PowerDesigner 9.5: цвет фона в свойствах процедуры
Старею... Как задать? Белый задрал. С уважением, Мартин Рахманов http://jimmers.russia.webmatrixhosting.net/ ... |
| 16.05.2005, 14:29 |
Хорошо, как это сделать в более новых версиях продукта? С уважением, Мартин Рахманов http://jimmers.russia.webmatrixhosting.net/ ... |
| 16.05.2005, 16:57 |
Нашёл тут : От:Mike Nicewarner [TeamSybase] (TeamSybase.5.psyclo@spamgourmet.com) Тема:Re: Customize colors in Editor View this article only Группы новостей:sybase.public.sqlanywhere.general Дата:2002-10-22 08:53:41 PST The color situation in PowerDesigner has been acknowledged and a dialog box is in the works. Until then, you can change the colors: The change can be done in registry under the key [HKEY_CURRENT_USERSoftwareSybasePowerDesigner 9ControlsEditor] When you install PowerDesigner, the ControlsEditor is almost empty. The keys are dynamically created once you have opened a syntax editor in PowerDesigner (preview, script, VB Script, ...). You will then be able to change their values. Obviously, the preview depends on the language (SQL, Java, C++, XML, ...) you're viewing. You can change the syntax coloring for each type of file (Java, SQL, C++, ...). For each file type, there are several category of colors: - Comment - Keyword - Number - Operator - String - Text - Text Selection For each category, you can change the foreground color and background color. NOTE: In general, you don't need to change the background color. For changing the text colors: - Open the registry and go to the node HKEYCURRENT_USER/Software/Sybase/PowerDesigner 9/Controls/Editor - Open the node of the file type, for example, SQL Files: - Open the Color Groups node. - Select a category, for example, Comment. - Create a new DWORD entry and rename the entry to Foreground - Change the value of the entry to a hexa format (ie) BBGGRR Example: 0000FF (red), FF0000 (blue), ec00c000 (Green) -- Michael F. Nicewarner [TeamSybase] http://www.datamodel.org mailto:TeamSybase.5.psyclo@spamgourmet.com ... |
| 17.05.2005, 10:59 |
Вот скрипт для замены цвета фона на светло-зелёный: Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\Software\Sybase\PowerDesigner 9\Controls\Editor\SQL Files\Color Groups\Text] "Background"=dword:00c8d2af[src][/src] Хотя может это всё-таки можно сделать через GUI, хотя бы в PD 11? ... |
| 17.05.2005, 11:05 |
Код: plaintext 1. 2. 3. 4. Это добавка для человеческого цвета комментов в T-SQL. ... |
| 17.05.2005, 11:19 |
Прилагаю REG скрипт для PD 11 Trial. С уважением, Мартин Рахманов http://jimmers.russia.webmatrixhosting.net/ ... |
| 13.07.2005, 17:40 |
start [/forum/topic.php?desktop=1&fid=32&tid=1545385]: |
38ms |
38ms |
| others: | 257ms |
| total: | 370ms |
