SQL Developer Data Modeler ( create the user defined text typ)
Hallo! We are migrating from Oracle Designer to SQL Developer Data Modeler How can we apply the user extensions (user defined text type for example for Entities from Designer in SDDM? hier is the exmaple from Designer: in the Administartion Utility i can create the new user defined Text Typ "UEICON Import Configuration" for Entities) and in the Repository Object Navigator you can see, every entitiy apply the new User Extension (UE) Property "Import Configuration" (see the picture) How can I make this in SDDM? Thanks! ... |
| 28.07.2014, 13:35:11 |
start [/forum/topic.php?desktop=1&fid=32&tid=1540838]: |
28ms |
70ms |
45ms |
| others: | 359ms |
| total: | 559ms |
