Конфигурация ReportServer'a 2005
Никак не могу запустить ReportServer'a 2005. Начинаю конфигурацию, дохожу до Database Setup, задаю ServerName, DBName(новое) . Начинается создание БД, Доходит до конца и выходит Warning-. Although saving the database connection succeeded, the report server cannot access internal information about this deployment to determine whether the current configuration is valid for this edition. If you are configuring a scale-out deployment, that feature is not supported by this edition. To continue, use a different report server database or remove the encryption keys from the current database before initializing the report server . ReportServicesConfigUI.WMIProvider.WMIProviderException: The version of the report server database is either in a format that is not valid, or it cannot be read. The found version is 'Unknown'. The expected version is 'C.0.8.40'. To continue, update the version of the report server database and verify access rights. (rsInvalidReportServerDatabase) at ReportServicesConfigUI.WMIProvider.RSReportServerAdmin.ThrowOnError(ManagementBaseObject mo) at ReportServicesConfigUI.WMIProvider.RSReportServerAdmin.ListReportServersInDatabase(RSReportServerInfo[]& serverInfos) Я определил по профайлеру, что ищется прцедура GetDBVersion. Что это такое, и где ее взять? ... |
| 01.03.2006, 17:06:43 |
start [/forum/topic.php?desktop=1&fid=31&tid=1539174]: |
99ms |
43ms |
| others: | 351ms |
| total: | 548ms |
