes up-to-the-minute reporting requirements can be off-loaded from the primary database to another server. You also need to be able to add indexes to the secondary database. Which configuration should you use? A. • Two servers configured in different data centers • SQL Server Availability Group configured in Synchronous-Commit Availability Mode • One server configured as an Active Secondary B.• Two servers configured in the same data center • SQL Server Availability Group configured in Asynchronous-Commit Availability Mode • One server configured as an Active Secondary C. • Two servers configured in the same data center • A primary server configured to perform log-shipping every 10 minutes • A backup server configured as a warm standby D.• Two servers configured in different data centers • SQL Server Availability Group configured in Asynchronous-Commit Availability Mode E. • Two servers configured on the same subnet • SQL Server Availability Group configured in Synchronous-Commit Availability Mode F.• SQL Server that includes an application database configured to perform transactional replication G.• SQL Server that includes an application database configured to perform snapshot replication H • Two servers configured in a Windows Failover Cluster in the same data center • SQL Server configured as a clustered instance Answer: F Я бы выбрал AlwaysOn (E or B) т.к. 70-462 учебник, стр. 449 : " Using AlwaysOn Replicas to Improve Concurrency In many cases, queries that are used to support reporting can reduce concurrency in online transaction processing (OLTP) systems. Reporting must often read large amounts of data and perform aggregate operations on the results. When this happens in an OLTP system, the users trying to INSERT, UPDATE, or DELETE data are often blocked, waiting for the reporting process to complete. In SQL Server 2012, the capability now exists to offload this reporting load to a read-only replica. This is accomplished by adding a new clause to the connection string for the reporting application, indicating that it’s ApplicationIntent=ReadOnly." Если это действительно так, то из вопроса не следует в каком режиме должна быть группа AlwaysOn (Asynchronous-Commit или Synchronous-Commit). ? Заранее всем спасибо. ... |
| 04.12.2012, 15:46:36 |
start [/forum/topic.php?desktop=1&fid=34&tid=1550072]: |
217ms |
36ms |
| others: | 231ms |
| total: | 538ms |
